No tools are showing in DWC - noob
@phaedrux Do you know what the SH terminal on that breakout board is for?
Also, after doing some reading, it looks like I should have checked the resistance on the wires I used to connect the thermistors... Maybe that is part of the issue. Tonight I'll replace those cables with thermistor cables and crimp them onto the plug pin instead of soldering.
@nvigr8 Change the S1 to S0 in your M574.
@stephen6309 Thank you for the input. Last night I finally got the X and Y endstops and movement working properly.
However, now the Z endstop shows as being on even though the BLtouch has not been triggered. Not sure what I changed to make this happen.
@stephen6309 Which .g file would that be in? Thanks.
@stephen6309 NM, I found it. Thanks! I'll try it out at lunch.
@nvigr8 config.g You just need to edit the one in there already.
@stephen6309 What does that ! do there to make it work?
@nvigr8 The ! inverts the signal from the pin.
@stephen6309 Ah, good to know. Thank you.
@stephen6309 Thanks again for the help. However, when I first made this post and put in the config.g it WAS working. It was the ONLY axis working at the time. In trying to fix other problems - tools, thermistors, etc. I must have changed something to make it not work. That line you referenced earlier apparently didn't change though.
I just wanted to give a little more context. I will still try your suggestion when I go home for lunch.
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jan 05 2022 21:06:25 GMT-0600 (Central Standard Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Multoo" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M584 X0 Y1 Z2 E3:4 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E400.00:400.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E2100.00:2100.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E450:450 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X420 Y410 Z470 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop M574 Z2 S2 ; configure Z-probe endstop for high end on Z ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P500 X-32.69 Y-31.88 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S295 ; set temperature limit for heater 1 to 295C M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S295 ; set temperature limit for heater 2 to 295C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings ; add for filament sensors M591 P1 C"e0stop" S1 D0 ;filament monitor connected to E0 endstop M591 P1 C"e1stop" S1 D1 ;filament monitor connected to E1 endstop ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
@stephen6309 Ok, I'm at home and I added that !. Now M119 shows the Z is not stopped.
Next problem is that when I home the Z axis, the probe deploys but when pushed in, it does not register as a stop. Ideas?
@nvigr8 said in No tools are showing in DWC - noob:
I don't think the inversion was correct in this case. It should not need inversion. I think there may be an issue with the white wire for the BLTouch which is the trigger signal wire.
@phaedrux Since the BL touch was working early on and now not, it occured to me after I left home that maybe the wires came loose through all the other manipulating I've been doing trying to get the thermistors and heaters working. I'll check them when I get back home after work. If they are seated well and there are no obvious issues, what do you suggest next?
On an older note, I got the heaters and tools all sorted, mostly. I added a mains powered bed (which isn't working yet - maybe the SSR) and accordingly bed heater in the configurator. Now the other two tools are showing as well.
At first the thermistor for nozzle 1 was showing wacky numbers and naturally the heater was faulting. I realized this morning that somewhere along the way I switched to PT100 thermistors and forgot about it...very old printer. At lunch I switched back to a standard E3D thermistor and now it appears to be working!
Just gotta get the BLtouch working now then the bed.
@phaedrux You were correct. The white wire broke off of the male plug end. Ended up not needing the ! after all. It is working properly now. Thank you for the help there.
