    Changes to config.g ignored when printing.
    Using Duet Controllers
    917
    • mjimeygundefined
      mjimeyg
      I have a CoreXY printer with a BMG extruder and V6 hotend. I also have a BLTouch and three z-axis motors.
      Originally it was controlled by a 6HC connected to a Raspberry Pi using the latest available firmware.
      The first time I realised this issue was when setting up the bed levelling where the BLTouch probes nears the z-axis motors and compensates. No matter what I changed, it refused to move to the points I inputted. The config files showed my new settings but when the command was run, the probe was nowhere near those points.
      I decided to remove the Raspberry Pi. This seemed to work.
      This was a few months ago.
      Present Day:
      I am trying to calibrate the z-axis offset. No matter what I do (turn the printer off, click the emergency button), it refuses to use the new value for the z-offset.
      I run the proceedure for getting the z-offset, I input it into the config.g and then I test it by re-homing. Sometimes I'll power off and then power on. But it ignores the values stored in the config.g.
      Is there a command I am missing to save these changes to the board? A button to press?
      I haven't had this issue before with the Duet 2 or when I first got the Duet 3 6HC.
      Many Thanks.
        dc42 administrators @mjimeyg
        @mjimeyg config.g is normally only read at startup. Therefore, after you make a change to config.g, you need to either reset the board (e.g. use the Emergency Stop button), or run M98 P"config.g" for the changes to take effect. This has always been the case.
        mjimeygundefined 1 Reply Last reply Reply Quote 0
        • mjimeygundefined
          mjimeyg @dc42
          @dc42 Would powering off and on achieve the same thing?
          Based on that then something else is wrong. Do you know what it could be?
            deckingman @mjimeyg
            @mjimeyg said in Changes to config.g ignored when printing.:
            Yes, cycling the power will run config.g again. If you use config-override.g and have M501 in your config.g file, then it will also run config-override.g. So anything that is in config-override.g will do as it says and override the values that are in config.g. Do you have anything in config-override.g ?
            mjimeygundefined 2 Replies Last reply Reply Quote 0
            • mjimeygundefined
              mjimeyg @deckingman
              @deckingman Yes, I've included it below.
              ; config-override.g file generated in response to M500 at 2021-11-28 10:26
              ; Heater model parameters
              M307 H0 R0.488 C616.200:616.200 D2.60 S1.00 V23.9 B0
              M307 H1 R1.258 C207.600:207.600 D11.70 S1.00 V23.2 B0
              ; Workplace coordinates
              G10 L2 P1 X0.00 Y0.00 Z0.00
              G10 L2 P2 X0.00 Y0.00 Z0.00
              G10 L2 P3 X0.00 Y0.00 Z0.00
              G10 L2 P4 X0.00 Y0.00 Z0.00
              G10 L2 P5 X0.00 Y0.00 Z0.00
              G10 L2 P6 X0.00 Y0.00 Z0.00
              G10 L2 P7 X0.00 Y0.00 Z0.00
              G10 L2 P8 X0.00 Y0.00 Z0.00
              G10 L2 P9 X0.00 Y0.00 Z0.00
              Could the G10 commands be overriding it? I didn't add them and assume they were generated by either the firmware or the reprap config tool.
              • mjimeygundefined
                mjimeyg @deckingman
                @deckingman I commented out those G10 lines but it didn't affect anything.
                  deckingman @mjimeyg
                  @mjimeyg I guess you'd better tell us what procedure and commands you are using to set the z offset. It would probably help if you post your entire config.g and any homing files that use the z offset (i.e. homez.g and homeall.g).
                  • mjimeygundefined
                    mjimeyg @deckingman
                    @deckingman I use the following guide for z-offset calibration: BLTouch on Duet WiFi – Configuration and usage
                    My files:
                    config.g:
                    ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 15:44:47 GMT+0000 (Greenwich Mean Time)
                    G90                                                   ; send absolute coordinates...
                    M83                                                   ; ...but relative extruder moves
                    M550 P"RatRig"                                          ; set printer name
                    M667 S1                                               ; select CoreXY mode
                    M552 P0.0.0.0 S1                                        ; enable network and acquire dynamic address via DHCP
                    M586 P0 S1                                   ; enable HTTP
                    M586 P1 S1                                   ; disable FTP
                    M586 P2 S1                                   ; disable Telnet
                    M569 P0.0 S1                                          ; physical drive 0.0 goes forwards
                    M569 P0.1 S1                                          ; physical drive 0.1 goes forwards
                    M569 P0.2 S0                                          ; physical drive 0.2 goes forwards ; Left
                    M569 P0.3 S0					                      ; physical drive 0.3 goes forwards ; Rear
                    M569 P0.4 S0                                          ; physical drive 0.4 goes forwards ; Right
                    M569 P0.5 S1					                      ; physical drive 0.5 goes backwards
                    M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5                      ; set drive mapping (Left:0.2 - Rear:0.3 - Right:0.4)
                    M671 X-30:230:25 Y120:556:120 S15 	          		  ; Kinematic bed ball locations - front left, front right and rear center
                    M350 X16 Y16 Z16 E16 I1                               ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z400.00 E409.00                     ; set steps per mm
                    M566 X900.00 Y900.00 Z12.00 E120.00                   ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z1000.00 E1200.00              ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 E250.00                   ; set accelerations (mm/s^2)
                    M906 X800 Y800 Z800 E1000 I30                         ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                               ; Set idle timeout
                    M208 X0 Y0 Z0 S1                                      ; set axis minima
                    M208 X500 Y500 Z500 S0                                ; set axis maxima
                    M574 X1 S3                                              ; configure sensorless endstop for low end on X
                    M574 Y1 S3                                              ; configure sensorless endstop for low end on Y
                    M574 Z1 S3                                              ; configure sensorless endstop for low end on Z
                    M950 S0 C"io7.out"                                    ; create servo pin 0 for BLTouch
                    M558 P9 C"io7.in" H5 F120 T6000                       ; set Z probe type to bltouch and the dive height + speeds
                    ;M558 H30                                              ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                    G31 P500 X-29 Y-12 Z4.53; set Z probe trigger value, offset and trigger height
                    M557 X15:470 Y15:470 S40                              ; define mesh grid
                    M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950   ; configure sensor 0 as thermistor on pin temp0
                    M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
                    M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
                    M307 H0 A436.5 C459.5 D4.1 S1.00 V0 B0                ; disable bang-bang mode for the bed heater and set PWM limit
                    M140 H0                                               ; map heated bed to heater 0
                    M308 S1 P"temp2" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin temp2
                    M950 H1 C"out1" T1                                      ; create nozzle heater output on out1 and map it to sensor 1
                    M307 H1 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
                    M143 H1 S280                                            ; set temperature limit for heater 1 to 280C
                    M950 F0 C"out7" Q500                                    ; create fan 0 on pin out7 and set its frequency
                    M106 P0 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"out8" Q500                                    ; create fan 1 on pin out8 and set its frequency
                    M106 P1 S1 H1 T45                                       ; set fan 1 value. Thermostatic control is turned on
                    M563 P0 D0 H1 F0                                        ; define tool 0
                    G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
                    G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
        ; load saved parameters from non-volatile memory
                    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"    ; set voltage thresholds and actions to run on power loss
                    T0                                                    ; select first tool
                    M501
                    config-override.g:
                    ;G10 L2 P1 X0.00 Y0.00 Z0.00
                    ;G10 L2 P2 X0.00 Y0.00 Z0.00
                    ;G10 L2 P3 X0.00 Y0.00 Z0.00
                    ;G10 L2 P4 X0.00 Y0.00 Z0.00
                    ;G10 L2 P5 X0.00 Y0.00 Z0.00
                    ;G10 L2 P6 X0.00 Y0.00 Z0.00
                    ;G10 L2 P7 X0.00 Y0.00 Z0.00
                    ;G10 L2 P8 X0.00 Y0.00 Z0.00
                    ;G10 L2 P9 X0.00 Y0.00 Z0.00
                    bed.g:
                    ; bed.g
                    ;G28 ; home
                    M558 F160
                    G30 P0 X10 Y115 Z-99999 ; probe near left leadscrew
                    G30 P1 X240 Y465 Z-99999 ; probe near rear leadscrew
                    G30 P2 X450 Y115 Z-99999 S3 ; probe near right leadscrew and calibrate 3 motors
                    G1 X0 Y0 F20000
                    G29 S1
                    homeall.g:
                    ; homeall.g
                    ; called to home all axes
                    M400
                    M913 X70 Y70 ; drop motor current to 70%
                    M400 G91; relative positioning
                    G1 H2 Z20 F12000 ; lift Z relative to current position
                    G1 H1 X-500.5 F10000 ; move quickly to X axis endstop and stop there (first pass)
                    G1 H2 X5 F12000 ; go back a few mm
                    G1 H1 X-500.5 F7000 ; move slowly to X axis endstop once more (second pass)
                    ;G1 H2 Z-10 F6000 ; lower Z again
                    G90 ; absolute positioning
                    M400
                    M913 X100 Y100 ; return current to 100%
                    M400
                    M400
                    ;G1 H2 Z10 F12000 ; lift Z relative to current position
                    G1 H1 Y-500.5 F10000 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 H2 Y5 F12000 ; go back a few mm
                    G1 H1 Y-500.5 F7000 ; move slowly to Y axis endstop once more (second pass)
                    ;G1 H2 Z-20 F6000 ; lower Z again
                    M400
                    M400
                    ;G1 H2 Z20 F12000 ; lift Z relative to current position
                    G1 X250 Y250 F6000 ; Move probe to middle of bed
                    M558 F500 ; Set the probing speed
                    G30 ; Do a single probe to home our Z axis
                    M558 F50 ; Set a slower probing speed
                    G30
                    G1 H2 Z20 F6000 ; lower Z again
                    G32 ; Run 3-point bed calibration defined in bed.g
                    ;G1 H1 Z-275 F360        ; move Z down stopping at the endstop
                    ;G90                     ; absolute positioning
                    ;G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                    ;G91                    ; relative positioning
                    ;G1 Z5 F100             ; lift Z relative to current position
                    Those are my files.
                      Which offset exactly are you changing?
                      • mjimeygundefined
                        mjimeyg @Phaedrux
                        @phaedrux I am changing the config.g file, line 50, the z argument of the G31 command:
                        I would like to reiterate two things:
                        1- This is board was working with this firmware and has stopped accepting the changes recently. I have not made any hardware or firmware changes.
                        2- The calibration process works perfectly. I can perform it as listed in the provided webpage and get a good offset. The issue lies in that the value is ignored once the board is reset. So, if I perform all the calibration settings and set the G31 command manually, the bed will level. It is how I am still printing. But if I turn the printer off or save the changes to the config.g file, then once the board has reset itself, it ignores the value saved and listed... by aproximately 0.3.
                        Finally, this is not an issue limited to the G31 command. Any changes are ignored to any command.
                          After you try changing it can you send G31 in the console and report back what it says?
                          Can you also send M98 P"config.g" in the console and report back any errors.
                          • mjimeygundefined
                            mjimeyg @Phaedrux
                            @phaedrux After changing the G31 z value from 4.31 to 4.5 in the config.g file and then going through the reset, the response from the G31 command is:
                            Z probe 0: current reading 0, threshold 500, trigger height 4.500, offsets X-29.0 Y-12.0
                            The response from the M98 P"config.g" command is:
                            HTTP is enabled on port 80
                            FTP is enabled on port 21
                            TELNET is enabled on port 23
                            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 461C
                            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 325C
                              Just to be sure, the config.g file you're editing is located in the system tab in DWC?
                              Can you check the config.g file on the SD card in a computer to make sure it's not write protected or something?
                              If you set the G31 offset manually in the console with G31 Z4.31 and then send G31 again, does it show the new value?
                              • mjimeygundefined
                                mjimeyg @Phaedrux
                                @phaedrux I am using the DWC.
                                The SD card is not write protected.
                                The G31 command shows the new value after is set with the G31 command.
                                  If you make any other changes to the config.g are they reflected at startup?
                                  • mjimeygundefined
                                    mjimeyg @Phaedrux
                                    @phaedrux I changed the M557 to:
                                    M557 X15:200 Y15:200 S40
                                    I then ran a G29 and it did probe only a quarter of the bed as per the changed command in the config.g.
                                    I also remembered that a few weeks ago Thermistor 1 out stopped working and I had to change the hotend thermistor to Thermistor 2. This is long after the issues with the config,g but it might be worth mentioning.
                                      deckingman @mjimeyg
                                      Just to recap. You changed the G31 offset from 4.31 to 4.5. Then you reset the board and sent G31 without any parameters and got back the resultant offset as being 4.5 yes? If that is the case, then the changes are not being ignored as per your thread title. I don't use a BLTouch so I'm not best qualified to comment but are you sure it's working properly and consistently? It just seems that the board and firmware are behaving as expected so the issue might be something else.
