    Does anyone here work on Superslicer?
    87
    8.6k
    • botundefined
      bot @resam
      @resam Hmmm no that is not intended at all. But actually that output was from an older test. Can you try this?
      ; generated by PrusaSlicer 2.4.0+n8 on 2022-01-02 at 08:52:13 UTC
      ; QOI thumbnail begin 64x64 1496
      ; cW9pZgAAAEAAAABABAAAwv9QUFB//6Ghof//jY2N3yUA7v88PDxg/6Ghof8Y/ygoKEAAx/8UFBQg/3
      ; l5eb8kJQDT/xkNByD/lFErv/+SUCrf/xULBiD/AAAAANL/FBQUIP95eXm/JAz/FBQUIADJDCUk/42N
      ; jd//KCgoQADQ/2M2HH//xmw5/8D+p1wwAf9TLhh/ANAYJMAlAM0M/42Njd/AJQDNHTMywQbBAf8VCw
      ; Yg/wAAAADNJSQY/ygoKEAAzwwlJP+NjY3fDADK/zEbDkAywwbCAf9TLhh/AMoM/3l5eb8k/2VlZZ//
      ; AAAAANP/KCgoQP+NjY3fwCUAyDAyxAbEPADIJSQY/ygoKEAA1f8UFBQgJST/eXl5v/8UFBQgAMQd/6
      ; 1eMt8yxQbFAf8qFwxAAMQM/3l5eb8kDADZJST/jY2N3yUAwjAyxwbGATwAwv8oKChAJMAlANv/FBQU
      ; IP+NjY3fJCUAHTMyyAbIAf8VCwYg/wAAAAAlJBj/KCgoQADdDCUk/5t5Zt8yygbJAf6QalQkJQDgHT
      ; MyywbL/3xOMr8A4P8xGw5AMs0GzAH/PyISYADdMDLOBs7/Uy4YfwDaHTMyzwbPAf8VCwYg/wAAAADX
      ; MDLRBtABPADUHTMy0gbS/31FJL//FQsGIP8AAAAA0f8xGw5AMtQG0/+SUCrf/1MuGH8AzzAy1QbVPA
      ; DMHRAy1gbWAf8VCwYg/wAAAADKEDLXBtcBAMoQMtcG1wEAyhAy1wbXAQDKEDLXBtcBAMoQMtcG1wEA
      ; yhAy1wbXAQDKEDLXBtcBAMoQMtZ+/qxfMQbWAQDKEDLVoZiklp1pmCwG1QEAyhAy1KKXNcIbBtQBAM
      ; oQMtI6o6g1xAkrBtIBAMoQMtEMNccJGwbRAQDKEDLPOqOXNcoJKwbPAQDKEDLOBDXNCRsGzgEAyhAy
      ; zDqimDXQlQ0GzQEAyhAyywQtNdIJ/rBhMwbLAQDKEDLKDDXVCRsGygEAyRj/wXNG/zLIOiM12AkrBs
      ; gBJQDHJSQhMscMNdsJGwbH/qZlPiQlAMT/FBQUIP+NjY3fJCUQMsU6IzXemzorBsUSJSQYDADBJSQY
      ; /ygoKEAAEDLEBDXhCRsGxAEADP+NjY3fwCUA/3l5eb8kDADBEDLDopc15BsGwwEAwP8UFBQgJSQYJP
      ; 88PDxgAMIQMsE6IzXmCSsGwQEAwiX/oaGh/wwAwxAywKKXNekJGwbAAQDD/xQUFCAAxBA6IzXsCSsB
      ; AMr/r2Az3zXvCf+lWzDfAMr/Gg4HIP+zYzTfNe4J/zMcD0AAyyX/ZjgefzXs/4BHJZ8Azw4JNegJDg
      ; DRJRE15v+aVS2/ANURNeQRANclCTXgCQ4A2SURNd4RAN0lCTXaCQ4A3yURNdgnAOMRNdYRAOUlJzXS
      ; CSUA5yURNdARAOslCTXMCQ4A7SURNco7APH/TSoWYDXHCQ4A8yU7NcQnAPcRNcIRAPklCcAOAPslAN
      ; 4AAAAAAAAAAQ==
      ; thumbnail end
      *not actually a robot
      resamundefined 1 Reply Last reply Reply Quote 0
      • resamundefined
        resam @bot
        @bot that one is producing a completely empty 32x32 PNG...
        I have to mention though: I don't fully trust the QOI toolchain either 😏
        But the converter tool is from the "official" specification repo, so 🤷
        • botundefined
          bot @resam
          @resam I tend to believe what you are verifying. I've not been able to decode the base64 into what is a viewable QOI image... however, the file writing to qoi format works.
          Hmmm.. Thank you for the help. I have no idea what to try now lol.
          • resamundefined
            resam @bot
            @bot does PrusaSlicer give you RGBA data with 4 channels? or just 3?
            you seem to have it hardcoded to 4, but I don't see where you take this assumption from.
            • botundefined
              bot @resam
              @resam The image data is 4 channel, yes. The PNG contains full transparency in part of it.
              When I write a test QOI image from a thumbnail, the image is perfectly vieable in https://github.com/Tom94/tev
              So, the problem doesn't seem to be the pixels. It seems to be the base64 encoding?
              But also the last test might have been ruined by me trying to generate QOI only if RRF is selected.
              test111.txt rename to .qoi
              • botundefined
                bot
                I have verified that everything works as intended, albeit the thumbnail is upside down! lol. Not sure why that is.
                The branch has been updated to trigger QOI format only if RRF is selected as gcode flavor. Also, the thumbnail comment will indicate if it is QOI (but will remain unchanged if outputting PNG)
                https://github.com/n8bot/PrusaSlicer/tree/n8-240-qoitest
                ; generated by PrusaSlicer 2.4.0+n8 on 2022-01-02 at 09:00:33 UTC
                ; QOI thumbnail begin 128x128 3024
                ; cW9pZgAAAIAAAACABAAAx/8UFBQg/42Njd//oaGh//9QUFB/AP3mJSQY/ygoKEAA0QwlJP+NjY3fDA
                ; Du/xkNByCeaf8AAAAA7gz/eXl5vyQlANX/FBQUIBjAJQDs/0ooFWD/xmw5//+SUCrf/1MuGH8A7CUk
                ; GP8oKChAANcMJST/jY2N3wwA6B3/lFErvzLA/qdcMMD/aDkenwDpDP95eXm/JAwA2yUkGCUA5v8xGw
                ; 5AMsIGwQH/PyISYADm/ygoKEAkwCUA3f8UFBQg/3l5eb8kJQDk/2M2HH8ywwbD/1MuGH8A5CUk/42N
                ; jd//FBQUIADfDCUkGP8oKChAAOAdMzLEBsQB/xULBiD/AAAAAOAM/42Njd8kJQDjDBjAJQDeMDLGBs
                ; UBPADeJSQY/ygoKEAA5QwlJP+NjY3fDADaHTMyxwbH/31FJL//FQsGIP8AAAAA2gz/eXl5vyT/ZWVl
                ; n/8AAAAA6f88PDxg/6Ghof8YJQDY/zEbDkAyyQbI/5JQKt//Uy4YfwDY/zw8PGD/oaGh/xj/KCgoQA
                ; Dr/xQUFCD/eXl5vyT/ZWVln/8AAAAA1jAyygbKPADV/xQUFCD/eXl5vyQMAO7/FBQUICUk/42Njd//
                ; PDw8YADSHf+tXjLfMssGywH/FQsGIP8AAAAA0v8oKChA/6Ghof/AJQDxDP+NjY3fJCUA0DAyzQbMAT
                ; wA0CUkGP8oKChAAPMMJST/jY2N3wwAzB0zMs4GzgH/FQsGIP8AAAAAzAz/eXl5vyQlAPf/KCgoQP+N
                ; jY3fwCUAyhky0AbPATwAyiUkGP8oKChAAPn/FBQUICUk/3l5eb//FBQUIADGHTMy0QbRPADHDP95eX
                ; m/JAwA/SUk/42Njd8lAMT/MRsOQBAy0gbSAf8qFwxAAMT/KCgoQCTAJQD9wf8UFBQg/42Njd8kJQDC
                ; MDLUBtMB/1MuGH8AwiUkGAwA/cMMJSQYDB0zMtUG1QH/FQsGIAwYJCX/AAAAAP3HDBj+m3lmMtcG1g
                ; H/pH5o/xj/KCgoQAD9yB0zMtgG2P99RSS//xULBiD/AAAAAP3H/zEbDkAy2gbZ/5JQKt//Uy4YfwD9
                ; xTAy2wbbPAD9wh0QMtwG3AH/FQsGIP8AAAAA/TAy3gbdATwA+h0zMt8G3wH/FQsGIP8AAAAA9/8xGw
                ; 5AMuEG4AH/Uy4YfwD1/3xDJJ8y4gbiPADyHRAy4wbjAQUA7zAy5QbkATwA7B0zMuYG5gH/FQsGIP8A
                ; AAAA6Rky6AbnATwA5h0zMukG6f99RSS//xULBiD/AAAAAOP/MRsOQDLrBur/klAq3/8/IhJgAOEwMu
                ; wG7P9TLhh/AN4dMzLtBu0B/xULBiD/AAAAANswMu8G7gE8ANgdMzLwBvD/fUUkv/8VCwYg/wAAAADW
                ; MzLxBvEBANYzMvEG8QEA1jMy8QbxAQDWMzLxBvEBANYzMvEG8QEA1jMy8QbxAQDWMzLxBvEBANYzMv
                ; EG8QEA1jMy8QbxAQDWMzLxBvEBANYzMvEG8QEA1jMy8QbxAQDWMzLxBvEBANYzMvEG8QEA1jMy8Qbx
                ; AQDWMzLwopeYHAbwAQDWMzLufqOXoZjAGwbvAQDWMzLtoZijlzXCnWn+sGEzBu0BANYzMuwMNcUJGw
                ; bsAQDWMzLqOiM1yAn+rF8xBuoBANYzMukMNcsJGwbpAQDWMzLnOiM1zps6KwbnAQDWMzLmBDXRCRsG
                ; 5gEA1jMy5Qw11BsG5QEA1jMy4zotNdYJKwbjAQDWMzLiDDXZCRsG4gEA1jMy4DojNdwJKwbgAQDWMz
                ; LfBDXfCRsG3wEA1jMy3qOXNeKVDQbeAQDWMzLcOi015AkPBtwBANYzMtsMNecJGwbbAQDWMzLZOiM1
                ; 6gkrBtkBANYzMtgMNe0JGwbYAQDWMzLWOiM18CkrBtYBANYzMtUENfMJ/rVkNAbVAQDV/xQUFCD/qW
                ; U/3zLUopc19hsG1P+RWTjf/xQUFCAA0xgk/r15UzLSOiM1+AkrBtL+pW1M/42Njd8lANElJBgzMtGi
                ; lzX7CRsG0Q0YJCUAzv8UFBQgGCQlADMyzzojNf3AKSsGzwEMJSQY/ygoKEAAyyUk/42Njd//KCgoQA
                ; DAMzLOBDX9wwkbBs4BAMAM/42Njd/AJQDIDP95eXm/JP9lZWWf/wAAAADCMzLNopc1/cYbBs0BAMH/
                ; FBQUICUkGAwAxf88PDxg/6Ghof8Y/ygoKEAAwzMyyzotNf3ICQ8GywEAwyUk/42Njd8lAMIM/3l5eb
                ; 8kDADFMzLKopc1/csJGwbKAQDE/xQUFCD/eXl5vyT/ZWVln/8AAAAAwP8oKChAJMAlAMYzMsg6IzX9
                ; zgkrBsgBAMX/FBQUICUk/42Njd//KCgoQCT/jY2N3/8oKChAAMczMseilzX90QkbBscBAMf/FBQUIP
                ; +NjY3fJCUAyTMyxTojNf3UmCsGxgH/AAAAAMgMJQDKMzLEBDX91wkPBsQBANYzMsOilzX92QkbBsMB
                ; ANYzMsE6IzX93AkrBsEBANYzMsAMNf3fCRsGwAEA1jM6IzX94ikrAQDW/5ZSK781/eUJ/3dBIp8A1v
                ; 8aDgcg/2Y4Hn81/eT/mlUtvwDZETX94hEA2yX/s2M03zX93gn/MxwPQADdJRE1/dwRAOElCTX92AkO
                ; AOMlETX91icA5xE1/dQRAOklJzX90AklAOslETX9zhEA7yUJNf3KCQ4A8SURNf3I/4BHJZ8A9f9NKh
                ; ZgNf3FCQ4A9yUnNf3CJwD7ETX9wBEA/SUJNfoJDgD9wSURNfgRAP3FDgk19AkOAP3HJRE18icA/csR
                ; NfARAP3NJQk17AklAP3PJRE16hEA/dMlCTXmCQ4A/dUlETXkJwD92RE14QkzAP3bJSc13iclAP3dJR
                ; E13BEA/eElCTXYCQ4A/eMlETXWOwD95w4JNdIJDgD96SURNdAnAP3tETXOEQD97yUJNcoJDgD98SUR
                ; NcgRAP31JQk1xAkOAP33JRE1wicA/fsRNcARAP39JcAA/f39wwAAAAAAAAAB
                ; thumbnail end
                results in
                • botundefined
                  bot @bot
                  as @resam pointed out to me, PrusaSlicer itself has to flip its pixels while encoding to PNG. I tried reversing the vector of pixels using std::reverse but that is not working.
                  So... for now the thumbnails are upside down! Lol. Sorry dc42.
                  @dc42 Here is a build of PrusaSlicer-n8 2.4.0 with the QOI image format enabled for RRF firmware, and upside-down thumbnail generation.
                  I've created an issue with QOI GH repo to ask/mention the idea of a flip image function on encode, so we can easily get our thumbnails the right way around!
                  Link to Win64 binary release: https://github.com/n8bot/PrusaSlicer/releases/download/version_2.4.0-release1-n8/PrusaSlicer-n8-2.4.0-QOIforRRFtest1-Win64.zip
                    dc42 administrators @bot
                    @bot wow that was quick, I didn't expect anything so soon! Thanks!
                    Are the pixels encoded in the file top-to-bottom, or bottom-to-top? And within each row are they left-to-right?
                    • botundefined
                      bot @dc42
                      @dc42 According to the spec, they are encoded
                      Images are encoded row by row, left to right, top to bottom. The decoder and
                      encoder start with {r: 0, g: 0, b: 0, a: 255} as the previous pixel value. An
                      image is complete when all pixels specified by width * height have been covered.
                      Pixels are encoded as
                       - a run of the previous pixel
                       - an index into an array of previously seen pixels
                       - a difference to the previous pixel value in r,g,b
                       - full r,g,b or r,g,b,a values
                      It surprised me how fast it was, too! The library was basically a drop-in replacement with the PNG library.
                      I'm experimenting with ways to flip the pixels vertically before they are encoded to QOI, but it's proving difficult because of some weird pointer stuff. I suppose they appear upside down because of the way PrusaSlicer collects the pixel data into vectors. The PNG miniz library has a bool flag on the encode function to flip the pixels vertically.
                      [Edit: I was able to reverse the vector of pixels, which does flip the image vertically but it also seems to invert the colour or swap the channels around incorrectly. Further experimentation required.]
                      • botundefined
                        bot @bot
                        Ok, I'm done!
                        Image is now flipped vertically, and the colours render correctly:
                        https://github.com/n8bot/PrusaSlicer/commit/821cbee27ce0a04d4dd86a9ce01a4fa271167236
                        Updated Win64 binaries: https://github.com/n8bot/PrusaSlicer/releases/download/version_2.4.0-release1-n8/PrusaSlicer-n8-2.4.0-QOIforRRFtest2-Win64.zip
                        Here are some web-based tools for testing:
                        Covnert Base64 to binary or hex: https://cryptii.com/pipes/base64-to-binary
                        Copy and Paste Hex data and save as file: https://hexed.it/
                        Drag and Drop saved QOI image viewer: https://floooh.github.io/qoiview/qoiview.html
                        0 n8bot committed to n8bot/PrusaSlicer
                        Flip vertically
                        resamundefined 1 Reply Last reply Reply Quote 2
                        • resamundefined
                          resam @bot
                          @dc42 now that we have shown this is feasible, a few more questions:
                          • one image in a fixed resolution, or multiple: 32x32 + 64x64 + 128x128, ...?
                          • square or same aspect ratios as the PanelDue: 1.6666 and 1.7647?
                          • what about DWC? use the same embedded QOI, or upload a dedicated PNG next to the gcode file?
                          From the wiki I got these for PanelDue: 480×272 (4.3" displays) or 800×480 pixels (5" and 7" displays).
                            dc42 administrators @resam
                            @resam @bot I suggest that for DWC we use QOI again. We may wish to support PNG in DWC too, however the headers for PNG and QOI encoding will allow DWC to identify which decoder to use.
                            I'll liaise with @chrishamm on what default thumbnail resolutions would suit both RRF and DWC. I presume you can pick up the required resolutions form the .ini file as is the case for PNG thumbnails. Maybe we should add an option to the Superslicer .ini file to specify the thumbnail image format?
                            • botundefined
                              bot @dc42
                              @dc42 Correct, the thumbnail resolutions are taken from the ini file, which is generated by the GUI.
                              If multiple resolutions are input, multiple thumbnails will be output to the gcode file. I assume the files do not need to conform to any aspect ratio, but I've only tested square power-of-2 sizes in width and height (just our of habit, I guess).
                              It would be possible to allow the user to select the format, but I know for sure that PrusaSlicer upstream will be reluctant to include changes to the GUI settings. Quietly choosing a new format for RRF will be more inline with their wishes, I imagine.
                              For SuperSlicer, @merill will decide what to do.
                              I have uploaded a universal macOS release that should work on intel and M1 macs alike, to broaden your potential testing base for this. Found here: https://github.com/n8bot/PrusaSlicer/releases/download/version_2.4.0-release1-n8/PrusaSlicer-n8-2.4.0-release1-macOS.dmg
                              Let me know if you'd like any changes.
                              • botundefined
                                bot
                                Discussing a few things with merill, I realize that we may want to simply output both PNG and QOI format when RRF is selected. Octoprint or other external services might still expect a PNG thumbnail. Outputting both should not break anything for anybody else, but provide the QOI for paneldue. I might output the QOI after the PNG in order to not mess with the expected location in the file of the thumbnail.
                                Any thoughts?
                                • oliofundefined
                                  oliof
                                  @bot that sounds nice and clean to me. The biggest risk is that other software picks up the QOI instead of PNG, but if that breaks them, well, they need to fix it anyways.
                                  • botundefined
                                    bot @oliof
                                    @oliof yeah. I think that identifying the thumbnail as a "QOI thumbnail" at the beginning of the comment might be enough to stop any software from thinking it is a PNG thumbnail (if they use that string to detect the thumbnail)
                                    But, also, placing it after all the PNG icons should at least give them the chance to gather the PNGs, too, and maybe error out on the QOI and hopefully retain the PNG.
                                    • oliofundefined
                                      oliof
                                      yeah unless they're lazy and pick the last image comment block because obviously (-:
                                      • botundefined
                                        bot @oliof
                                        @oliof lol that may very well actually be the case.
                                        • oliofundefined
                                          oliof
                                          Only one way to find out (-:
                                          • resamundefined
                                            resam @oliof
                                            @bot let's make sure we keep in sync what SuperSlicer/PrusaSlicer and the Cura plugin are doing.
                                            As long we are consistent, things work (or break) all in the same way.
                                            botundefined 1 Reply Last reply Reply Quote 3
