Duet3d 6HC Silicone Heat Bed Config
Hi everyone! I apologize, i speak spanish.
I need help configuring my printer heat bed, i have a 110V 310x310 750w silicone bed installed, I use an SSR with it, the problem is that when I set the temperature my board shot down the bed because it says (Heater 0 fault: temperature rising too slowly: expected 2.27°C/sec measured 0.78°C/sec) but as far I can see temperature rises just fine, what I need to do to change that configuration and give more time before shootdown my heat bed? -
You need to perform heater tuning. See the link below for additional information.
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control -
@alex-cr thanks, i gonna check that, the problem is that I'm new with macros and the hole RepRap thin, hopefully, I can understand
