Usable Laser / 5V PWM Outputs on Expansion Board 1XD
I want to know if it is Possible to use for example io2_out on the Expansion Board 1XD
together with M452Original Command:
M452 C"out9" R255 F200
Modified Command:
(for CAN Address 40)M452 C"40.io2_out" R255 F200
or is the Firmware not able to use it?
at the moment i cannot test it because i wait for the 1XD Board. -
undefined Phaedrux moved this topic from Duet Hardware and wiring
@neueklasse I'm sorry, it's not supported. The reason is that the code to control the laser power has to adjust it dynamically according the the instantaneous speed of the move.
@o_lampe RRF already uses PPI mode.
It would be possible to support lasers connected to expansion boards, but quite a lot of work, so I am only likely to implement it if several users or an OEM need it.
