    Mesh Bed Compensation: Z axis not working during print
    • dgratundefined
      dgrat
      I performed a mesh bed compensation and started a print. I expected to see the z-axis spinning slightly while printing (~0.1 mm). But it is not. Am I missing something?
        Please send M122 during a print to see if mesh compensation is actually active.
        I will only be active after a mesh is created (G29 S0) or when the mesh has been loaded (G29 S1).
        The amount of movement can be subtle.
        You'd have to share more of your gcode files for us to see what the machine state is like at the start of a print.
        • dgratundefined
          dgrat
          I tested by editing of the heightmap. I think the motor is working but missing microsteps.
          Guess the combination of T8-8 spindle with 1.8° stepper is insufficient for compensating minor height differences.
            What is your steps per mm?
            Can you share your config.g?
            dgratundefined 1 Reply Last reply Reply Quote 0
            • dgratundefined
              dgrat @Phaedrux
              @phaedrux
              ; generated by RepRapFirmware Configuration Tool v2.1.4 on Mon Dec 09 2019 20:31:57 GMT+0100 (Mitteleuropäische Normalzeit)
              G90                                     ; send absolute coordinates...
              M83                                     ; ...but relative extruder moves
              M550 P"Ender"                           ; set printer name
              ; Panel Due
              M575 P1 S1 B57600
              M667 S0                                 ; select Cartesian mode
              M552 S1                                 ; enable network
              M586 P0 S1                              ; enable HTTP
              M586 P1 S0                              ; disable FTP
              M586 P2 S0                              ; disable Telnet
              M569 P0 S1                              ; physical drive 0 goes forwards
              M569 P1 S1                              ; physical drive 1 goes forwards
              M569 P2 S1                              ; physical drive 2 goes forwards
              M569 P3 S1                              ; physical drive 3 goes forwards
              M584 X0 Y1 Z2 E3                        ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
              M92 X80 Y80 Z400 E830                   ; set steps per mm
              M566 X1200 Y1200 Z120 E3000             ; set maximum instantaneous speed changes (mm/min)
              M203 X12000 Y12000 Z3000 E3000          ; set maximum speeds (mm/min)
              M201 X5000 Y5000 Z120 E3000             ; set accelerations (mm/s^2)
              M906 X1200 Y1200 Z1200 E800 I30         ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                 ; Set idle timeout
              M208 X0 Y0 Z0 S1                        ; set axis minima
              M208 X225 Y225 Z220 S0                  ; set axis maxima
              M574 X1 S1 P"xstop"                        ; Set active high and disabled endstops
              M574 Y1 S1 P"ystop"                        ; Set active high and disabled endstops
              M574 Z2 S1 P"zstop"                        ; Set active high and disabled endstops
              ; Disable heaters H3-H7 to free up pins
              M950 H3 C"nil"
              M950 H4 C"nil"
              M950 H5 C"nil"
              M950 H6 C"nil"
              M950 H7 C"nil"
              M950 S0 C"exp.heater3"                  ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H8 F150 T6000     ; Set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z5.04                    ; Set Z probe trigger value, offset and trigger height Z+ pousouva osu Z smerem dolu k podlozce (stará tisková hlava X7.9 Y58.8)
              M557 X40:220 Y00:180 S20                ; Define mesh grid
              M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 		; define bed temperature sensor
              M950 H0 C"bed_heat" T0 			        ; heater 0 uses the bed_heat pin, sensor 0
              M143 H0 S120                            ; Set temperature limit for heater 0 to 120C
              M307 H0 S1.00 V23.9
              M140 H0
              M308 S1 P"e0_temp" Y"pt1000"
              M950 H1 C"e0_heat" T1 			        ; heater 1 uses the e0_heat pin and sensor 1
              M143 H1 S265                                ; Set temperature limit for heater 1 to 240C
              M307 H1 A271.1 C122.4 D24.0 S0.25 V24 B0    ; limit the hotend heater to 25% power
              M950 F0 C"fan0" Q500
              M106 P0 S0.0 I0 H-1 C"Print Fan"       	; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M950 F1 C"fan1" Q500
              M106 P1 T50 H1 C"Hotend Fan"            ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M950 F2 C"fan2" Q500
              M106 P2 T50 H1 C"Case Fan"              ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M563 P0 D0 H1 F0                        ; define tool 0
              G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
              G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
              ; enable: config-override.g
              M501
              • dgratundefined
                dgrat @dgrat
                @dgrat I found the issue. I forgot to set the X/Y offset of my sensor. It was correcting for the wrong spot..
                • Phaedruxundefined Phaedrux has marked this topic as solved
