Solved Help to get Bltouch running :(
Hi all, I'm getting a headache making my Bltouch 3.1 running on my Duetwifi 2. I followed this guide and connected the Bltouch and made the changes according to it, but when I'm testing it's not working properly.
Note: both my Duetwifi2 and Bltouch3.1 are original.
I want to use Bltouch for homming Z and bed probing.
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Dec 18 2021 14:22:20 GMT+0100 (Central European Standard Time); General preferences
M550 P"RK3D Tool Changer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M92 X80.00 Y80.00 Z800.00 E2208.00:2208.00 ; set steps per mm
M566 X900.00 Y900.00 Z30.00 E40.00:40.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z960.00 E4800.00:4800.00 ; set maximum speeds (mm/min)
M201 X10000.00 Y10000.00 Z50.00 E1200.00:1200.00 ; set accelerations (mm/s^2)
M906 X1100 Y1100 Z1500 E400:400 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X430 Y365 Z430 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure Z-probe endstop for low end on Z; Z-Probe
M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input
;M558 P5 C"zstop" H2 F120 T15000 ; Z probe connected to Z endstop input
; set Z probe type to switch and the dive height + speeds
M558 P9 C"^zprobe.in" H5 F120 T6000 ; Duet 2 WiFi/Ethernet, DueX2/5M950 S0 C"exp.heater3" ; Duet 2 WiFi/Ethernet
M307 H3 A-1 C-1 D-1
M558 P9 H5 F100 T2000
G31 X0 Y0 Z0 P25G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:385 Y40:300 S40 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S280 ; set temperature limit for heater 2 to 280C; Fans
M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Left0.6mm" D0 H1 F0 ; define tool 0
G10 P0 X0 Y0 Z-1.7 ; set tool 0 axis offsets
M563 P1 S"Right0.4mm" D1 H2 F0 ; define tool 1
G10 P1 X0 Y0 Z-1.8 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
M501
; config-override.g file generated in response to M500 at 2021-12-18 18:15
; Heater model parameters
M307 H0 R0.236 C321.589:321.589 D3.52 S1.00 V24.5 B0 I0
M307 H1 R3.055 C180.783:180.783 D6.59 S1.00 V24.5 B0 I0
M307 H2 R2.831 C250.719:250.719 D8.02 S1.00 V24.5 B0 I0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00deployprobe.g
1
M280 P0 S10retractprobe.g
1
M280 P0 S90 -
What exactly is happening or not happening?
Please post the results of M122 and M98 P"config.g"
Please post your homeall.g and homez.g files.
Does M401 and M402 work to reploy and retract the pin?
your config has a mix of RRF2 and RRF3 commands.
Assuming you are on RRF3 clean up this section
; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure Z-probe endstop for low end on Z ; Z-Probe M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input ;M558 P5 C"zstop" H2 F120 T15000 ; Z probe connected to Z endstop input ; set Z probe type to switch and the dive height + speeds M558 P9 C"^zprobe.in" H5 F120 T6000 ; Duet 2 WiFi/Ethernet, DueX2/5 M950 S0 C"exp.heater3" ; Duet 2 WiFi/Ethernet M307 H3 A-1 C-1 D-1 M558 P9 H5 F100 T2000 G31 X0 Y0 Z0 P25 G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height M557 X15:385 Y40:300 S40 ; define mesh grid
to look like this
; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop ; Z-Probe M950 S0 C"exp.heater3" ; Duet 2 WiFi/Ethernet M558 P9 C"^zprobe.in" H5 F120 T6000 ; Duet 2 WiFi/Ethernet, DueX2/5 G31 X0 Y0 Z0 P25 M557 X15:385 Y40:300 S40 ; define mesh grid
Thanks for the reply!
M401 and M402 does nothing. The Bltouch is lighting red. If I send "M280 P0 S10" the prob deploys, if i touch it Bltouch starts blinking and doesn't respond then.
I disabled the lines you mentioned.M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 08DGM-956GU-DJMSJ-6J9F6-3SD6J-9VPHG
Used output buffers: 3 of 24 (12 max)
Static ram: 23876
Dynamic ram: 75600 of which 0 recycled
Never used RAM 14940, free system stack 184 words
Tasks: NETWORK(ready,13.8%,236) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.4%,443) IDLE(ready,0.7%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:02:15 ago, cause: software
Last software reset at 2022-02-13 09:14, reason: User, GCodes spinning, available RAM 14940, slot 1
Error status: 0x00
Step timer max interval 0
MCU temperature: min 20.9, current 22.1, max 23.0
Supply voltage: min 24.5, current 24.6, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2022-02-13 09:16:25
Slowest loop: 4.51ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.1ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 157.98ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address 5c:cf:7f:76:63:fc
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 19136
WiFi IP address 192.168.3.20
WiFi signal strength -76dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23
Error: Missing Z probe pin name(s)
Error: Invalid Z probe index
Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 577C
Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 734C
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H2 Z5 F18000 ; lift Z relative to current position
G1 H1 X-999 F1800
G1 H1 Y-999 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-999 ; home X axis
G1 H1 Y-999 ; home Y axis
G1 X5 Y5 F18000 ; go back a few mm
G1 H1 X-999 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-999 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X15 Y40 F18000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F300 ; lift Z relative to current position
;G90 ; absolute positioning
; homez.g
; called to home the Z axis
;G1 H2 Z5 F18000 ; lift Z relative to current position
;G1 X15 Y40 F18000 ; go to first probe point
;G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G90 ; absolute positioning; generated by RepRapFirmware Configuration Tool on Tue Jun 05 2018 01:10:26 GMT+0200 (CEST)
G1 Z5 F1000 H2 ; lift Z relative to current position
G1 H1 X-450 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-450 ; home X axis
G1 H1 Y-355 ; home Y axis
G1 H1 X-450 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-355 ; then move slowly to Y axis endstop
G1 X50 Y45 F18000 ;
G1 H1 Z-450 F100 S1 ; move Z down stopping at the endstop
G92 Z0 ; set new Z position
G1 Y45 F18000
G1 Z5 F300 H2 ; uncomment this line to lift the nozzle after homing
- WiFi -
@phaedrux
I'm making progress, I changed to the following:; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:385 Y40:300 S40 ; define mesh gridAnd now I'm able to use M401 and M402. When I home Z the sensor trigger and stops the bed. I guess now I should use M401 and M402 manually to deploy and retract before and after each homing and probbing? Or is there an easy way to do that automatically?
You don't need to use M401 and M402 manually. They get used by G30 automatically to reploy and retract the pin.
Your homez should match your homeall for homing the Z axis. Right now it's using an endstop that doesn't exist.
Uncomment all this
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Dec 18 2021 14:22:20 GMT+0100 (Central European Standard Time) ;G91 ; relative positioning ;G1 H2 Z5 F18000 ; lift Z relative to current position ;G90 ; absolute positioning ;G1 X15 Y40 F18000 ; go to first probe point ;G30 ; home Z by probing the bed
And delete the rest in homez
I wonder about the first lines in both your deployprobe.g and a retractprobe.g files. I'm not sure if the "1" will cause an error that makes the rest of the file get skipped.
Thanks for the input, the probe is now working without farther changes.
