    M84 error after upgrade to 3.3
    1.6k
    • mringersollundefined
      mringersoll @fcwilt
      @fcwilt
      so how do i get to that line of code to post it?
        mringersoll @fcwilt
        @fcwilt
        and what do i use to open it to get the line
        Thanks
        • fcwiltundefined
          fcwilt @mringersoll
          @mringersoll said in M84 error after upgrade to 3.3:
          Thanks
          It's a text file. You can open it in most any text editor - one with line numbers would be helpful.
          Or you can also upload to the SYSTEM folder in the DWC and open it there.
          mringersollundefined 1 Reply Last reply Reply Quote 0
            mringersoll @fcwilt
            @fcwilt
            M84 E ; disable for more accurate probing,is what is says.
            Also why is the Z axis staying up so high the nozzle is about 6mm from the bed. and during probing i does not go down much at all before it goes back up the probe is triggering way early not even close to the bed when I home the printer the probe works as expected don't get it.
            Mike
            fcwiltundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @mringersoll
              Well there is why you are getting an error. Whatever is generating that line of code is not putting the number(s) after the E.
              If you use to work possibly the older firmware didn't handle that error properly or perhaps in the absence of any number(s) it used a default.
              • fcwiltundefined
                fcwilt @mringersoll
                We would need to see your homing files first.
                Have you made any changes to your config file? If so post it again.
                  If you change that line to M84 E0 that should solve that error, though I'm not sure it's related to your homing problem. For that we would need to see your homing files and start gcode as well.
                    mringersoll @Phaedrux
                    @phaedrux Ok here are the homing files but my problem is the nozzle stays like 3mm above bed when it prints.
                    ; homeall.g
                    ; called to home all axes
                    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 06 2021 04:14:12 GMT-0600 (Central Standard Time)
                    G91 ; relative positioning
                    G1 H2 Z5 F9000 ; lift Z relative to current position
                    G1 H1 X-243 Y-241 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X5 Y5 F9000 ; go back a few mm
                    G1 H1 X-243 Y-241 F600 ; move slowly to X and Y axis endstops once more (second pass)
                    G90 ; absolute positioning
                    G1 X59 Y27 F9000 ; go to first bed probe point and home Z
                    ;G91 ; relative positioning
                    ;G1 Z5 F150 ; lift Z relative to current position
                    ;G90 ; absolute positioning
                    ; homex.g
                    ; called to home the X axis
                    G1 H1 X-240 F2400 ; move quickly to X axis endstop and stop there (first pass)
                    G1 H2 X5 F9000 ; go back a few mm
                    G1 H1 X-240 F600 ; move slowly to X axis endstop once more (second pass)
                    G1 H2 Z-5 F9000 ; lower Z again
                    ; homey.g
                    ; called to home the Y axis
                    G1 H1 Y-240 F2400 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 H2 Y5 F9000 ; go back a few mm
                    G1 H1 Y-240 F600 ; move slowly to Y axis endstop once more (second pass)
                    ; homez.g
                    ; called to home the Z axis
                    G1 X59 Y25 F9000 ; go to first probe point
                      Phaedrux Moderator @mringersoll
                      M558 P5 C"^!zprobe.in" H5 F240 T9000 ; set Z probe type to switch and the dive height + speeds
                      G31 P1000 X-47 Y-11 Z1.90 ; set Z probe trigger value, offset and trigger height
                      M557 X12:193 Y16:214 S25 ; define mesh grid
                      What type of Z probe do you have?
                      Have you calibrated the z trigger height recently?
                      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                      What do you have in your slicer start gcode? I don't see anything wrong with your homing files.
                      mringersollundefined 2 Replies Last reply Reply Quote 0
                        @phaedrux Hello Again
                        I am using an EZabl for my probe and calibration about 2 days ago. I am using an Ender 3 Cura or simplfy3d slicer i tried to copy and paste to get my cura Start G code but does not work.
                        Mike
                          @phaedrux Hello
                          Here is the start gcode from my slicer
                          ;M75 ; Start Print Timer and Engage Fil Sensor if USB Printing
                          G92 E0 ; Reset Extruder distance to 0
                          G1 E-2 ; Retracts filament to prevent blobs during probing
                          M84 E ; Disable E Motor for probe accuracy on direct drive systems
                          G28 ; home all axes
                          G28 Z ; home Z to get more accurate Z position
                          G29; EZABL mesh generation
                          G4 S10; wait for heaters to recover
                          M117 Purge extruder
                          G92 E0 ; reset extruder
                          G1 Z1.0 F3000 ; move z up little
                          G1 X0.16 Y26 Z0.3 F5000.0 ; move to start-line position
                          G1 X0.16 Y110.0 Z0.3 F750.0 E15 ; draw 1st line
                          G1 X0.6 Y110.0 Z0.3 F3000.0 ; move to side a little
                          G1 X0.4 Y13 Z0.3 F730.0 E12 ; draw 2nd line
                          M117 Printing.....
                          • fcwiltundefined
                            fcwilt @mringersoll
                            @phaedrux Hello
                            G28 ; home all axes
                            M117 Purge extruder
                            M117 Printing.....
                            Where did that code come from?
                              mringersoll @fcwilt
                              @fcwilt Hello That is the Start gcode from my Slicer like i was asked for.
                              Also as i said before there is something triggering my Z probe way off the print bed i mean the probe is nowhere near the bed when it triggers. When i run G28 the probe works as expected goes close to bed, anything after the probe might get 4mm from bed so something is messing with the Z Probe.
                              Mike
                              • fcwiltundefined
                                fcwilt @mringersoll
                                Mike
                                You mentioned Cura and Simplify3D as the slicers you use. Is that correct?
                                Which slicer was the code you post from?
                                Was this code you entered in the user code location in the slicer or was it completely generated by the slicer?
                                mringersollundefined 3 Replies Last reply Reply Quote 0
                                  mringersoll @fcwilt
                                  @fcwilt Hello
                                  slicer generated with the addition for mesh bed probing
                                    mringersoll @fcwilt
                                    @fcwilt oh sorry Cura 4.12.1
                                      mringersoll @fcwilt
                                      @fcwilt Hello
                                      well not sure how to fix it but when i turn on the printer in the console menu of my Paneldue there are two lines back to back that say bad model perimeter it is at the beginning seems to be after the network stuff than wifi starts so how do i start all over with this firmware and such.
                                      • fcwiltundefined
                                        fcwilt @mringersoll
                                        I would suspect your M307 commands in the heater section.
                                        The first is M307 H0 B1 S1.5. The S parameter is limited to 0 to 1.
                                        The second is M307 H1 B0 S0.00. While the S parameter is within range it doesn't make sense.
                                        Try setting them both to 1.0 and check again.
                                        mringersollundefined 1 Reply Last reply Reply Quote 1
                                          I'd suggest going through the calibration again. See if the trigger height is what it should be. I don't see anything in the gcode that would cause it to trigger so high. so it may be an issue with the probe. Recalibrating would let you test it's trigger height.
                                            mringersoll @fcwilt
                                            @fcwilt Hello
                                            well if this is not in the 1.3,1.5 Range i get a heater error that says heater not heating at a fast enough rate.
                                            The first is M307 H0 B1 S1.5. how do i solve that problem.
                                            Mike
