    error zoffset for bl touch and duet3 firmware 3.4 beta 7+1
    Beta Firmware
    632
    • massimilianocontiundefined
      massimilianoconti @Phaedrux
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Dec 31 2021 12:22:58 GMT+0100 (Ora standard dell’Europa centrale)
      M550 P"Duet 300X Dual" ; set printer name
      M955 P0 C"spi.cs3+spi.cs2"
      M669 K1 ; select CoreXY mode
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.2 S0 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes forwards
      M569 P0.4 S0 ; physical drive 0.4 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
      M350 X128 Y128 Z128 E128:128 I1 ; configure microstepping with interpolation
      M92 X640.00 Y640.00 Z5120.00 E3367.10:3367.70.31 ; set steps per mm
      M566 X800.00 Y800.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z500.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X2300.00 Y2300.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X900 Y900 Z1000 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M593 P"zvd" F70
      M208 X-18 Y-5 Z0 S1 ; set axis minima
      M208 X305 Y305 Z260 S0 ; set axis maxima
      M671 X10:300:300:10 Y290:290:5:5 P0.5
      M591 D0 P5 C"e0_stop" R40:120 E3.0 S0
      M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
      M574 Y1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" P9 H5 F500:100 T6000 A5 R0.1 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X12.5 Y-20 Z1.55 ; set Z probe trigger value, offset and trigger height
      M557 X20:290 Y15:300 S25:20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 Q10 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0
      M143 H0 S130 ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"pt1000" ; configure sensor 1 as PT1000 on pin temp1
      M143 H1 S400 ; set temperature limit for heater 1 to 400C
      M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp2
      M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H1:2 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 H1 F1 ; define tool 0
      M563 P1 D1 H2 F1 ; define tool 0
      G10 P1 X25 Y0 Z0 ; set tool 0 axis offsets
      T0 ; select first tool
      M150 X0 ; set LED type to NeoPixel and set SPI frequency to 3MHz
      M150 B255 P128 S65 F0
      M501
        Phaedrux Moderator @massimilianoconti
        @massimilianoconti said in error zoffset for bl touch and duet3 firmware 3.4 beta 7+1:
        Not sure if it will make a difference but you have P9 listed twice.
        Can you post your homeall and homez?
        Are you using mesh compensation or auto leveling?
        the nozzle gets too close and triggers the extruder motor.
        What exactly does that mean?
        massimilianocontiundefined 1 Reply Last reply Reply Quote 0
          Yes
          use mesh compensation or automatic leveling
          maybe it's not good P 9 repeated I don't know how it happened
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 01 2022 15:36:30 GMT+0100 (Ora standard dell’Europa centrale)
          G91 ; relative positioning
          G1 H1 X-310 Y-310 F1800 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X-310 ; home X axis
          G1 H1 Y-310 ; home Y axis
          G1 H1 X-310 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y-310 ; then move slowly to Y axis endstop
          G90 ; absolute positioning
          G1 X15 Y35 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
            When do you run G32 or load a mesh?
            Post your bed.g and the slicer start gcode as well please.
            Also test with the new 3.4 beta 7+4 updates.
              Ok thank you. meanwhile I removed the P 9. could you give me the link to download the firmware 3.4 beta 7+4?
              Thank you
              start script
              G28 F4000;
              M150 R255 U255 B255 P128 S65 F0
              M561 ; Clear any bed transform
              G29 S1;
              G1 Z0.470 F7800.000
              G1 X10 Y8 Z10 F3000
              G1 Z0 F500
              T0
              G92 E0
              G1 Z0.25 F400
              G1 X80 Y8 E60 F100
              T1
              G92 E0
              G1 X140 Y8 E60 F100
              ; bed.g
              ; generated by RepRapFirmware Configuration Tool v3.3.2 on Sun Sep 26 2021 01:04:15 GMT+0200 (Ora legale dell’Europa centrale)
              G29 S2; Clear bed height map
              ; Probe 4-point
              M401 ; Deploy probe - deployprobe.g
              G30 P0 X10 Y290 Z-9999 ; Front Right
              G30 P1 X300 Y290 Z-9999 ; Front Left
              G30 P2 X300 Y5 Z-9999 ; Center Rear
              G30 P3 X10 Y5 Z-9999 S4 ; Center Rear
              M402 ; Retract Probe - retractprobe.g
              M300 S715 P1500
              G4 P1500
              G29 S1
                I did. https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files
                When do you call G32 to do the leveling and loading of the mesh?
                This is not needed with the BLtouch
                  Thank you. I think it will be uploaded. Printing is fine.anyway how do you see exactly if the mesh is loaded?
                    If you send M122 it will have a line for compensation in use. If it says mesh, it is active. If it says none, it is not.
                      M122
                      RepRapFirmware for Duet 3 MB6HC version 3.4.0beta7+1 (2021-12-22 16:03:36) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                      Board ID: 08DJM-9P63L-DJMSS-6J9DD-3S46N-TVFH8
                      Used output buffers: 1 of 40 (23 max)
                      Static ram: 150664
                      Dynamic ram: 95148 of which 164 recycled
                      Never used RAM 100928, free system stack 130 words
                      Tasks: NETWORK(ready,24.0%,219) ETHERNET(notifyWait,0.1%,169) HEAT(notifyWait,0.0%,324) Move(notifyWait,1.5%,248) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,333) TMC(notifyWait,8.9%,58) MAIN(running,65.4%,925) IDLE(ready,0.0%,30), total 100.0%
                      Owned mutexes:
                      Last reset 00:24:15 ago, cause: software
                      Last software reset at 2022-01-13 22:50, reason: User, GCodes spinning, available RAM 104696, slot 0
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      Step timer max interval 153
                      MCU temperature: min 43.9, current 46.7, max 46.9
                      Supply voltage: min 23.6, current 23.8, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                      12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
                      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
                      Events: 0 queued, 0 completed
                      Driver 0: pos 206422, ok, SG min 0, mspos 967, reads 52485, writes 17 timeouts 0
                      Driver 1: pos 7789, ok, SG min 0, mspos 571, reads 52485, writes 17 timeouts 0
                      Driver 2: pos 33670, ok, SG min 0, mspos 641, reads 52485, writes 17 timeouts 0
                      Driver 3: pos 0, ok, SG min 0, mspos 620, reads 52485, writes 17 timeouts 0
                      Driver 4: pos 0, standstill, SG min 0, mspos 1, reads 52486, writes 17 timeouts 0
                      Driver 5: pos 0, standstill, SG min 0, mspos 8, reads 52492, writes 11 timeouts 0
                      Date/time: 2022-01-13 23:15:16
                      Slowest loop: 32.87ms; fastest: 0.05ms
                      === Storage ===
                      Free file entries: 9
                      SD card longest read time 2.7ms, write time 5.2ms, max retries 0
                      • list itemDMs created 125, segments created 38, maxWait 211955ms, bed compensation in use: mesh, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 16146, completed 16101, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                        === AuxDDARing ===
                        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                        Heater 0 is on, I-accum = 0.4
                        Heater 1 is on, I-accum = 0.2
                        Segments left: 1
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is doing "G1 X167.119 Y158.677 E0.0301" in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        Code queue is empty
                        === CAN ===
                        Messages queued 13102, received 0, lost 0, boc 0
                        Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 7276/0/0
                        Tx timeouts 0,6,7275,0,0,5818 last cancelled message type 30 dest 127
                        === Network ===
                        Slowest loop: 39.85ms; fastest: 0.02ms
                        HTTP sessions: 1 of 8
                      • Ethernet -
                        State: active
                        Error counts: 0 0 1 0 0
                        Yes it is active
                          perfect. I tried to install version 3.4 beta 7+6 but in the end from an error drive 0
                          perfect. I tried to install I think it's the firmware that has something in the wrong installation. I put back the 3.4 beta 7 + 1 and it went immediately fine. version 3.4 beta 7+4 is not present among the downloaded files but only the 3.4 beta 7+6
                          • Phaedruxundefined Phaedrux moved this topic from General Discussion
                            dc42 administrators @massimilianoconti
                            @massimilianoconti the spurious error from driver 0 is fixed in the 3.4beta7+7 files now at https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0.
                            massimilianocontiundefined 2 Replies Last reply Reply Quote 0
                              massimilianoconti @dc42
                              perfect thank you very much. now the version works in the installation. I do some tests and let you know
                                massimilianoconti @massimilianoconti
                                This post is deleted!
                                  Firmware 3.4 beta 7+7 solved the heater problem when starting a new print. the heater is fine part good also the bl touch seems to be fine. I do further tests and communicate news
