    error zoffset for bl touch and duet3 firmware 3.4 beta 7+1
    Beta Firmware
    604
      Phaedrux Moderator @massimilianoconti
      @massimilianoconti said in error zoffset for bl touch and duet3 firmware 3.4 beta 7+1:
      could you give me the link to download the firmware 3.4 beta 7+4?
      I did. https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files
      When do you call G32 to do the leveling and loading of the mesh?
      M401 ; Deploy probe - deployprobe.g
      M402 ; Retract Probe - retractprobe.g
      This is not needed with the BLtouch
      massimilianocontiundefined 1 Reply Last reply Reply Quote 0
      • massimilianocontiundefined
        massimilianoconti @Phaedrux
        Thank you. I think it will be uploaded. Printing is fine.anyway how do you see exactly if the mesh is loaded?
          If you send M122 it will have a line for compensation in use. If it says mesh, it is active. If it says none, it is not.
            M122
            RepRapFirmware for Duet 3 MB6HC version 3.4.0beta7+1 (2021-12-22 16:03:36) running on Duet 3 MB6HC v1.01 or later (standalone mode)
            Board ID: 08DJM-9P63L-DJMSS-6J9DD-3S46N-TVFH8
            Used output buffers: 1 of 40 (23 max)
            Static ram: 150664
            Dynamic ram: 95148 of which 164 recycled
            Never used RAM 100928, free system stack 130 words
            Tasks: NETWORK(ready,24.0%,219) ETHERNET(notifyWait,0.1%,169) HEAT(notifyWait,0.0%,324) Move(notifyWait,1.5%,248) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,333) TMC(notifyWait,8.9%,58) MAIN(running,65.4%,925) IDLE(ready,0.0%,30), total 100.0%
            Owned mutexes:
            Last reset 00:24:15 ago, cause: software
            Last software reset at 2022-01-13 22:50, reason: User, GCodes spinning, available RAM 104696, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Aux0 errors 0,0,0
            Step timer max interval 153
            MCU temperature: min 43.9, current 46.7, max 46.9
            Supply voltage: min 23.6, current 23.8, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
            Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
            Events: 0 queued, 0 completed
            Driver 0: pos 206422, ok, SG min 0, mspos 967, reads 52485, writes 17 timeouts 0
            Driver 1: pos 7789, ok, SG min 0, mspos 571, reads 52485, writes 17 timeouts 0
            Driver 2: pos 33670, ok, SG min 0, mspos 641, reads 52485, writes 17 timeouts 0
            Driver 3: pos 0, ok, SG min 0, mspos 620, reads 52485, writes 17 timeouts 0
            Driver 4: pos 0, standstill, SG min 0, mspos 1, reads 52486, writes 17 timeouts 0
            Driver 5: pos 0, standstill, SG min 0, mspos 8, reads 52492, writes 11 timeouts 0
            Date/time: 2022-01-13 23:15:16
            Slowest loop: 32.87ms; fastest: 0.05ms
            === Storage ===
            Free file entries: 9
            SD card longest read time 2.7ms, write time 5.2ms, max retries 0
            • list itemDMs created 125, segments created 38, maxWait 211955ms, bed compensation in use: mesh, comp offset 0.000
              === MainDDARing ===
              Scheduled moves 16146, completed 16101, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
              === AuxDDARing ===
              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Heater 0 is on, I-accum = 0.4
              Heater 1 is on, I-accum = 0.2
              Segments left: 1
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is doing "G1 X167.119 Y158.677 E0.0301" in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty
              === CAN ===
              Messages queued 13102, received 0, lost 0, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 7276/0/0
              Tx timeouts 0,6,7275,0,0,5818 last cancelled message type 30 dest 127
              === Network ===
              Slowest loop: 39.85ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
            • Ethernet -
              State: active
              Error counts: 0 0 1 0 0
              Yes it is active
                perfect. I tried to install version 3.4 beta 7+6 but in the end from an error drive 0
                perfect. I tried to install I think it's the firmware that has something in the wrong installation. I put back the 3.4 beta 7 + 1 and it went immediately fine. version 3.4 beta 7+4 is not present among the downloaded files but only the 3.4 beta 7+6
                • Phaedruxundefined Phaedrux moved this topic from General Discussion
                  dc42 administrators @massimilianoconti
                  @massimilianoconti the spurious error from driver 0 is fixed in the 3.4beta7+7 files now at https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0.
                  massimilianocontiundefined 2 Replies Last reply Reply Quote 0
                    massimilianoconti @dc42
                    perfect thank you very much. now the version works in the installation. I do some tests and let you know
                      massimilianoconti @massimilianoconti
                      This post is deleted!
                        Firmware 3.4 beta 7+7 solved the heater problem when starting a new print. the heater is fine part good also the bl touch seems to be fine. I do further tests and communicate news
