Slowing in line with part no extrusion
383
    demonlibra
    Good day.
    Why happening freezes while running this g-code?
    G28 ; Homing
    T0 ; Select tool T0
    M83 ; Extruder to relative mode
    M302 P1 ; Allow cold extrudes
    G1 X20 F9000
    G1 X80 E1 F9000
    ;freeze
    G1 X120 F9000
    G1 X80 E1 F9000
    ;freeze
    G1 X20 F9000
      What do you mean freeze?
      What firmware and duet are you using?
      How are you executing the gcode?
      Can you post your config.g and the results of M122 and M98 P"config.g" please?
        demonlibra
        Speed slowing down between move with and without extrusion.
        Firmware 3.3.
        Executing like any other gcode from duetwebcontrol.
        M122.txt M98.txt
        undefined 1 Reply Last reply 19 Jan 2022, 21:39 Reply Quote 0
          Phaedrux Moderator @demonlibra
          @demonlibra said in Slowing in line with part no extrusion:
          As a print job or a macro?
          Can you post your config.g?
            demonlibra
            Print job
            config.g
            undefined 1 Reply Last reply 19 Jan 2022, 21:48 Reply Quote 0
              alankilian @demonlibra
              @demonlibra
              My extruder has 1/10th the number of steps-per-mm and my extruder speed change is quite a bit larger than yours.
              Maybe your settings are making the extruder run VERY slowly and so the movement needs to be slow also.
              Mine:
              M92 X100.00 Y100.00 Z100.00 E91.00 ; set steps per mm
              M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
              Yours:
              M92 X80 Y80 Z400 E923 ; set steps per mm
              M205 X15 Y15 Z1 E12 ; set max instantaneous speed change (mm/sec)
              M203 X12000 Y12000 Z1800 E2400 ; set maximum speeds (mm/min)
              M201 X2000 Y2000 Z50 E2000 ; set accelerations (mm/s^2)
                demonlibra
                I changed length of extrusion from 1 to 0.001 mm but situation is the same. Get slow down after movement with extrusion and before movement without extrusion.
                You can try to run this code without filament for check:
                G28
                T0
                M83
                M302 P1
                while 1=1
                G1 X80 E0.001 F9000
                ;freeze
                G1 X120 F9000
                G1 X80 E0.001 F9000
                ;freeze
                G1 X20 F9000
                  demonlibra
                  Looks like the problem resolved in 3.4 beta
                  5 out of 8
