    NodeDSF : Interface nodes for Node-Red (V1.1.11 - 06-10-23).
    Third-party software
    4.9k
    • MintyTreborundefined
      MintyTrebor @tekstyle
      @tekstyle There are written instructions on setting up node-red in the NodeDSF installation wiki pages, however this is primarily aimed at linux users. nodered.org has instructions on installing for windows, and general usage guidance.
      The NodeDSF wiki has detailed information on how each its nodes work, and includes example uses, and a video of setting up a flow to send an email on printer status change.
      If you want general node-red guidance nodered.org or youtube are your friends.
      Sorry - should of also added:
      In terms of getting your duet wifi board to work. All you need to know is your Duet Wifi's IP address (and user name and password if you have set one up). You do not have to configure anything on the duet side in order for NodeDSF to work.
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      tekstyleundefined 2 Replies Last reply Reply Quote 1
      • tekstyleundefined
        tekstyle @MintyTrebor
        @mintytrebor Thank you for the guidance! got a lot on my plate but will look into this in the near future.
        • tekstyleundefined
          @mintytrebor
          i am trying to follow your tutorial to setup email but I am getting this when I click on deploy after dragging the debug green box to the flow chart.
          "Your flow credentials file is encrypted using a system-generated key. If the system-generated key is lost for any reason, your credentials file will not be recoverable, you will have to delete it and re-enter your credentials. You should set your own key using the 'credentialSecret' option in your settings file. Node-RED will then re-encrypt your credentials file using your chosen key the next time you deploy a change."
          I am unsure where to go from here. I am using windows as my machine to run node-red.
          MintyTreborundefined 1 Reply Last reply Reply Quote 0
            @tekstyle I don't think that is an error msg just a warning - probably because you have put a user name and password into the send email node. Node-Red stores these types of variables (credentials, api keys, etc) in a separate secured file. The warning is telling you the default encryption of this file is tied to your machine, and not a "key" you have provided.
            From the Node-red Forum:
            "Open your Node-RED settings file (typically settings.js - but Node-RED logs the full path to the file it is using so you can check).
            Find the credentialSecret entry. Remove the // from the start of the line to uncomment it and then change the value (a-secret-key) to be whatever string you want to use to encrypt your credentials file. You will need to remember that value if you every want to move your flows to another machine (for example).
            Restart Node-RED. Done."
            Repo
            tekstyleundefined 1 Reply Last reply Reply Quote 0
            • tekstyleundefined
              @mintytrebor
              i found the settings.js. uncommented the // as shown below then restarted by closing command prompt. restarted and starting up the service again by typing "node-red" [enter]. went to http://127.0.0.1:1880/ on my web browser. I am stuck here where I don't know where to enter the credential "12345"
                // By default, credentials are encrypted in storage using a generated key. To
                  // specify your own secret, set the following property.
                  // If you want to disable encryption of credentials, set this property to false.
                  // Note: once you set this property, do not change it - doing so will prevent
                  // node-red from being able to decrypt your existing credentials and they will be
                  // lost.
                  credentialSecret: "12345",
              this is my start up log:
              16 Dec 02:22:22 - [info] Node-RED version: v1.3.5
              16 Dec 02:22:22 - [info] Node.js  version: v14.17.1
              16 Dec 02:22:22 - [info] Windows_NT 10.0.19041 x64 LE
              16 Dec 02:22:23 - [info] Loading palette nodes
              16 Dec 02:22:25 - [info] +-----------------------------------------------------
              16 Dec 02:22:25 - [info] | uibuilder initialised:
              16 Dec 02:22:25 - [info] |   Using Node-RED's webserver
              16 Dec 02:22:25 - [info] |   root folder: \Users\dell\.node-red\uibuilder
              16 Dec 02:22:25 - [info] |   version . .: 3.3.1
              16 Dec 02:22:25 - [info] |   packages . : socket.io
              16 Dec 02:22:25 - [info] Settings file  : C:\Users\dell\.node-red\settings.js
              16 Dec 02:22:25 - [info] Context store  : 'default' [module=memory]
              16 Dec 02:22:25 - [info] User directory : \Users\dell\.node-red
              16 Dec 02:22:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
              16 Dec 02:22:25 - [info] Flows file     : \Users\dell\.node-red\flows_DESKTOP-PI7LP0S.json
              16 Dec 02:22:25 - [info] Server now running at http://127.0.0.1:1880/
              16 Dec 02:22:25 - [info] Waiting for missing types to be registered:
              16 Dec 02:22:25 - [info]  - ui_group
              16 Dec 02:22:25 - [info]  - ui_tab
              16 Dec 02:22:25 - [info]  - ui_template
              16 Dec 02:22:25 - [info]  - ui_button
              16 Dec 02:22:25 - [info]  - ui_toast
              16 Dec 02:22:25 - [info]  - ui_gauge
              16 Dec 02:22:25 - [info]  - ui_text
                @tekstyle Sorry not following you.
                You have already specified your credentialSecret as "12345" in settings.js. You should not need to enter it anywhere else.
                If you want to change it, then change "12345" in settings.js.
                Repo
                • tekstyleundefined
                  @mintytrebor
                  i don't think node-red is communicating with DUET when following the email tutorial (https://www.youtube.com/watch?v=cn_XXR3FJ00). link text
                  here is what my debug looks like. I am now doing this on a rasp pi4 as it wasn't working on my windows 10 machine. I also followed the instructions at link text to install node-red and NODE DSF on it.
                  dsfModel : msg : Object
                  object
                  topic: "dsfModel"
                  payload: null
                  dsf: object
                  monitorMode: "DSF"
                  monitorError: "No server defined or cannot connect to DSF. Checking again in 10 seconds"
                  _msgid: "adf0ddc76a5d1eae"
                    @tekstyle Are you using a standalone duet control board, or do you have it connected to an SBC using a ribbon/spi cable?
                    If you are using a standalone control board you need to set the type to Duet in the connection properties of the monitor node
                    Then
                    Repo
                    tekstyleundefined 2 Replies Last reply Reply Quote 0
                    • tekstyleundefined
                      @mintytrebor
                      i am using a duet2wifi with a rasp pi4 for node-red.
                      • tekstyleundefined
                        @mintytrebor
                        i changed the type to DUET. i also changed my credentialSecret code to false. it seems to be getting something under debug window on the right now. but following your example, i can not see the OM for the command M117 "xxx". if you go to line 141, that is were STATE starts and I do not see the field for displaymessage = "xxx"
                        12/20/2021, 9:32:20 AM
                        msg : string[57]
                        "Error loading flows: Error: Failed to decrypt credentials"
                        12/20/2021, 9:32:20 AMnode: b881bf70e5d5eca0
                        object
                        topic: "dsfModel"
                        payload: object
                        fullModel: object
                        boards: array[1]
                        0: object
                        directories: object
                        empty
                        fans: array[3]
                        0: object
                        actualValue: 0
                        requestedValue: 0
                        rpm: -1
                        1: object
                        actualValue: 0
                        requestedValue: 1
                        rpm: -1
                        2: object
                        actualValue: 0
                        requestedValue: 0
                        rpm: -1
                        global: object
                        ext1: 1
                        SensorTriggered: 2
                        heat: object
                        heaters: array[3]
                        0: object
                        active: -273
                        current: 15.1
                        standby: 0
                        state: "active"
                        1: object
                        active: 0
                        current: 14.2
                        standby: 160
                        state: "active"
                        2: object
                        active: 0
                        current: -273.1
                        standby: 0
                        state: "off"
                        inputs: array[12]
                        [0 … 9]
                        0: object
                        feedRate: 50
                        lineNumber: 69
                        state: "idle"
                        1: object
                        feedRate: 50
                        lineNumber: 0
                        state: "idle"
                        2: object
                        3: object
                        4: object
                        5: object
                        6: object
                        7: object
                        8: null
                        9: object
                        [10 … 11]
                        job: object
                        build: null
                        duration: null
                        filePosition: 0
                        layer: null
                        layerTime: null
                        pauseDuration: null
                        rawExtrusion: null
                        timesLeft: object
                        warmUpDuration: null
                        limits: object
                        empty
                        move: object
                        axes: array[3]
                        0: object
                        machinePosition: 0
                        userPosition: 0
                        1: object
                        2: object
                        currentMove: object
                        extruders: array[1]
                        0: object
                        virtualEPos: -3
                        network: object
                        empty
                        scanner: object
                        empty
                        sensors: object
                        analog: array[3]
                        0: object
                        lastReading: 15.1
                        1: object
                        2: object
                        endstops: array[3]
                        0: object
                        triggered: false
                        1: object
                        2: object
                        filamentMonitors: array[1]
                        0: object
                        status: "ok"
                        gpIn: array[2]
                        0: null
                        1: object
                        value: 0
                        probes: array[1]
                        0: object
                        value: array[1]
                        seqs: object
                        boards: 0
                        directories: 0
                        fans: 6
                        global: 2
                        heat: 14
                        inputs: 29753
                        job: 39
                        move: 82
                        network: 7
                        reply: 168
                        scanner: 1
                        sensors: 36
                        spindles: 0
                        state: 45
                        tools: 13
                        volChanges: array[2]
                        0: 77
                        1: 0
                        volumes: 64929
                        spindles: array[4]
                        0: object
                        current: 0
                        state: "unconfigured"
                        1: object
                        2: object
                        3: object
                        state: object
                        messageBox: object
                        title: null
                        message: null
                        atxPower: true
                        currentTool: 0
                        gpOut: array[0]
                        laserPwm: null
                        msUpTime: 634
                        nextTool: 0
                        previousTool: -1
                        status: "idle"
                        time: "2021-12-20T09:32:32"
                        upTime: 476541
                        tools: array[2]
                        0: object
                        active: array[1]
                        0: 0
                        standby: array[1]
                        state: "active"
                        1: object
                        volumes: array[2]
                        0: object
                        empty
                        1: object
                        patchModel: null
                        prevModel: null
                        dsf: object
                        monitorMode: "Duet"
                        _msgid: "7916fbc1145cf6f1"
                          @tekstyle ""Error loading flows: Error: Failed to decrypt credentials" is a node-red error (not from NodeDSF) because you have changed your credentialSecret code configuration in your setting.js.
                          The help text for credentialSecret states changing it will prevent node-red from decrypting existing credentials:
                           // lost.
                           //credentialSecret: "a-secret-key",
                          Which means any ip addresses, usernames, passwords (etc) you configured in your nodes before you changed credentailSecret are no longer accessible to node-red.
                          I suggest you Reset the settings.js beck to what it was before you changed it.
                          The default setting is just commented out eg:
                          Repo
                          • tekstyleundefined
                            @mintytrebor
                            i changed it back to credentialsecret: "a-secret-key" with it commented out. restarted. this is my start log
                            Starting as a systemd service.
                            20 Dec 20:55:41 - [info]
                            Welcome to Node-RED
                            20 Dec 20:55:41 - [info] Node-RED version: v2.1.4
                            20 Dec 20:55:41 - [info] Node.js  version: v14.18.2
                            20 Dec 20:55:41 - [info] Linux 5.10.63-v7l+ arm LE
                            20 Dec 20:55:42 - [info] Loading palette nodes
                            20 Dec 20:55:44 - [info] Dashboard version 3.1.2 started at /ui
                            20 Dec 20:55:44 - [info] Settings file  : /home/pi/.node-red/settings.js
                            20 Dec 20:55:44 - [info] Context store  : 'storeInFile' [module=localfilesystem]
                            20 Dec 20:55:44 - [info] Context store  : 'default' [module=memory]
                            20 Dec 20:55:44 - [info] User directory : /home/pi/.node-red
                            20 Dec 20:55:44 - [warn] Projects disabled : editorTheme.projects.enabled=false
                            20 Dec 20:55:44 - [info] Flows file     : /home/pi/.node-red/flows.json
                            20 Dec 20:55:44 - [info] Server now running at http://127.0.0.1:1880/
                            your credentials.
                            20 Dec 20:55:44 - [warn] Error loading credentials: SyntaxError: Unexpected token � in JSON at position 1
                            20 Dec 20:55:44 - [warn] Error loading flows: Error: Failed to decrypt credentials
                            20 Dec 20:55:44 - [info] +-----------------------------------------------------
                            20 Dec 20:55:44 - [info] | uibuilder v4.1.4 initialised
                            20 Dec 20:55:44 - [info] | root folder: /home/pi/.node-red/uibuilder
                            20 Dec 20:55:44 - [info] | Using Node-RED's webserver at:
                            20 Dec 20:55:44 - [info] |   http://127.0.1.1:1880/ or http://localhost:1880/
                            20 Dec 20:55:44 - [info] | Installed packages:
                            20 Dec 20:55:44 - [info] |   jquery, socket.io
                            20 Dec 20:55:44 - [info] Starting flows
                            20 Dec 20:55:44 - [info] Started flows
                            settings.js below
                                flowFile: 'flows.json',
                                /** By default, credentials are encrypted in storage using a generated key.$
                                 * specify your own secret, set the following property.
                                 * If you want to disable encryption of credentials, set this property to f$
                                 * Note: once you set this property, do not change it - doing so will preve$
                                 * node-red from being able to decrypt your existing credentials and they w$
                                 * lost.
                            //    credentialSecret: false,
                            //    credentialSecret: "a-secret-key",
                            for every change made, how do I apply those changes so node-red knows to reset itself or something to decrypt exisiting credentials properly? right now , I just do node-red-stop followed by node-red-start in terminal.
                              @tekstyle Node-red has probably generated a new key automatically now..
                              Look for a file called something like "flows_#####cred.json" in .node-red folder (the same folder as settings.js) and rename it to "flows#####_cred.old". Then restart node red.
                              It will probably clear all of the node settings you have already entered, but it should clear the error.
                              You will have to re-enter the IP and set the mode to Duet in the monitor node of your flow.
                              Repo
                              • tekstyleundefined
                                @mintytrebor
                                renamed the flow_cred.json to flow_cred.old.
                                stop service and start up again. then deleted all old flow and made new ones. it's weird, i can see the objective models in the debug (eg, it knows I have 2 tools configured) but it just doesn't do anything. it never updates (eg, T0 is set to "off" but it always shows "standby"). Also, the debug would just keep displaying new information even before I press the red deploy button
                                start log below:
                                pi@raspberrypi:~/.node-red $ node-red
                                20 Dec 21:33:24 - [info]
                                Welcome to Node-RED
                                20 Dec 21:33:24 - [info] Node-RED version: v2.1.4
                                20 Dec 21:33:24 - [info] Node.js  version: v14.18.2
                                20 Dec 21:33:24 - [info] Linux 5.10.63-v7l+ arm LE
                                20 Dec 21:33:25 - [info] Loading palette nodes
                                20 Dec 21:33:27 - [info] Dashboard version 3.1.2 started at /ui
                                20 Dec 21:33:27 - [info] Settings file  : /home/pi/.node-red/settings.js
                                20 Dec 21:33:27 - [info] Context store  : 'storeInFile' [module=localfilesystem]
                                20 Dec 21:33:27 - [info] Context store  : 'default' [module=memory]
                                20 Dec 21:33:27 - [info] User directory : /home/pi/.node-red
                                20 Dec 21:33:27 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                20 Dec 21:33:27 - [info] Flows file     : /home/pi/.node-red/flows.json
                                20 Dec 21:33:27 - [info] Creating new flow file
                                20 Dec 21:33:27 - [info] +-----------------------------------------------------
                                20 Dec 21:33:27 - [info] | uibuilder v4.1.4 initialised
                                20 Dec 21:33:27 - [info] | root folder: /home/pi/.node-red/uibuilder
                                20 Dec 21:33:27 - [info] | Using Node-RED's webserver at:
                                20 Dec 21:33:27 - [info] |   http://127.0.1.1:1880/ or http://localhost:1880/
                                20 Dec 21:33:27 - [info] | Installed packages:
                                20 Dec 21:33:27 - [info] |   jquery, socket.io
                                20 Dec 21:33:27 - [info] Server now running at http://127.0.0.1:1880/
                                20 Dec 21:33:27 - [info] Starting flows
                                20 Dec 21:33:27 - [info] Started flows
                                20 Dec 21:34:43 - [info] Stopping flows
                                20 Dec 21:34:43 - [info] Stopped flows
                                20 Dec 21:34:43 - [info] Starting flows
                                20 Dec 21:34:43 - [info] Started flows
                                  @tekstyle The log shows node-red is working without any credential issues now.
                                  I suggest you go into the monitor node and click the pencil edit button next to the ip address
                                  then delete the config
                                  repeat deletion for every item in the list
                                  Then delete the flow and do a full deploy
                                  Go to the connection test example flow from my repo here, then click copy raw contents
                                  In a new flow click the menu and select import
                                  paste the copied raw data into the box, select new flow, and click import
                                  this will create a new "Connection Example" flow
                                  Double click the monitor node (named Duet2 Board), and click the pencil button and set your duet board IP and mode to Duet
                                  Click update, then done, and then do a full deploy.
                                  Open the debug side window
                                  The use the Start & Stop nodes to control the monitor, the output can be seen in the side debug window. It should look something like this:
                                  Repo
                                  • tekstyleundefined
                                    @mintytrebor
                                    i got that far. it seems like it is working. I was able to see target active temp change and updated .
                                    when i do a M117 "hello" on my console in DWC. where do I see that in the debug window in node-red.
                                      @tekstyle Great!
                                      First check you are on the latest release (v1.1.4) through the palette manager, I found a bug whilst answering your query, so please make sure you are updated before going any further. (It can sometimes take a while before updates show in palette manager)
                                      Then add an DSF Event node plus a debug node and configure it like this:
                                      Deploy, start the monitor and send a M117 message in DWC and it should appear in the debug window (like the picture above).
                                      Repo
                                      • tekstyleundefined
                                        @mintytrebor
                                        i finally got this to work. that last post was a great help! thank you! now on to setting up email notification.
                                          @tekstyle Great! I'm glad you got it working. It's worthwhile spending some time learning node-red, it's really powerful and easy to use, and there are loads of nodes available for interfacing with other IOT stuff etc. I run all my lights, home automation, & printers with it.
                                          Repo
                                          • tekstyleundefined
                                            @mintytrebor so i used an email node with app password to get it to work. i just want it to display a message with m117 right now. however, it sends me the whole payload of dsf model.
                                            i copied the path "payload.fullModel.state.displayMessage" . i just copied and paste. but it still keeps sending me the whole thing. anyway to zero it down to just what i request of it on the debug node?
