Storing the Z offset value
    DR8
    I'm running 1.18 firmware and I'm wondering how can I store the Z offset value. Now I use the Slic3r function to do this but I want to store the value in the firmware. My currently offset value is 1.8 mm
    Thanks!
    P.S. What config.json file is good for? Something bad will happend if I will delete it?
      Motalw
      You can set it with G31 in your config.g
      https://duet3d.com/wiki/G-code#G31:_Set_or_Report_Current_Probe_status
      about the config.json , When using the RRF configuration tool you can create your own individual configuration by creating a new one from scratch or by loading an existing JSON (Config.json) template:
        DR8
        So if I have this:
        G31 P600 X0 Y18.5 Z2.5 ; Set Z probe trigger value, offset and trigger height
        should I change like this?
        G31 P600 X0 Y18.5 Z4.3 ; Set Z probe trigger value, offset and trigger height
        because in the slic3r the Z offset is 1.8mm
          DR8
          so actually it should be
          G31 P600 X0 Y18.5 Z0.7 ; Set Z probe trigger value, offset and trigger height
          and now it works.
          For those who still don't understand read this very helpfull article :
          http://www.sublimelayers.com/2017/05/fdffsd.html
          Topic can be close now. Thanks!
            stephenc
            DR8 do you then set the Z offset to 0 in your slic3r?
            Stephen
            https://github.com/stephenci/ZideX
            2 out of 5
