    Sanity Check! Tool Offsets: G10 P0 X...
    • DocTruckerundefined
      DocTrucker
      Hi All,
      Looking to implement a little meta coding object to repeat a specific pattern a number of times from an offset based on the current head position.
      Is the following current best practice for that procedure?
      • Read current head position from object model.
      • Read current G10 P0 offset from object model.
      • Apply appropriate offset to the G10 P0 values to make the current position position X=0, Y=0.
      • Run print job with M98 P"build-name.gcode" (Is this any worse than using the specific start build gcode?)
        ...Move head, repeat...
      I believe that is better than resetting the position using G92 as it doesn't invalidate any bed probing?
      Cheers.
        DocTrucker
        So this is the test macro (that works):
        var tool_num = 0
        var num_x_pattern = 3
        var num_y_pattern = 2
        var x_pattern_space = 50.0
        var y_pattern_space = 25.0
        var int_x = move.axes[0].machinePosition
        var int_y = move.axes[1].machinePosition
        var initial_x_offset = tools[var.tool_num].offsets[0]
        var initial_y_offset = tools[var.tool_num].offsets[0]
        while true
        	if iterations = (var.num_x_pattern * var.num_y_pattern)
        		break
        	else
        		var x_i = mod(iterations, var.num_x_pattern)
        		var y_i = ((iterations-var.x_i)/var.num_x_pattern)
        		var x_pos = var.int_x + (var.x_i * var.x_pattern_space)
        		var y_pos = var.int_y + (var.y_i * var.y_pattern_space)
        		G10 P0 X{(-1 * var.x_pos)} Y{(-1 * var.y_pos)}
        		G1 X0 Y0 F6000
        		G1 X10 Y10 F600
        		continue
        G10 P0 X{(-1 * var.initial_x_offset)} Y{(-1 * var.initial_y_offset)}
        G1 X{var.int_x} Y{var.int_y} F6000
        I would be replacing the following lines with a call to run a build file:
        		G1 X0 Y0 F6000
        		G1 X10 Y10 F600
        Does this seem the sensible approach?
        • DocTruckerundefined DocTrucker referenced this topic
