    3 Independent Z Motors - Trouble with Autolevel
    Firmware installation
    519
    • engikeneerundefined
      engikeneer @austinious
      @austinious ^config.g and homing files
      i3 clone with a bunch of mods
      • austiniousundefined
        austinious
        I do not have the exact bed file here at work, the only difference is the X,Y's are different than what I am posting here. I can post the exact file later today. Just a reminder as you look through this, everything works EXCEPT autolevel. G30 will home the z axis, and the probe works as intended.
        Thanks!
        config.g
        <; Configuration file for Duet 3 (firmware version 3.3)
        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Dec 11 2021 09:34:44 GMT-0500 (Eastern Standard Time)
        M550 P"redacted" ; set printer name
        M551 P"nothingToSeeHere" ; set password
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P0.4 S1 ; physical drive 0.4 goes forwards
        M569 P0.5 S1 ; physical drive 0.5 goes forwards
        M584 X3 Y4 Z0:1:2 E5 ; set drive mapping
        M92 X160.00 Y160.00 Z8000.00 E409.00 ; set steps per mm
        M906 X800 Y1600 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X400 Y400 Z400 S0 ; set axis maxima
        M574 X1 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io1.in
        M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io2.in
        M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
        M558 P9 C"io4.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        M557 X50:350 Y50:350 S25 ; define mesh grid
        M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
        M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
        M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
        M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
        M106 P0 C"HotEnd" S0 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
        M950 F1 C"out9" Q500 ; create fan 1 on pin out9 and set its frequency
        M106 P1 C"Blower" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
        M563 P0 S"HotEnd" D0 H1 F0:1 ; define tool 0
        ; Custom settings
        M671 X215:7:424 Y-14:395:395 S0.5
        bed.g
        ; bed.g
        G29 ; probe the bed and enable compensation
        G30 P0 X130 Y0 Z-99999 ; probe near a leadscrew
        G30 P1 X0 Y280 Z-99999 ; probe near a leadscrew
        G30 P2 X240 Y280 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
        homeall.g
        ; homeall.g
        ; called to home all axes
        G91 ; relative positioning
        G1 H1 X-405 Y-405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
        G1 H2 X5 Y5 F6000 ; go back a few mm
        G1 H1 X-405 Y-405 F360 ; move slowly to X and Y axis endstops once more (second pass)
        G1 H1 Z-405 F360 ; move Z down stopping at the endstop
        G90 ; absolute positioning
        G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
        ;G91 ; relative positioning
        ;G90 ; absolute positioning
        homex.g
        ; homex.g
        ; called to home the X axis
        G1 H1 X-405 F1800 ; move quickly to X axis endstop and stop there (first pass)
        G1 H2 X5 F6000 ; go back a few mm
        G1 H1 X-405 F360 ; move slowly to X axis endstop once more (second pass)
        G1 H2 Z-5 F6000 ; lower Z again
        homey.g
        ; homey.g
        ; called to home the Y axis
        G1 H1 Y-405 F1800 ; move quickly to Y axis endstop and stop there (first pass)
        G1 H2 Y5 F6000 ; go back a few mm
        G1 H1 Y-405 F360 ; move slowly to Y axis endstop once more (second pass)
        homez.g - This is the file I have messed with the most with no luck.
        ; homez.g
        ; called to home the Z axis
        G1 H1 Z-405 F1800 ; move Z down until the endstop is triggered
          austinious
          One thing just hit me....I'm not sure the G30 P#'s in the bed.g correspond to the driver assignments in config.g, could it be that simple?
          engikeneerundefined 1 Reply Last reply Reply Quote 0
            @austinious both homeall and homez use a G1 H1 move to home so expects and endstop, not a G30 probing move. Thats the source of your error.
            Also, don't load your heightmap til after you levels the bed in bed.g. otherwise your levelling measurements will be based on a compensated bed and the two will fight each other
            The order of the probe points in the bed.g don't matter. I use six points in mine in different parts of the bed. What matters is the M671 coordinates are in the same order as your z drives
            austiniousundefined 1 Reply Last reply Reply Quote 0
              austinious @engikeneer
              @engikeneer Thanks, I'll work with that when I get home. I have to do some reading about height map it seems....no idea what it does.
                @austinious here's some bed time reading 😄
                https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                  @engikeneer 👍 🤠
                    austinious
                    Success! Sort of...
                    G28
                    Error: Some computed corrections exceed configured limit of 0.50mm: -0.599 -1.480 -2.324
                    Error: Height map file 0:/sys/heightmap.csv not found
                    I assume there is a setting to determine how much adjustment. But hey! Progress!
                    bed.g
                    ; bed.g - I added some lowering between probes due to the bed being off.
                    G30
                    G30 P0 X100 Y0 Z-99999 ; probe near rear leadscrew
                    G1 Z-10 F6000 ; lower Z again
                    G30 P1 X233 Y280 Z-99999 ; probe near left leadscrew
                    G30 P2 X0 Y280 Z-99999 S3 ; probe near right leadscrew and calibrate 3 motors
                    G29 S1 ; probe the bed and enable compensation
                    engikeneerundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                      @austinious yes, it's the S parameter in M671
                      https://duet3d.dozuki.com/Wiki/M671
                      You are then calling G29 S1 which loads the heightmap (with the default name). Looks like you don't have one made already so you need to create one with G29 or G29 S0
                        @engikeneer thanks! I found the M671 just as you replied....lol. Is there any reason to not increase that to 5mm?
                        I'm reading up on the heightmap and mesh, thanks for the links!
                          austinious @austinious
                          @engikeneer
                          G28
                          Leadscrew adjustments made: -0.591 -1.472 -2.315, points used 3, (mean, deviation) before (-1.019, 0.476) after (0.000, 0.000)
                          WooHoo!
                          Thanks for the help, I really appreciate it! I increased my M671 to 3mm, reading up on the mesh.
                            @austinious if your mechanism can take it, there's no real reason not to set it higher. Just bear in mind if uou did have two of the motors swapped, it could unlevel the bed by that much.
                            Might want to run G32 a few times as any slight errors in leadscrew positions etc mean it won't get it 100% first time. I only run it once before each print, but do it a few times if I mess with anything. Some more clever people use conditional gcode to repeatedly run it until the adjustments are below a threshold. One for if you're feeling fancy when it's yp and running - then you can show me how to do it 😛
                              @engikeneer
                              We'll see if I get that far. I usually stop tweaking when I get an acceptable print. I'm largely going to be making jigs and stamps for leatherworking, but I hope to make some neat stuff out of NylonX
                              • fcwiltundefined
                                fcwilt @austinious
                                @austinious said in 3 Independent Z Motors - Trouble with Autolevel:
                                bed.g
                                G30
                                Just FYI you should not need those G1 Z-10 commands - the three G30 P# commands should be able to execute one right after another. If they cannot you likely have a Z probe setting not quite right.
                                Also using conditional code it is possible to have the leveling process repeat as needed until a specified degree of "levelness" is obtained.
                                austiniousundefined 1 Reply Last reply Reply Quote 1
                                  austinious @fcwilt
                                  @fcwilt I remove those statements and turns out I had the XY's not lined up with the z drivers and now it works great The only problem I'm having now and I was going to spend tomorrow messing with it is that my first test print the z-axis everything leveled at home that's wonderful but then it was 5 mm away from the bed so I'm sure I've got it some adjustments to do
