    I think I found a bug
    Beta Firmware
    547
    • RKS7204undefined
      RKS7204
      My printer is a delta printer
      Board: Duet 2 Ethernet (2Ethernet)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta7 (2021-12-16)
      I have to run M999 after startup. If I don't do that I get errors, and the head won't move.
      23/12/2021 23:02:49 G28
      23/12/2021 23:02:38 Connection established
      23/12/2021 23:02:31 Connection interrupted, attempting to reconnect...
      HTTP request timed out
      23/12/2021 23:02:22 M999
      23/12/2021 23:02:14 Error: G0/G1: insufficient axes homed
      23/12/2021 23:02:13 Warning: Driver 1 warning: phase A may be disconnected, phase B may be disconnected
      Warning: Driver 2 warning: phase A may be disconnected, phase B may be disconnected
      Warning: Driver 0 warning: phase A may be disconnected, phase B may be disconnected
      23/12/2021 23:01:45 G28
      Steve
      Phaedruxundefined natthapol.vundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @RKS7204
        @rks7204 said in I think I found a bug:
        Are you certain your motors don't have a bad crimp?
        Can you send M122 and M98 P"config.g" and post the results?
        Can you also share your config.g and homedelta.g?
        RKS7204undefined 1 Reply Last reply Reply Quote 0
        • RKS7204undefined
          RKS7204 @Phaedrux
          @Phaedrux
          After sending M999 all motors are moving. If I don't send M999 I get the "disconnected" error. I believe that if it is a bad crimp, sending M999 wouldn't solve it.
          23/12/2021 23:14:33 M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta7 (2021-12-16 12:22:11) running on Duet Ethernet 1.02 or later
          Board ID: 08DGM-95BNL-MGPSN-6JKFJ-3S86L-12XRX
          Used output buffers: 3 of 24 (19 max)
          Static ram: 23804
          Dynamic ram: 68812 of which 0 recycled
          Never used RAM 19344, free system stack 136 words
          Tasks: NETWORK(ready,26.3%,230) HEAT(notifyWait,0.0%,330) Move(notifyWait,0.0%,305) MAIN(running,73.6%,440) IDLE(ready,0.1%,30), total 100.0%
          Owned mutexes:
          Last reset 00:12:10 ago, cause: software
          Last software reset at 2021-12-23 23:02, reason: User, GCodes spinning, available RAM 19320, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 22.6, current 24.9, max 25.2
          Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Events: 0 queued, 0 completed
          Driver 0: pos 81255, standstill, SG min 0
          Driver 1: pos 80409, standstill, SG min 15
          Driver 2: pos 80836, standstill, SG min 49
          Driver 3: pos 0, standstill, SG min n/a
          Driver 4: pos 0, standstill, SG min n/a
          Driver 5: pos 0
          Driver 6: pos 0
          Driver 7: pos 0
          Driver 8: pos 0
          Driver 9: pos 0
          Driver 10: pos 0
          Driver 11: pos 0
          Date/time: 2021-12-23 23:14:31
          Slowest loop: 13.25ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.0ms, write time 0.0ms, max retries 0
          DMs created 83, segments created 5, maxWait 22861ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty
          === Network ===
          Slowest loop: 17.56ms; fastest: 0.02ms
          HTTP sessions: 1 of 8
          Interface state active, link 100Mbps full duplex
          TripodMaker
          Status
          Idle
          Mode: FFF
          Tool Position
          X
          0.0
          Y
          0.0
          Z
          500.60
          Extruder Drives
          Drive 0
          0.0
          Speeds
          Requested Speed
          0 mm/s
          Top Speed
          0 mm/s
          Sensors
          Vin
          24.4 V
          MCU Temperature
          24.8 °C
          Z-Probe
          542
          Tools
          Extra
          Control Heaters
          Tool Heater Current Active Standby Tool 0
          T0 - Load Filament Heater 1
          active 18.5 °C
          Bed Heater 0
          off 18.1 °C
          Temperature Chart
          23/12/2021 23:15:50 M98 P"config.g"
          HTTP is enabled on port 80
          FTP is enabled on port 21
          TELNET is disabled
          Config.g :
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Dec 21 2021 21:14:01 GMT+0100 (Midden-Europese standaardtijd)
          M550 P"TripodMaker" ; set printer name
          M665 R167.220 L350.3926 B160 H505.578 X0.345 Y0.210 Z0; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0.38 Y-0.02 Z-0.36 ; Put your endstop adjustments here, or let auto calibration find them
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S0 ; disable Telnet
          M92 X100.00 Y100.00 Z100.00 E166.00 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
          M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
          M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
          M558 P1 C"!zprobe.in" H5 F120 T6000 R1 A5 X0 Y0 Z0 ; set Z probe type to unmodulated and the dive height + speeds
          G31 P800 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height
          M557 R145 S20 ; define mesh grid
          M307 H0 R0.228 K0.256:0.000 D3.08 E1.35 S1.00 B0 ; enable PID mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          M950 F0 C"fan0" Q250 ; create fan 0 on pin fan0 and set its frequency
          M950 F1 C"fan1" Q250 ; create fan 1 on pin fan1 and set its frequency
          ;M950 F2 C"fan2" Q250 ; create fan 2 on pin fan2 and set its frequency
          ;M106 P2 S2 H100:101:102 T44:65 L0.3 ; set fan 2 value. Thermostatic control is turned on
          M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
          M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as on-chip MCU temperature sensor
          M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 H2:3 L0.15 X1 B0.3 T40:70 ; set fan 2 value
          G10 P0 X9 Y0 Z0 ; set tool 0 axis offsets
          T0 S0 ; select first tool
          M912 P0 S3.2 ; calibrate MCU temp
          HomeDelta.g :
          ; homedelta.g
          ; called to home all towers on a delta printer
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Dec 21 2021 22:18:44 GMT+0100 (Midden-Europese standaardtijd)
          G91 ; relative positioning
          G1 H1 X805 Y805 Z805 F1800 ; move all towers to the high end stopping at the endstops (first pass)
          G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
          G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
          G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
          G90 ; absolute positioning
          G1 X0 Y0 F6000 ; move X+Y to the centre
          Steve
            Ok so you're resetting the printer and getting these errors. I think that's actually normal. Or am I not understanding again?
            • RKS7204undefined
              RKS7204 @Phaedrux
              @phaedrux
              When i power on the printer. Ik get these errors. And the motors don't move. After I reset the printer with M999 the errors are gone. I can start printing.
              Steve
              • rjenkinsgbundefined
                rjenkinsgb
                Out of curiosity, what happens if you add
                G4 S5
                (a five second delay) near the top of your config, between the general and network sections?
                Robert J.
                Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                • RKS7204undefined
                  RKS7204 @rjenkinsgb
                  @rjenkinsgb
                  That doesn't make a difference
                  Steve
                    rjenkinsgb
                    OK. Is the 24V (or 12v) power permanently on, or controlled somehow by the Duet board?
                    Robert J.
                    • RKS7204undefined
                      RKS7204 @rjenkinsgb
                      @rjenkinsgb
                      The power is not controlled by the duet bord.
                      I use a physical switch on the printer.
                      When the printer is off, there is no power suplied to the board.
                      Steve
                      • natthapol.vundefined
                        natthapol.v @RKS7204
                        @rks7204 looks like a similar issue here.
                        https://forum.duet3d.com/topic/26261/3-4-0beta6-home-limit-switch-bug
                        It happened to me on the new 3.4 firmware as well. But only if I set acceleration to a high value (>8000-10000mm/min)
                        Funny is, this number works on 3.3 without Phase disconnected warning.
                        • RKS7204undefined
                          RKS7204 @RKS7204
                          My accelerations (as listed above) are not even near those high numbers.
