    Extruder reporting 2000C
    Beta Firmware
    • moth4017undefined
      moth4017
      just cam back to my printer while in idle the Extruder was reporting the hot end at 2000 C,
      99944759-0820-4c84-941a-5a931b15654e-image.png nit sure why , but just thought ill let you no, buy the way the actual extruder was at room temperature
      SIamundefined bbergerundefined 2 Replies Last reply Reply Quote 0
      • SIamundefined
        SIam @moth4017
        @moth4017 Check your cable crimp connectors and thermistor
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • bbergerundefined
          bberger @moth4017
          @moth4017 said in Extruder reporting 2000C:
          What board and which firmware? Also which temperature sensor? My PT100 pretty much failed shortly after switching to 3.4 RC1 - coincidence or symptom?
          • moth4017undefined
            moth4017
            Duet3 + Mini 5 , thermistor in the heat block , all connections are ok just done another print all ok
            moth4017undefined 1 Reply Last reply Reply Quote 0
            • moth4017undefined
              moth4017 @moth4017
              just happend againg , i will see if i can track it down
