rrf 3.4 beta update on ODROID sbc not possible
Beta Firmware
1.0k
    joeko @Nurgelrot
    @nurgelrot said in rrf 3.4 beta update on ODROID sbc not possible:
    @joeko I'm always following unstable on these so I went from 3.4 Beta somthing to Beta 6
    I did have an issue with the STM32 version not patching right away it complained about a dependency problem with duetsoftwareframework requiring <= reprapfirmware 3.4-b5-999. I removed all the duet packages and reinstalled latest unstable and it worked.
    My transfer pin is 67 on /dev/gpiochip0. But these are different on different versions of linux on the odroid C4. I remember that the ubuntu version shipped with the Odroid had it at pin 68 on chip1
    if any version is installed but nothing is running (or you have shut it down) try running:
    that will produce errors on screen if you have any sort of communication problem. ^D or ^C to exit.
    with armbian buster it works. i also did it with buster from hardkernel (meveric from forum) but this was not possible. now it works.
    sudo /opt/dsf/bin/DuetControlServer -ud
    give me
    Duet Control Server v3.4-b6
    Written by Christian Hammacher for Duet3D
    Licensed under the terms of the GNU Public License Version 3
    [info] Settings loaded
    [fatal] Another instance is already running. Stopping.
    i think that is ok because it is running
    thank you for your help
    @chrishamm
    it would make it easier when it offer the choice to modify the json for the tfr pin while the installation...much easier.
    undefined undefined 2 Replies Last reply 14 Dec 2021, 14:02 Reply Quote 0
      jay_s_uk @joeko
      @joeko I've updated our DSF on armbian instructions here
      https://teamgloomy.github.io/dsf_on_armbian.html
      undefined 1 Reply Last reply 14 Dec 2021, 15:36 Reply Quote 0
        Nurgelrot @joeko
        @joeko Yes a opportunity to override the default pin locations in the post-install script would be very handy. Also when you upgrade make sure you do not override your existing config.json. I've done that a couple times now getting annoying 🙂
          joeko @jay_s_uk
          @jay_s_uk said in rrf 3.4 beta update on ODROID sbc not possible:
          first i have used armbian buster with kernel 4.9. with that version i got boot problems. after change to buster with kernel 5.1 is this gone. i spend many hours to fix that.....
          do i realy set
          Then you have to add the following lines in /boot/armbianEnv.txt :
          extraargs=apparmor=1
          security=apparmor
          because here is it also possible without this.
          undefined 1 Reply Last reply 14 Dec 2021, 15:37 Reply Quote 0
            jay_s_uk @joeko
            @joeko if you want to use 3rd party plugins (and the duetpimanagement plugin), then yes, you need apparmor installed
            undefined 1 Reply Last reply 14 Dec 2021, 15:39 Reply Quote 0
              joeko @jay_s_uk
              installed yes but also ?
              security=apparmor
              i have it installed and running but i am not sure if this is needed. here is it running without
              undefined 1 Reply Last reply 14 Dec 2021, 15:41 Reply Quote 0
                jay_s_uk @joeko
                @joeko check with sudo aa-status, it'll tell you if its running.
                I had to add it on the armbian build i'm using though as I don't think its installed by default
                  joeko
                  apparmor module is loaded.
                  9 profiles are loaded.
                  9 profiles are in enforce mode.
                  /opt/dsf/plugins/EndstopsMonitor/**
                  /opt/dsf/plugins/InputShaping/**
                  /usr/bin/man
                  /usr/sbin/chronyd
                  /usr/sbin/haveged
                  man_filter
                  man_groff
                  nvidia_modprobe
                  nvidia_modprobe//kmod
                  0 profiles are in complain mode.
                  2 processes have profiles defined.
                  2 processes are in enforce mode.
                  /usr/sbin/chronyd (2569)
                  /usr/sbin/chronyd (2570)
                  0 processes are in complain mode.
                  0 processes are unconfined but have a profile defined.
                  looks good ?
                  undefined 1 Reply Last reply 14 Dec 2021, 15:42 Reply Quote 0
                    jay_s_uk @joeko
                    @joeko yep, looks good
                      joeko
                      and again, first while
                      sudo apt-get install duetsoftwareframework
                      i got errormessage that no connection to the board is possible (of course) and the sbc hangs and i had to cut the power, power on and modify the json and install new.
                      • undefined joeko marked this topic as a question 15 Dec 2021, 09:25
                      • undefined joeko has marked this topic as solved 15 Dec 2021, 09:26
                      28 out of 28
