    Problem with my bed calibration on my modix
    Gcode meta commands
    • ICY_SNAKEundefined
      ICY_SNAKE
      I updated to version 3.3
      here is my macro for leveling but it gives me an error on line 14
      Error: M558: Missing Z probe pin name(s)
      Can someone help me please?
      thx
      Dieter
      M300 S555 P666 ;
      M291 S3 P"Press OK to continue, or CANCEL to abort"
      M300 S1888 P444 ; Beep
      M561
      G28 ; Home
      M561
      G30 P0 X2 Y20 Z-99999 ; Probe near a leadscrew
      G30 P1 X570 Y20 Z-99999 ; Probe near a leadscrew
      G30 P2 X570 Y599 Z-99999 ; Probe near a leadscrew
      G30 P3 X2 Y599 Z-99999 S4 ; Probe near a leadscrew
      M400
      G4 S1
      M300 S1111 P444 ; Beep
      M558 P9 H5 F120 T18000 A1 R0.7
      M400
      M300 S1111 P444
      M291 S3 R"Bed Mapping" P"The printer will now generate a new heightmap of 100 points" ;
      G28
      DO IT OR DON'T
      PCRundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • PCRundefined
        PCR @ICY_SNAKE
        @icy_snake you need the name of the pin in M558.
        Look at the wiki. It's the C paramter
          ICY_SNAKE
          @pcr said in Problem with my bed calibration on my modix:
          Not really sure what it means.
          from th wiki:
          M558 P9 C"^zprobe.in" H5 F120 T3000 ; BLTouch connected to Z probe IN pin
          What is the meaning of "^zprobe.in"
          DO IT OR DON'T
          rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
          • rjenkinsgbundefined
            rjenkinsgb @ICY_SNAKE
            @icy_snake
            It's the configuration name for whatever input you are using; some boards have fixed names for such as the probe and endstops, some use numbers or letters and numbers.
            Look at the connection diagram for whatever Duet board you have and see what it calls the connector your probe is on??
            This is my setup for a BLTouch, connected to I/O7 header on a Duet 6HC board:
            M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
            M558 P9 C"^io7.in" H4 F60 T6000             ; set Z probe type to bltouch and the dive height + speeds
            If it's an input-only probe (switch etc) you don't need the out pin. The probe type needs setting appropriately.
            Robert J.
            Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
              Phaedrux Moderator @ICY_SNAKE
              @icy_snake said in Problem with my bed calibration on my modix:
              You don't need the full M558 line in your macros. If you just want to alter a parameter for speed or whatever you can just include that parameter. Since you've got a M558 P9 there it is expecting you to define the entire line now, but you're missing the pin name.
