    Was working, now can't connect to WiFi
    815
      So does it have a saved SSID now or not?
      Does your config.g have a M552 S1?
      The last test would be to see if it will run in standalone WIFI access point mode.
      https://duet3d.dozuki.com/Wiki/M589
      flyeyesundefined 1 Reply Last reply Reply Quote 0
      • flyeyesundefined
        flyeyes @Phaedrux
        @phaedrux
        Yes, it seems to be working now. I have no idea what I did differently, which bothers me a bit because it worked fine when I first configured it, then after a week quit working, and now it’s working fine as far as I can tell.
        I haven’t done anything differently, but I will watch it for now. If it quits again I’m just going to plug it into the pi or start over with a different board.
          Well if we can identify what's wrong or if there is something wrong and it's under warranty you can get it replaced.
          • terbospaghettiundefined
            terbospaghetti
            I'm having this same problem.
            I can save and forget networks as long as the wifi module has been set to active with m552 S0, but not with S-1 or S1 modifiers. When I try to check the status of the wifi module with M552 by itself, I consistently get "wifi module is changing modes" until there's an SPI timeout message like the one at the bottom of the excerpt below.
            I've successfully reinstalled wifiserver.bin twice (i'm doing this over USB with pronterface and a 24vPSU for the board), but this has yielded no changes in anything. If I just let it sit, it'll eventually give me a bunch of these in a row:
            WiFi module is idle
            WiFi reported error: network scan failed
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            Error retrieving WiFi status message: SPI timeout
            WiFi module is idle
            Failed to change WiFi mode: SPI timeout
            Once the SPI timeout message(s) come, m552 reports that the wifi module is disabled.
            I know it's not a poor signal issue, as I've tried within a foot or two of the router.
            Here's my m122 if it helps:
            >>> M122
            SENDING:M122
            RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
            Board ID: ZJ21Z-NV9RL-D65J0-40KMN-L3X2Z-HFGNV
            Used output buffers: 1 of 40 (40 max)
            Static ram: 102724
            Dynamic ram: 106504 of which 0 recycled
            Never used RAM 34476, free system stack 157 words
            Tasks: NETWORK(ready,7.6%,328) HEAT(notifyWait,0.0%,364) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,1.1%,115) MAIN(running,90.4%,426) IDLE(ready,0.0%,29) AIN(delaying,0.8%,264), total 100.0%
            Owned mutexes: USB(MAIN)
            Last reset 00:14:30 ago, cause: software
            Last software reset at 2022-01-09 18:47, reason: StuckInSpinLoop, Display spinning, available RAM 41956, slot 1
            Software reset code 0x408f HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x20002a4c Task IDLE Freestk 43 ok
            Stack: 00087e75 000888a8 61000000 a5a5a5a5 00087e75 a5a5a5a5 a5a5a5a5 2000390c 0001676d 20019104 2002ec9c 20002a68 200190fc 00000004 2001e0dc 2001e0dc 20002a68 2001e0d4 00000001 20002ac4 4e49414d 00000000 00000000 00000001 00000001 17c2fb96 00000000
            Error status: 0x04
            Error status: 0x04
            Aux0 errors 0,0,1
            MCU revision 3, ADC conversions started 870849, completed 870849, timed out 0, errs 0
            Step timer max interval 597
            MCU temperature: min 26.1, current 33.1, max 33.3
            Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
            Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
            Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
            Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
            Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
            Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
            Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 13591, writes 9, timeouts 0, DMA errors 0
            Cache data hit count 1789008195
            Slowest loop: 99.69ms; fastest: 0.12ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 0.5ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Bed heaters = 0 -1, chamberHeaters = -1 -1
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is ready with "M122" in state(s) 0
            Aux is assembling a command in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === CAN ===
            Messages queued 7836, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 4354/0/0
            Tx timeouts 0,0,4353,0,0,3481 last cancelled message type 4514 dest 127
            === Network ===
            Slowest loop: 200.13ms; fastest: 0.00ms
            HTTP sessions: 0 of 8
            - WiFi -
            Network state is disabled
            WiFi module is disabled
            Failed messages: pending 0, notready 0, noresp 2
              Phaedrux Moderator @terbospaghetti
              @terbospaghetti said in Was working, now can't connect to WiFi:
              That's normal.
              The M587 command will fail if the WiFi module has not yet been taken out of reset. So if the WiFi module has not been started, send M552 S0 to put it in idle mode first.
              https://duet3d.dozuki.com/Wiki/M587
              Not normal.
              Have you been able to verify that the correct version is installed with a M122 when the wifi has connected?
              terbospaghettiundefined 1 Reply Last reply Reply Quote 0
                terbospaghetti @Phaedrux
                @phaedrux said in Was working, now can't connect to WiFi:
                Not sure where I would look or what it should say, but the process was successful according to the console in pronterface
                  In the M122 report at the end there is a section for wifi
                  - WiFi -
                  When it's active it would say what wifi server version it's running.
                  ddxdesignundefined terbospaghettiundefined 2 Replies Last reply Reply Quote 0
                  • ddxdesignundefined
                    ddxdesign @Phaedrux
                    @flyeyes @terbospaghetti
                    This kind of thing happened to me and part of my resolution dance, along with a big chain of FW upgrades to current, was in discovering that my modem/router had smashed the 2.4ghz and 5ghz networks into one automode SSID. And the Duet doesn't like 5ghz I think. I had to dig into my router config and force the two networks to separate SSIDs, after which the Duet was much better about seeing the 2.4ghz network even after a restart or a few days switched off. Not perfect, but much better.
                    Maybe looking into that could help.
                    terbospaghettiundefined 1 Reply Last reply Reply Quote 1
                      terbospaghetti @ddxdesign
                      @ddxdesign good thinking, but I've got two discrete networks, one 2.4 and one 5ghz.
                      I tried to post the m122 info that @Phaedrux asked for yesterday but couldn't do it for some reason, maybe I should try again in a moment
                        @phaedrux here you go, as requested. It will only show idle or "changingmode"
                        Example 1:
                        === Network ===
                        Slowest loop: 1.27ms; fastest: 0.00ms
                        • WiFi -
                          Network state is active
                          WiFi module is idle
                          WiFi firmware version 1.26
                          WiFi MAC address 8c:aa:b5:15:42:25
                          WiFi Vcc 3.39, reset reason Power up
                          WiFi flash size 2097152, free heap 31248
                          Clock register 00002002
                        Example 2:
                        === Network ===
                        Slowest loop: 1.30ms; fastest: 0.00ms
                        - WiFi -
                        Network state is changingMode
                        WiFi module is trying to connect
                        WiFi flash size 2097152, free heap 28024
                        Curiously tho, I can turn on AP mode and get into DWC that way. That would be a great workaround if it worked in the config.g file, but the wiki says that's a no-no.
                          Does it say that? I think it says you shouldn't setup the SSID and password params in config.g, but to enable access point mode you'd just have M552 S2 to turn on AP mode.
                          Regardless, it's odd that it works fine in AP mode, but not with the router. That indicates the hardware itself is fine and the problem is some incompatibility with the router or settings.
