Filament sensor not detecting filament run-out
Filament Monitor
    lildannyoso
    I recently purchased a BigTreeTech Smart Filament sensor and have been trying to get it to work. When testing to see if it would detect a filament run-out, it did not. I double checked my wiring and that seems to be correct, so the issue must be in my config file. here it is:
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 20 2020 19:57:06 GMT-0500 (Central Daylight Time)
    M550 P"Anycubic Predator" ; set printer name
    M665 R227 L440.45 B185 H410 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    M552 P192.168.86.37 S1 ; enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P1 S0 ; physical drive 1 goes forwards
    M569 P3 S0 ; physical drive 3 goes forwards
    M92 X80.00 Y80.00 Z80.00 E415.00 ; set steps per mm
    M566 X1500.00 Y1500.00 Z1500.00 E1500.00 P1 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E10000.00 ; set maximum speeds (mm/min)
    M201 X1500.00 Y1500.00 Z1500.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ; Retraction
    M207 S1.9 F3000 Z0.388 ; Firmware retraction
    M208 Z0 S1 ; set minimum Z
    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
    M591 D0 P7 C"e0stop" L7 R50:200 E15 S0 ; filament sensor connected to e0_stop
    M558 P8 R0.4 C"zprobe.in+zprobe.mod" H10 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
    G31 P100 X0 Y0 Z.1 ; set Z probe trigger value, offset and trigger height
    M557 R180 S20 ; define mesh grid
    M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; disable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
    M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
    M563 P0 S"Hotend" D0 H1 F1 ; define tool 0
    M572 D0 S0.2 ; pressure advance
    M501 ; set the active parameters to those stored in sys/config-override.g
    Any help would be appreciated.
    undefined 1 Reply Last reply 14 Jan 2022, 23:51 Reply Quote 0
      alankilian @lildannyoso
      @lildannyoso said in Filament sensor not detecting filament run-out:
      You've got your filament monitor disabled.
      From the M591 page:
      Sn 0 = disable filament monitoring
      undefined 1 Reply Last reply 15 Jan 2022, 03:12 Reply Quote 1
        lildannyoso @alankilian
        @alankilian Wow such an obvious oversight on my part. It works now!
        undefined 1 Reply Last reply 15 Jan 2022, 14:00 Reply Quote 1
          @lildannyoso
          We've all been there.
          Sometimes the eyes of the author just CANNOT see obvious mistakes.
          I'm glad you got it running!
          4 out of 4
