Adding support for the enraged rabbit carrot feeder (ERCF)
Accessories and Add-ons
12
64
11.3k
    pfn @Alex.cr
    @alex-cr on my duet2, for testing, I was able to reliably get 70-100 pulses per second in some standalone experiments
    https://forum.duet3d.com/post/252836
    I did initial development of the ERCF gcode on duet2, but never tried with feed rates greater than 40mm/s (having jamming problems really got in the way of going any faster).
    On the duet3, I haven't tested to see how fast the encoder can trigger, however, I load at 150mm/s completely reliably, the pulse count generally matches what I expect for an ~800mm bowden. Again, a less than perfect build prevents me from loading at much faster than 150mm/s with any level of reliability.
    This might be another sbc difference, it seems triggers would have to be invoked from the duet to the sbc for processing, and that appears to introduce latency that would limit the max pulse/second rate.
      danzaywer @pfn
      @pfn
      I redesigned one of the pieces of the selector to insert an endstop with a steel ball just to have the feedback necessary to understand any anomalies, in this way I can know if the wire is present up to the extruder if it is stuck in the tube or if it is short to portray it. As soon as I have time I will make a further modification to have both endstop and encoder (or laser filament sensor). I also save the state by storing the active tool in a variable and write to a file that is loaded by config.g. the U axis homing after a certain number of changes (set with a local variable) because the smuff carriage does not flow very well ...
        danzaywer @pfn
        @pfn
        I have three macros:
        • TFREEMASTER.G invoked by all tfreex.g
        • TPREMASTER.G by tprex.g
        • TPOSTMASTER.G by tpostx.g
        you could enter in tpostmaster:
        M98 P "ercf / lib / load-tool.g" T{state.currentTool}
        as far as temperatures are concerned, I manage them with 6 global variables:
        global ToolF; first layer temperature tool
        global ToolC; temperature toolchange
        global ToolT; first layer temperature tool
        global ToolS; standby temperature
        global bedH; first layer bed temperature
        global bedB; temperature bed
        these variables are set by "/ filaments / <filament-name> /config.g", where I can possibly also insert pressureadvance and more, the template I use is
        0:/filaments/ABS/config.g
        var firstlayertemp=240
        var layertemp=235
        var standbytemp=180
        var toolchangetemp=234
        var firstlayerbed=103
        var layerbed=95
        set global.toolF=var.firstlayertemp
        set global.toolT=var.layertemp
        set global.toolS=var.standbytemp
        set global.toolC=var.toolchangetemp
        if global.isfirstBedHeat && global.setBed
        set global.bedH=var.firstlayerbed
        set global.bedB=var.layerbed
        set global.isfirstBedHeat=false
        i don't need load.g and unload.g of the filament
        the temperature of the tool and of the bed is set by a macro that I inserted in the start gicode of the slicer and at the tool change. In superslicer I put this:
        ;Start G-code
        M83
        set global.slicer=3
        set global.layercount=0
        {if wipe_tower}set global.slicerwipe=true{endif}{if !wipe_tower}set global.slicerwipe=false{endif};wipetower
        T[current_extruder]
        M703
        M98 P"/sys/DEFAULTS/heatup.g"
        M116
        ;end start
        ;BEFORE_LAYER_CHANGE
        G92 E0.0
        {if layer_num>0}set global.layercount=[layer_num]{endif}
        ;[layer_z]
        ;AFTER_LAYER_CHANGE
        ;SET LAYER COUNT
        {if layer_num<2}{if layer_num>0}M98 P"/sys/DEFAULTS/heatup.g"{endif}{endif}
        ;TOOL CHANGE G-CODE
        T[next_extruder]
        for CURA I have to initialize the global.layercount to -1 in the start and then pass in post processing script:
        set global.layercount = {global.layercount + 1}
        of course you have to set ALL the temperatures of ALL the materials to 0 in superslicer to let the printer manage everything!
        in this way and setting the tools in config.g with:
        M584 X0 Y1 Z2:9 E3:3:3:3:3 U4 V8 P5
        M563 P0 S"E1 " D0 H1 F2 ; Define tool 0 P=tool number, D=driver number, H=heather, F= fan
        M563 P1 S"E2 " D1 H1 F2 ; Define tool 1
        M563 P2 S"E3 " D2 H1 F2 ; Define tool 2
        M563 P3 S"E4 " D3 H1 F2 ; Define tool 3
        M563 P4 S"E5 " D4 H1 F2 ; Define tool 4
        ;M563 P99 S"SUPPORT" D5 H2 F2 ; Define tool 99
        I can have the materials assigned to each tool and with a flag variable that disables the execution of the tool change macros outside of printing I can change the material from the web interface to any tool (obviously not for the one currently loaded, for that I disable the flag to physically perform the unloading and loading).
        in start.g the tool actually loaded is always selected.
        the slicer only deals with the management of the fans as they are strictly linked to the gcode and the material, I don't think it can be left to the firmware to manage it ...
        my only current problem is that when i change filament with ATX off the printer tries to heat the tool and i have a temp fault, i could not understand where i went wrong as the heater should stay off, as soon as i have time i investigate, for now it is a manageable problem.
        undefined 1 Reply Last reply 4 Dec 2021, 18:29 Reply Quote 1
          danzaywer @pfn
          @pfn
          sorry if i ask a stupid question, what is the purpose of
          M42 P {global.ercf_servo_num} S0
          when do you engage and disengage the servo?
          undefined 1 Reply Last reply 3 Dec 2021, 15:31 Reply Quote 0
            pfn @danzaywer
            @danzaywer that is to turn the servo off after making its move. The servo is moved in engage and disengage macros
            undefined 1 Reply Last reply 3 Dec 2021, 18:19 Reply Quote 0
              danzaywer @pfn
              @pfn is a good idea to turn servo off during engage? I think it will cause lost of grip on filament....
              undefined 1 Reply Last reply 3 Dec 2021, 18:20 Reply Quote 0
                pfn @danzaywer
                @danzaywer on the ercf, once the servo reaches past a position, it will be locked into place, so there would be no loss of grip
                  Alex.cr @pfn
                  @pfn said in Adding support for the enraged rabbit carrot feeder (ERCF):
                  There's also some problems around properly changing temperatures if changing material type that comes with not using Tx, I'm not sure if I want to cave and use the tool notation for changing filaments.
                  My vote is to leave any Tx out of the equation. I should think we can write a filament change macro that can account for temps without having to build 4-9 different tools in the config file. That or leave it to the slicer and make sure the necessary G10 lines are over there. That is my plan at least.
                  Interesting I missed that part of the forum post. I even chimed in at the end... I am for sure getting different trigger/pulse events that I would expect. I have a few changes I need to make to my ERCF and then I will be testing more.
                  Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                  undefined undefined 2 Replies Last reply 4 Dec 2021, 11:26 Reply Quote 1
                    pfn @Alex.cr
                    @alex-cr the main problem with slicers is that they will output G10 Px Stemp where x is the tool number (for the case of mmu, the virtual tool)--this is at least the case for superslicer, and possibly prusaslicer.
                    undefined 1 Reply Last reply 4 Dec 2021, 17:54 Reply Quote 0
                      danzaywer @Alex.cr
                      @alex-cr said in Adding support for the enraged rabbit carrot feeder (ERCF):
                      if I can express my opinion I think that sticking to the standard firmware logic can only bring advantages. Tx invokes in order Tfreex-Tprex-Tpostx, just leave the unused ones empty and invoke for example the macro of the tool change in Tpostx. Don't reinvent things that already exist, especially if they are done well. I currently have a fully functional Smuff V6 system (apart from the hardware limits of smuff) with temperature management and relative PID made by firmware, all made with standard structures in about 20 total macros
                      undefined 1 Reply Last reply 4 Dec 2021, 18:21 Reply Quote 0
                        Alex.cr @pfn
                        This can be overcome by just putting 'G10 P0 Stemp' in the tool change G code to override superslicer from putting in other commands.
                        That being said, you and @danzaywer are probably correct in that 'Tx' commands are probably the correct way to go to be more slicer agnostic and follow convention.
                        undefined 1 Reply Last reply 4 Dec 2021, 18:20 Reply Quote 0
                          pfn @Alex.cr
                          @alex-cr superslicer will always emit G10 Px Sy regardless of any toolchange gcode.
                          I'm generally not a fan of using Tx still because it pollutes the /sys folder. Right now, I'm just experimenting with creating the tool but not ever actually using the tool.
                          My printer is temporarily down as some belts and wires got destroyed. So I won't be working on this until after the holidays are over, most likely.
                            pfn @danzaywer
                            @danzaywer said in Adding support for the enraged rabbit carrot feeder (ERCF):
                            I'm not a huge fan of creating all the tXXX.g macros in /sys -- if simply creating the tools in config is enough to allow temperature control, I will likely use that approach
                              pfn @danzaywer
                              why do you need a layercount? this is also available from object model...
                              in general, I'm not a fan of doing RRF filament temperature management, I still have a purge line at the beginning of my print, and moving a purge line logic into filament settings is very convoluted and inelegant. It may be something I investigate more as I become more fully setup with MMU printing, but at the moment, it conflicts with my design goals. My design goal is to make mmu(ercf) support drop in and easily removable. There should be minimal calls into ercf from regular RRF settings (the only line should really be the macro call for init.g); additionally, it should be easily moved to another printer with minimal manual configuration (should require user changes to only settings.g)
                              undefined 1 Reply Last reply 5 Dec 2021, 01:03 Reply Quote 0
                                danzaywer @pfn
                                because I was unaware of the existence of job.layer and I built it by myself ... thanks for the tip! one less global variable in memory!
                                why would you move purge line logic into filament management? I think it continues to be managed by the slicer, I don't use it, I use a skirt line for filament priming but I can verify. The purge tower works for me without problems
                                undefined 1 Reply Last reply 5 Dec 2021, 01:06 Reply Quote 0
                                  pfn @danzaywer
                                  because purge has to come after heating, and that depends on the filament being set, which comes after start gcode. and single material prints don't have any purge behavior -- that's one thing I need to figure out how to detect from the print job
                                  undefined 2 Replies Last reply 5 Dec 2021, 10:19 Reply Quote 0
                                    danzaywer @pfn
                                    Yes, is all correct and is all working well to me!
                                      danzaywer @pfn
                                      In start gcode I put M703 after Tx then temperature macro
                                      undefined 1 Reply Last reply 5 Dec 2021, 14:50 Reply Quote 0
                                        pfn @danzaywer
                                        How does the start gcode know which filament is loaded? M703 can only heat with the correct filament loaded (and I actually have M703 in tpost already).
                                        I suppose this isn't an issue outside of the first job with a new tool if the filaments in the tool don't change, but I'm still changing filaments frequently per tool (pla to petg and abs), and that state that rrf keeps is going to be frequently out of sync
                                        undefined 1 Reply Last reply 5 Dec 2021, 15:14 Reply Quote 0
                                          danzaywer @pfn
                                          @pfn first of all https://duet3d.dozuki.com/Wiki/Slicing_recommendations
                                          In prusaslicer or superslicer start gcode put T[current_extruder]
                                          In toolchange gcode put T[next_extruder]
                                          At job end i leave filament in hotend.It is also stored in a file parsed in config.g by tpostx.g macro. When new job start if T[next_extruder] is the extruder already loaded then reprap firmware do nothing, otherwise toolchange macros begins.I also store tool T-1 during unload (tfreex.g) so if powerfailure happens with no tool selected firmware know it at restart.
                                          You have to put M703 into tpostx.g and after T[next_extruder] in start gcode otherwise if tool is already loaded RepRapFirmware not run toolchange macro and m703 inside it is not applied, of course it depend to what m703 do, in my case it Set global variables related to temps of tool selected.
                                          undefined 1 Reply Last reply 5 Dec 2021, 15:22 Reply Quote 0
                                          42 out of 64
