Solved Change G30 Z drop to 5mm instead of 15mm
I've got a HeVORT, with a 3 Z Axis. It's working fine. But due to the size and weight of the bed (440 x 440) MIC Al plate and 6mm glass, I slowed the z down some
When I run auto-level, it works fine, but drops the Z down 15mm then does the level touch (BLTouch).
Is there a way I can instead just have it drop 5mm instead of 15mm, just so it finishes quicker.
G30 P0 X30.1 Y88.5 Z-99999 ; probe near a leadscrew
G30 P1 X30.1 Y425.5 Z-99999 ; probe near a leadscrew
G30 P2 X380.1 Y425.5 Z-99999 ; probe near a leadscrew
G30 P3 X380.1 Y88.5 Z-99999 S3; probe near a leadscrewThanks.
Michael
Post your full config.g please. You'll probably want to change the dive height for the probe found in the M558 H
@phaedrux friend, you just gave me exactly what I needed. It's the M558 command. I can totally sort it out from there.
Michael
