    No tools are showing in DWC - noob
    Duet Web Control
    1.5k
    • Nvigr8undefined
      Nvigr8 @Stephen6309
      @stephen6309 NM, I found it. Thanks! I'll try it out at lunch.
      Modified Multoo MT1.5, Modified Creality CR6SE, Modified Monoprice Mini Delta, Modified Wanhao Di3, Phrozen Shuffle
      • Stephen6309undefined
        Stephen6309 @Nvigr8
        @nvigr8 config.g You just need to edit the one in there already.
        Nvigr8undefined 1 Reply Last reply Reply Quote 0
        • Nvigr8undefined
          Nvigr8 @Stephen6309
          @stephen6309 What does that ! do there to make it work?
          Stephen6309undefined 1 Reply Last reply Reply Quote 0
            Stephen6309 @Nvigr8
            @nvigr8 The ! inverts the signal from the pin.
            Nvigr8undefined 2 Replies Last reply Reply Quote 0
            • Nvigr8undefined
              Nvigr8 @Stephen6309
              @stephen6309 Ah, good to know. Thank you.
              • Nvigr8undefined
                Nvigr8 @Stephen6309
                @stephen6309 Thanks again for the help. However, when I first made this post and put in the config.g it WAS working. It was the ONLY axis working at the time. In trying to fix other problems - tools, thermistors, etc. I must have changed something to make it not work. That line you referenced earlier apparently didn't change though.
                I just wanted to give a little more context. I will still try your suggestion when I go home for lunch.
                ; Configuration file for Duet WiFi (firmware version 3.3)
                ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jan 05 2022 21:06:25 GMT-0600 (Central Standard Time)
                M575 P1 S1 B57600                                      ; enable support for PanelDue
                G90                                                    ; send absolute coordinates...
                M83                                                    ; ...but relative extruder moves
                M550 P"Multoo"                                         ; set printer name
                M552 S1                                                ; enable network
                M586 P0 S1                                             ; enable HTTP
                M586 P1 S0                                             ; disable FTP
                M586 P2 S0                                             ; disable Telnet
                M569 P0 S0                                             ; physical drive 0 goes backwards
                M569 P1 S0                                             ; physical drive 1 goes backwards
                M569 P2 S1                                             ; physical drive 2 goes forwards
                M569 P3 S1                                             ; physical drive 3 goes forwards
                M569 P4 S1                                             ; physical drive 4 goes forwards
                M584 X0 Y1 Z2 E3:4                                     ; set drive mapping
                M350 X16 Y16 Z16 E16:16 I1                             ; configure microstepping with interpolation
                M92 X80.00 Y80.00 Z400.00 E400.00:400.00               ; set steps per mm
                M566 X900.00 Y900.00 Z60.00 E120.00:120.00             ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E2100.00:2100.00        ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z20.00 E250.00:250.00             ; set accelerations (mm/s^2)
                M906 X1300 Y1300 Z1300 E450:450 I30                    ; set motor currents (mA) and motor idle factor in per cent
                M84 S30                                                ; Set idle timeout
                M208 X0 Y0 Z0 S1                                       ; set axis minima
                M208 X420 Y410 Z470 S0                                 ; set axis maxima
                M574 X1 S1 P"!xstop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
                M574 Y1 S1 P"!ystop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
                M574 Z2 S2                                             ; configure Z-probe endstop for high end on Z
                M950 S0 C"exp.heater3"                                 ; create servo pin 0 for BLTouch
                M558 P9 C"^zprobe.in" H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
                M558 H30                                               ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                G31 P500 X-32.69 Y-31.88 Z2.5                          ; set Z probe trigger value, offset and trigger height
                M557 X15:215 Y15:195 S20                               ; define mesh grid
                M308 S0 P"bedtemp" Y"thermistor" T100000 B3950         ; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
                M307 H0 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
                M140 H0                                                ; map heated bed to heater 0
                M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
                M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                M143 H1 S295                                           ; set temperature limit for heater 1 to 295C
                M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp
                M950 H2 C"e1heat" T2                                   ; create nozzle heater output on e1heat and map it to sensor 2
                M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                M143 H2 S295                                           ; set temperature limit for heater 2 to 295C
                M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
                M106 P1 S1 H1:2 T45                                    ; set fan 1 value. Thermostatic control is turned on
                M563 P0 D0 H1 F0                                       ; define tool 0
                G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                M563 P1 D1 H2 F0                                       ; define tool 1
                G10 P1 X0 Y0 Z0                                        ; set tool 1 axis offsets
                G10 P1 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
                ; Custom settings
                ; add for filament sensors
                M591 P1 C"e0stop" S1 D0                                ;filament monitor connected to E0 endstop
                M591 P1 C"e1stop" S1 D1                                ;filament monitor connected to E1 endstop
                M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"     ; set voltage thresholds and actions to run on power loss
                T0                                                     ; select first tool
                • Nvigr8undefined
                  Nvigr8 @Stephen6309
                  @stephen6309 Ok, I'm at home and I added that !. Now M119 shows the Z is not stopped.
                  Next problem is that when I home the Z axis, the probe deploys but when pushed in, it does not register as a stop. Ideas?
                    Phaedrux Moderator @Nvigr8
                    @nvigr8 said in No tools are showing in DWC - noob:
                    I don't think the inversion was correct in this case. It should not need inversion. I think there may be an issue with the white wire for the BLTouch which is the trigger signal wire.
                    • Nvigr8undefined
                      Nvigr8 @Phaedrux
                      @phaedrux Since the BL touch was working early on and now not, it occured to me after I left home that maybe the wires came loose through all the other manipulating I've been doing trying to get the thermistors and heaters working. I'll check them when I get back home after work. If they are seated well and there are no obvious issues, what do you suggest next?
                      On an older note, I got the heaters and tools all sorted, mostly. I added a mains powered bed (which isn't working yet - maybe the SSR) and accordingly bed heater in the configurator. Now the other two tools are showing as well.
                      At first the thermistor for nozzle 1 was showing wacky numbers and naturally the heater was faulting. I realized this morning that somewhere along the way I switched to PT100 thermistors and forgot about it...very old printer. At lunch I switched back to a standard E3D thermistor and now it appears to be working!
                      Just gotta get the BLtouch working now then the bed.
                      • Nvigr8undefined
                        Nvigr8 @Phaedrux
                        @phaedrux You were correct. The white wire broke off of the male plug end. Ended up not needing the ! after all. It is working properly now. Thank you for the help there.
