    Extruder goes too fast sometimes with Cura and other slicing sw….
    • flopoundefined
      flopo
      Hi everyone.
      I modified a 3d printer FLSUN all-metal; I mounted the DUET WIFI, smart effector and a magnetic rod.
      When I start printing my extruder filament goes very fast.
      I use Cura 2.5 for slicing.
      I've copied the settings from the original Marlin firmware FLSUN but I can't figure out what I'm doing wrong; do I also need to put M83 in start gcode?
      All the other settings work well, there are some STL files that work well for the extruder. I can't understand why with Cura my extruder sometimes doesn't work properly.
      Ciao a tutti,
      Ho modificato una Flsun All Metal,ho montato Duet Wifi,Smart Effector,carbon fiber magnetic rod.Qunado preparo la stampa on Cura 2.5 ho versioni precedenti,tante volte il mio extruder gira molto velocequando inizia la stampa,ho impostato correttamente gli steps,copiandoli dal firmware originale Marlin con quale e arrivata la stampante.
      Ci sono file stl che funzionano bene.
      Grazie.
      • Willy510undefined
        Willy510
        Try putting an M82 not M83 in your start code and that should fix it
        • flopoundefined
          flopo
          @Willy510:
          Yeah works…..I haven't thought about it....damn.....Thank you
