Duet3 paneldue 7i status changed connecting to printing
machine data:
firmware 3.4 beta 7+7
duet 3 v 1.01
firmware 3.4 .0 paneldue 7iI see continuous errors( status changed from connecting to printing) in the console and go away and return icons on the home page
I did the reset of the paneldue checked the cables but nothing
Can you show us a screen shot or photo of the errors you're seeing?
hello, I attach the photo
continue without stopping
Are those messages coming at a steady rate or randomly? Do they match what's happening with the printer itself?
they manifest themselves when I launch the print but still the printing proceeds well
I can try to install the paneldue firmware again
very likely something is not working correctly with the communication between RRF and PD. Status connecting is set either on initial connection or connection is lost.
Please check your wiring.
ok I make a new wiring for safety and update
I'm still testing, for now it seems to me that panel two responds well. I created a new cable to connect duet 3 to I 0.0 to panel two. I reserve the right to update the outcome
