    Question regarding MAC address
    Beta Firmware
    323
    • user M_123undefined
      user M_123
      hello i am using firmware version 3.4beta 3 but now i am update firmware to 3.4beta 5 so mac address is changed but i am using same board is it possible that MAC address will changed??.
      ->MAC for beta3 is=be:7b:50:3e:51:37
      ->MAC for beta5 is=be:4e:50:3e:51:37
        jay_s_uk @user M_123
        @user-m_123 yes, its in the change notes
        user M_123undefined 1 Reply Last reply Reply Quote 0
          user M_123 @jay_s_uk
          @jay_s_uk ok
          • jens55undefined
            jens55
            Strange, I always thought that mac addresses are hard coded to the particular device and there was no way of changing it. (yes it can be temporarily overwritten via software)
            Do you have a link to that change note (I was unable to find it)
            The reason I am curious is because my printers are assigned IP numbers based on their MAC address and I can see holy hell happening if MAC id's are changed nilly willy ....
            achrnundefined 1 Reply Last reply Reply Quote 0
            • achrnundefined
              achrn @jens55
              @jens55 https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#reprapfirmware-340rc1 penultimate bullet under the first list under that heading.
              MAC addresses are less immutable than most people think. Some routers hold it only in firmware and there's no hard-coding / burning into hardware. They aren't unique either - manufacturers can recycle them. The uniqueness and immutability is more custom than standards, I believe.
              Having said which, it is pretty well observed custom, so I assume there's a good reason for the changes it in this case.
              jay_s_ukundefined jens55undefined user M_123undefined 3 Replies Last reply Reply Quote 0
                jay_s_uk @achrn
                @achrn the change was it wasn't calculating the MAC address correctly, allowing 2 or more of the same device on a network having the same MAC address
                • jens55undefined
                  jens55 @achrn
                  @achrn, thanks for link and explanation ..... most interesting!
                  • dc42undefined dc42 marked this topic as a question
                  • dc42undefined dc42 has marked this topic as solved
                    user M_123 @achrn
                    @jay_s_uk @achrn thank u
