    My print is too much tall
    Firmware installation
    • Arisoyundefined
      Arisoy
      Can someone explain me why my cube is not... a cube...
      Leadscrew are TR8*8 and this is my parameter in config.g :
      M92 X80.00 Y80.00 Z800.00
      Is this line false? Is it something else?
      jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Arisoy
        @arisoy try Z400
          deckingman @Arisoy
          @arisoy To expand on what @jay_s_uk has said.....assuming your stepper is a "normal" 1.8 degree motor, then it has 200 full steps per revolution. A TR8 screw has a lead of 8mm meaning that a nut positioned on the screw will travel 8mm in one revolution - or in your case, the Z axis will travel 8mm for one revolution of the screw. So we have 8mm = 200 full steps therefore 1mm will be 25 full steps. Assuming you use 16x micro-stepping that's 400 (25 x 16) steps per mm.
          Arisoyundefined 1 Reply Last reply Reply Quote 2
          • Arisoyundefined
            Arisoy @deckingman
            @deckingman Thanks for your explanation. I did the calculation too but somehow i miss something...
            Thanks a lot everything is working fine now 🙂
              deckingman @Arisoy
              @arisoy Glad you got it sorted. Maybe you did the calculation for 0.9 degree steppers? - They have 400 full steps per revolution which would be 50 full steps per mm, so 800 would be correct for a 0.9 degree motor.
