How To Update Splashscreen On PD3.4.0?
Hi all,
Just wondering what the process is for updating the splash screen on the new firmware. I had a custom logo way back in time when 1.xx was the goto, and I was wondering how the process of updating it has changed.
I tried the old method with the bmp2c and command line, but no dice.
Kind regards
N -
I don't think the process has changed. What happens when you try the bmp2c tool?
@Phaedrux Starting fresh so each step is visible:
Starting with only 2 things in an empty workspace environment. 1) bmp2c.exe 2)DuetSplashScreen.bmp
Open CMD at target location and: bmp2c -binary -outfile ConstructLogo.bin ConstructLogo.bmp
Produces loverly ConstructLogo.bin in the target file
download PanelDueFirmware-3.4.0-v3-7.0.bin so its nice and fresh
run: bmp2c copy /b PanelDueFirmware-3.4.0-v3-7.0.bin+ConstructLogo.bin PanelDueFirmware.bin
panic: open copy: The system cannot find the file specified.
goroutine 1 [running]:
main.main()
/home/manuel/Sync/3DP/github/PanelDueFirmware/Tools/gobmp2c/bmp2c.go:46 +0x12b6
So I think the name of the file may be the issue, so I will rename PanelDueFirmware-3.4.0-v3-7.0.bin -> PanelDueFirmware.bin but the same error appears.
hope this helps.
Are you using an administrator command line prompt?
@phaedrux Yes I am. at first I wasn't but I just tried again, no dice.
