    please help me blv setting
    129
    7.9k
      A Former User @oliof
      @oliof ok
      • oliofundefined
        oliof
        Don't forget to reslice with adjusted bed heat settings.
          @oliof yes but that has nothing to do with the quality of the piece if
          • oliofundefined
            oliof
            Let's solve one problem at a time. I you don't have proper adhesion, the rest of the print will always look bad no matter what. So that needs fixing first.
            A Former User? 3 Replies Last reply Reply Quote 0
              @oliof yes ok thank you
                @oliof
                I put new pei my ca does not adhere to 60 degrees
                  @oliof
                  as the aluminum plate is 10mm I have to heat for 30 minutes to 60 after it holds
                  • oliofundefined
                    oliof @A Former User
                    @sgk that's quite possible. If you let the print bed soak the heat, does the print adhere better? Show us a new photo.
                    To speed up printing, I suggest a simple 30mm cube in vase mode.
                      @oliof hello I tried to print more than once at 60d but the cubes end up taking off I must put in mini 80d.
                      I put a new pei sheet and the same ideas?
                      • oliofundefined
                        oliof
                        Since 80C is way above PLA glass transition temperature, your thermistor configuration may be wrong Please confirm what kind of thermistor you bought for this build.
                        Alternately, the thermistor ADC may need calibration.
                        you're saying you can print a vase mode cube with the bed at 80C -- can we get a photo of that?
                          @oliof
                          good morning, how are you doing? yes ok
                              @oliof the bed
                                A Former User @A Former User
                                @sgk IMG_20211215_095813_edit_63873446177232.jpg IMG_20211215_100009_edit_63813279327762.jpg IMG_20211215_095846_edit_63849951138173.jpg IMG_20211215_095839_edit_63860796521504.jpg
                                  @sgk and i have this error too
                                    • oliofundefined
                                      oliof
                                      still looks slightly hot on the bed surface. and you either have z banding from a z drive that's not straight, and/or banding like artifacts from a bed heater that's not PID tuned.
                                      • oliofundefined
                                        oliof
                                        (also it doesn't look like a single wall vase mode print)
                                          @oliof
                                          the bottom part it's just that I didn't turn on the fan
                                            @oliof how do i have to?
