generic.heater.states.disconnected
Long time no see gentlemen....
I managed to install my old duet wifi 2 on a friends Creality CR20 pro.
There are some problems to b solved. Starting with extruder heater.Extruder heater cannot be controlled. It says
'' generic.heaterStates.disconnected ''
I ran the M303 command and the heater did turn on and was calibrated accordingly.
However, I cannot turn on or off the heater. I haven't tried printing with it.I have to solve this problem first so I can move onto the next one, which is fan control, they always stay on, no matter what....
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Feb 20 2022 02:24:30 GMT+0200 (Eastern European Standard Time); General preferences
M550 P"Print Machine" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M350 X32 Y32 Z32 E32 I0 ; configure microstepping without interpolation
M92 X200 Y200 Z400 E420.00 ; set steps per mm
M208 X195 Y195 Z250 S0 ; set axis maxima; Endstops
M574 X1 Y2 S1 ; set active high endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T3000 ; BLTouch connected to Z probe IN pin
M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector
M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
G31 P500 X-20 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M106 P0 S1 I1 F500 H1 T50 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I1 F500 H1 T50 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0Cm501
@cozyp said in generic.heater.states.disconnected:
'' generic.heaterStates.disconnected ''Where and when does it say that?
What firmware version? The config looks like RRF2 style, but what does M122 report? Might be a good time to update to RRF3 with a fresh config.
@phaedrux everything solved on updating to latest firmware. I'm deleting this post
