    DCS Not Started
    Duet Web Control
    690
      Do you have a different pi to test with?
      kzobarlowundefined 1 Reply Last reply Reply Quote 0
      • sonderzugundefined
        sonderzug @kzobarlow
        @kzobarlow sorry, must have remembered wrongly. I might have had the cable plugged in backwards to the Pi but that doesn't seem the case with your setup.
        • kzobarlowundefined
          kzobarlow @Phaedrux
          @phaedrux
          not on hand but may try it at this point
            kzobarlow
            Upgraded/Changed to a Raspberry Pi 4 Model B and still getting the same error as before....
            Edit:
            SD Card was re flashed before doing anything
              Thanks for testing with a new Pi. Can you confirm that you reflashed with the latest Duet Pi image download?
              If you enable logging again do you get the same errors?
                kzobarlow @Phaedrux
                @phaedrux
                Yes SD card was re-flashed with the latest image
                This is what I got running $ sudo journalctl -u duetcontrolserver -e
                pi@duet3:~ $ sudo journalctl -u duetcontrolserver -e
                Jan 31 19:48:24 duet3 DuetControlServer[10320]: [fatal] Could not connect to Due
                Jan 31 19:48:24 duet3 systemd[1]: duetcontrolserver.service: Failed with result
                Jan 31 19:48:24 duet3 systemd[1]: Failed to start Duet Control Server.
                Jan 31 19:48:24 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
                Jan 31 19:48:24 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
                Jan 31 19:48:24 duet3 systemd[1]: Stopped Duet Control Server.
                Jan 31 19:48:24 duet3 systemd[1]: Starting Duet Control Server...
                Jan 31 19:48:25 duet3 DuetControlServer[10354]: Duet Control Server v3.3.0
                Jan 31 19:48:25 duet3 DuetControlServer[10354]: Written by Christian Hammacher f
                Jan 31 19:48:25 duet3 DuetControlServer[10354]: Licensed under the terms of the
                Jan 31 19:48:25 duet3 DuetControlServer[10354]: [info] Settings loaded
                Jan 31 19:48:25 duet3 DuetControlServer[10354]: [info] Environment initialized
                Jan 31 19:48:26 duet3 DuetControlServer[10354]: [fatal] Could not connect to Due
                Jan 31 19:48:26 duet3 systemd[1]: duetcontrolserver.service: Failed with result
                Jan 31 19:48:26 duet3 systemd[1]: Failed to start Duet Control Server.
                Jan 31 19:48:26 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
                Jan 31 19:48:26 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
                Jan 31 19:48:27 duet3 systemd[1]: Stopped Duet Control Server.
                Jan 31 19:48:27 duet3 systemd[1]: Starting Duet Control Server...
                Jan 31 19:48:28 duet3 DuetControlServer[10387]: Duet Control Server v3.3.0
                Jan 31 19:48:28 duet3 DuetControlServer[10387]: Written by Christian Hammacher f
                Jan 31 19:48:28 duet3 DuetControlServer[10387]: Licensed under the terms of the
                lines 980-1001/1001 (END)
                  Have you tested the Duet in standalone mode to see if it's otherwise functional? What firmware is flashed on it?
                  Is the touch screen powered by it's own supply?
                  • chrishammundefined
                    chrishamm administrators @kzobarlow
                    @kzobarlow Please use journalctl -u duetcontrolserver -e --no-pager because the error mesage is truncated. If it is the same "Cannot put line into event mode" error message (also truncated before), it indicates that something keeps blocking a required GPIO pin.
                    If this is the case, please run the following commands:
                    sudo systemctl stop duetcontrolserver
                    sudo gpioinfo
                    If you get an error invoking gpioinfo, try installing gpiod (sudo apt install gpiod) first. The line starting with line 25 shows you which program blocks access to the GPIO pin.
                    Duet software engineer
                      kzobarlow @Phaedrux
                      @phaedrux
                      Yes I tested it without the Pi connected and was able to interact with it through my browser
                      The touch screen is powered by the pi but I switched to a PC monitor powered independently so I can see the terminal screen better but still have the same problem
                        kzobarlow @chrishamm
                        @chrishamm
                        Result from journalctl -u duetcontrolserver -e --no-pager
                        eb 01 21:08:04 duet3 DuetControlServer[21900]: Duet Control Server v3.3.0
                        Feb 01 21:08:04 duet3 DuetControlServer[21900]: Written by Christian Hammacher for Duet3D
                        Feb 01 21:08:04 duet3 DuetControlServer[21900]: Licensed under the terms of the GNU Public License Version 3
                        Feb 01 21:08:05 duet3 DuetControlServer[21900]: [info] Settings loaded
                        Feb 01 21:08:05 duet3 DuetControlServer[21900]: [info] Environment initialized
                        Feb 01 21:08:06 duet3 DuetControlServer[21900]: [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin)
                        Feb 01 21:08:06 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
                        Feb 01 21:08:06 duet3 systemd[1]: Failed to start Duet Control Server.
                        Feb 01 21:08:06 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
                        Feb 01 21:08:06 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 623.
                        Feb 01 21:08:06 duet3 systemd[1]: Stopped Duet Control Server.
                        Feb 01 21:08:06 duet3 systemd[1]: Starting Duet Control Server...
                        After tying this
                        sudo gpioinfo
                        pi@duet3:~ $ sudo gpioinfo
                        gpiochip0 - 58 lines:
                        	line   0:     "ID_SDA"       unused   input  active-high
                        	line   1:     "ID_SCL"       unused   input  active-high
                        	line   2:       "SDA1"       unused   input  active-high
                        	line   3:       "SCL1"       unused   input  active-high
                        	line   4:  "GPIO_GCLK"       unused   input  active-high
                        	line   5:      "GPIO5"       unused   input  active-high
                        	line   6:      "GPIO6"       unused   input  active-high
                        	line   7:  "SPI_CE1_N"   "spi0 CS1"  output   active-low [used]
                        	line   8:  "SPI_CE0_N"   "spi0 CS0"  output   active-low [used]
                        	line   9:   "SPI_MISO"       unused   input  active-high
                        	line  10:   "SPI_MOSI"       unused   input  active-high
                        	line  11:   "SPI_SCLK"       unused   input  active-high
                        	line  12:     "GPIO12"       unused   input  active-high
                        	line  13:     "GPIO13"       unused   input  active-high
                        	line  14:       "TXD1"       unused   input  active-high
                        	line  15:       "RXD1"       unused   input  active-high
                        	line  16:     "GPIO16"       unused   input  active-high
                        	line  17:     "GPIO17"       unused   input  active-high
                        	line  18:     "GPIO18"       unused   input  active-high
                        	line  19:     "GPIO19"       unused   input  active-high
                        	line  20:     "GPIO20"       unused   input  active-high
                        	line  21:     "GPIO21"       unused   input  active-high
                        	line  22:     "GPIO22"       unused   input  active-high
                        	line  23:     "GPIO23"       unused   input  active-high
                        	line  24:     "GPIO24"       unused   input  active-high
                        	line  25:     "GPIO25"       unused   input  active-high
                        	line  26:     "GPIO26"       unused   input  active-high
                        	line  27:     "GPIO27"       unused   input  active-high
                        	line  28: "RGMII_MDIO"       unused   input  active-high
                        	line  29:  "RGMIO_MDC"       unused   input  active-high
                        	line  30:       "CTS0"       unused   input  active-high
                        	line  31:       "RTS0"       unused   input  active-high
                        	line  32:       "TXD0"       unused   input  active-high
                        	line  33:       "RXD0"       unused   input  active-high
                        	line  34:    "SD1_CLK"       unused   input  active-high
                        	line  35:    "SD1_CMD"       unused   input  active-high
                        	line  36:  "SD1_DATA0"       unused   input  active-high
                        	line  37:  "SD1_DATA1"       unused   input  active-high
                        	line  38:  "SD1_DATA2"       unused   input  active-high
                        	line  39:  "SD1_DATA3"       unused   input  active-high
                        	line  40:  "PWM0_MISO"       unused   input  active-high
                        	line  41:  "PWM1_MOSI"       unused   input  active-high
                        	line  42: "STATUS_LED_G_CLK" "led0" output active-high [used]
                        	line  43: "SPIFLASH_CE_N" unused input active-high
                        	line  44:       "SDA0"       unused   input  active-high
                        	line  45:       "SCL0"       unused   input  active-high
                        	line  46: "RGMII_RXCLK" unused input active-high
                        	line  47: "RGMII_RXCTL" unused input active-high
                        	line  48: "RGMII_RXD0"       unused   input  active-high
                        	line  49: "RGMII_RXD1"       unused   input  active-high
                        	line  50: "RGMII_RXD2"       unused   input  active-high
                        	line  51: "RGMII_RXD3"       unused   input  active-high
                        	line  52: "RGMII_TXCLK" unused input active-high
                        	line  53: "RGMII_TXCTL" unused input active-high
                        	line  54: "RGMII_TXD0"       unused   input  active-high
                        	line  55: "RGMII_TXD1"       unused   input  active-high
                        	line  56: "RGMII_TXD2"       unused   input  active-high
                        	line  57: "RGMII_TXD3"       unused   input  active-high
                        gpiochip1 - 8 lines:
                        	line   0:      "BT_ON"       unused  output  active-high
                        	line   1:      "WL_ON"       unused  output  active-high
                        	line   2: "PWR_LED_OFF" "led1" output active-low [used]
                        	line   3: "GLOBAL_RESET" unused output active-high
                        	line   4: "VDD_SD_IO_SEL" "vdd-sd-io" output active-high [used]
                        	line   5:   "CAM_GPIO"       unused  output  active-high
                        	line   6:  "SD_PWR_ON" "sd_vcc_reg"  output  active-high [used]
                        	line   7:    "SD_OC_N"       unused   input  active-high
                        pi@duet3:~ $ ^C
                        If I'm seeing this right... I don't see anything that's tied to 25?
                          @kzobarlow That's a different error message now. Please ensure you do not have a microSD card in the Duet.
                            @chrishamm
                            No SD card is present in the Duet Mini board
                              kzobarlow
                              So again.... if I'm seeing this right "GPIO25" reads unused still and unless I'm missing something don't see anything getting blocked?
                                @kzobarlow Does the DIAG LED on the Duet blink or is it dimmed? Do you have firmware 3.3 installed on the board? If in doubt, you can flash it again. You can find firmware version 3.3 here ( Duet3Firmware_Mini5plus.uf2).
                                If you have a multimeter, you can also check continuity between pin 22 of the Pi and Duet. When you're at it, you could check pin 17 as well, because that signal is required for SPI comms, too.
                                  @chrishamm
                                  Still getting DCS Error...
                                  "Does the DIAG LED on the Duet blink or is it dimmed?"
                                  • Not sure which one that is, looking at the wiring diagram LED V FUSED and LED 12V are the only ones active and showing a solid light.
                                  • All other lights LED ACT, LED STATUS, LED +5V, and LED +3.3V do not turn on even during powering on the PSU
                                  • Again Pi is powered by an independent 5V PSU and Mini is powered by a 24 PSU
                                  "Do you have firmware 3.3 installed on the board?"
                                  • Yes checked with M115
                                  • Reflashed using Fallback procedure #1 and Fallback procedure #2
                                  • SD Card was removed after confirming again with YAT RRF is up to date
                                  "If you have a multimeter, you can also check continuity between pin 22 of the Pi and Duet. When you're at it, you could check pin 17 as well, because that signal is required for SPI comms, too."
                                  • Checked with a multimeter and continuity is fine for both pins
                                  Trying terminal again
                                  Feb 06 22:19:30 duet3 DuetControlServer[4022]: Duet Control Server v3.3.0
                                  Feb 06 22:19:30 duet3 DuetControlServer[4022]: Written by Christian Hammacher for Duet3D
                                  Feb 06 22:19:30 duet3 DuetControlServer[4022]: Licensed under the terms of the GNU Public License Version 3
                                  Feb 06 22:19:30 duet3 DuetControlServer[4022]: [info] Settings loaded
                                  Feb 06 22:19:31 duet3 DuetControlServer[4022]: [info] Environment initialized
                                  Feb 06 22:19:31 duet3 DuetControlServer[4022]: [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin)
                                  Feb 06 22:19:31 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
                                  Feb 06 22:19:31 duet3 systemd[1]: Failed to start Duet Control Server.
                                  Feb 06 22:19:32 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
                                  Feb 06 22:19:32 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 87.
                                  Feb 06 22:19:32 duet3 systemd[1]: Stopped Duet Control Server.
                                  Feb 06 22:19:32 duet3 systemd[1]: Starting Duet Control Server...
                                  pi@duet3:~ $ gpioinfo
