RRF3.4 RC2 Filament/sensor error
Beta Firmware
2.0k
    BoA
    I updated to 3.4rc2, and I am getting some random filament sensor error.
    Duet3 standalone
    RepRapFirmware for Duet 3 MB6HC version 3.4.0rc2 (2022-02-22 17:04:17) running on Duet 3 MB6HC v1.01 or later (standalone mode)
    Board ID: 08DJM-956L2-G43S8-6J1D6-3SJ6R-KA0YG
    Used output buffers: 9 of 40 (27 max)
    Static ram: 150984
    Dynamic ram: 98404 of which 0 recycled
    Never used RAM 81388, free system stack 130 words
    Tasks: NETWORK(ready,23.3%,199) ETHERNET(notifyWait,0.1%,168) HEAT(notifyWait,0.1%,321) Move(notifyWait,0.8%,254) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,333) TMC(notifyWait,8.7%,58) MAIN(running,67.1%,1016) IDLE(ready,0.0%,30), total 100.0%
    Owned mutexes: LwipCore(NETWORK)
    Last reset 00:29:09 ago, cause: power up
    Last software reset at 2022-03-06 15:52, reason: User, GCodes spinning, available RAM 81480, slot 1
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
    Error status: 0x00
    Aux0 errors 0,0,0
    Step timer max interval 135
    MCU temperature: min 20.6, current 45.6, max 45.9
    Supply voltage: min 5.2, current 27.2, max 27.5, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 4.5, current 12.2, max 12.3, under voltage events: 0
    Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/30/0, gc cycles 0
    Events: 1 queued, 1 completed
    Driver 0: pos 15715, ok, SG min 0, mspos 926, reads 20833, writes 22 timeouts 0
    Driver 1: pos 21332, standstill, SG min 0, mspos 984, reads 20834, writes 22 timeouts 0
    Driver 2: pos 893, ok, SG min 0, mspos 314, reads 20842, writes 14 timeouts 0
    Driver 3: pos 0, standstill, SG min 0, mspos 8, reads 20845, writes 11 timeouts 0
    Driver 4: pos 0, ok, SG min 0, mspos 186, reads 20838, writes 18 timeouts 0
    Driver 5: pos 0, ok, SG min 0, mspos 42, reads 20838, writes 18 timeouts 0
    Date/time: 2022-03-07 23:25:14
    Slowest loop: 61.24ms; fastest: 0.05ms
    === Storage ===
    Free file entries: 9
    SD card longest read time 4.0ms, write time 24.3ms, max retries 0
    DMs created 125, segments created 30, maxWait 521301ms, bed compensation in use: mesh, comp offset 0.000
    === MainDDARing ===
    Scheduled moves 10333, completed 10324, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
    === AuxDDARing ===
    Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 3 -1 -1 -1, ordering errs 0
    Heater 0 is on, I-accum = 0.2
    Heater 1 is on, I-accum = 0.8
    Segments left: 1
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is doing "G1 X171.425003 Y101.862925 E.14892831" in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    SBC is idle in state(s) 0
    Daemon is idle in state(s) 0
    Aux2 is idle in state(s) 0
    Code queue is empty
    === Filament sensors ===
    Extruder 0: pos 269.30, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
    Extruder 1: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
    === CAN ===
    Messages queued 15746, received 0, lost 0, boc 2
    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 8749/0/0
    Tx timeouts 0,0,8747,0,0,6996 last cancelled message type 4514 dest 127
    === Network ===
    Slowest loop: 83.26ms; fastest: 0.02ms
    HTTP sessions: 1 of 8
    - Ethernet -
    State: active
    Error counts: 0 0 1 0 0
    Socket states: 5 2 2 2 2 2 0 0
    Only message logged is:
    Error: Filament error on extruder 0: sensorError
    Print is paused, and after resuming everything works fine
    With RRF3.3 no such issues
    • undefined Phaedrux moved this topic from Beta Firmware 8 Mar 2022, 19:37
      Can you share your M592 command and the results of sending M592 D0?
      undefined 1 Reply Last reply 8 Mar 2022, 20:31 Reply Quote 0
        BoA @Phaedrux
        @phaedrux M592? I do not use M592 anywhere in config.
        And M592 D0 is:
        M592 D0
        Drive 0 nonlinear extrusion coefficients: A=0.000, B=0.0000, limit=0.20
        Perhaps You had M591 in mind.
        M591 D0 P3 C"io5.in" S1 L25.4 R50:150 E12.7 A0 ; configure magnetic filament monitor on io5
        M591 D1 P3 C"io7.in" S1 L25.4 R50:150 E12.7 A0 ; configure magnetic filament monitor on io7
        M591 D0
        Duet3D rotating magnet filament monitor v3 on pin io5.in, disabled, sensitivity 25.40mm/rev, allow 50% to 150%, check printing moves every 12.7mm, version 3, mag 132 agc 64, measured sensitivity 25.61mm/rev, min 94% max 106% over 5312.6mm
        I see it is reported as disabled, as I disabled it after this error message just before resuming print just to avoid next pause.
          Sorry, I meant M591,
          undefined 1 Reply Last reply 8 Mar 2022, 21:07 Reply Quote 0
          • undefined Phaedrux moved this topic from Filament Monitor 8 Mar 2022, 20:55
            BoA @Phaedrux
            @phaedrux I posted M591 also
              And when you return to 3.3 the problem goes away entirely?
              undefined 1 Reply Last reply 8 Mar 2022, 21:09 Reply Quote 0
                BoA @Phaedrux
                @phaedrux Yes
                  charliedrums
                  This just happened to me on a 14 hour print. I updated to RRF3.4. Came here to see what it could be. I resumed the print and is printing fine now. the print is still going as I write.
                  RepRapFirmware for Duet 3 MB6HC version 3.4.0rc2 (2022-02-22 17:04:17) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                  Board ID: 08DJM-956BA-NA3TN-6JTD0-3SJ6S-1V82V
                  Used output buffers: 10 of 40 (40 max)
                  Static ram: 150984
                  Dynamic ram: 66520 of which 28 recycled
                  Never used RAM 129804, free system stack 114 words
                  Tasks: SBC(resourceWait:,0.7%,494) HEAT(notifyWait,0.0%,321) Move(notifyWait,1.7%,248) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,346) CanClock(delaying,0.0%,339) TMC(notifyWait,8.4%,58) MAIN(running,89.1%,923) IDLE(ready,0.0%,30), total 100.0%
                  Owned mutexes: HTTP(MAIN)
                  Last reset 15:54:21 ago, cause: power up
                  Last software reset at 2022-03-09 01:00, reason: HardFault, GCodes spinning, available RAM 130308, slot 1
                  Software reset code 0x4063 HFSR 0x80000000 CFSR 0x00000000 ICSR 0x00400803 BFAR 0x00000000 SP 0x2041b4f8 Task MAIN Freestk 1672 ok
                  Stack: 20429f28 2042c2d8 2041b594 00000001 0000002e 0045c81b 0045c676 61070000 20419a7c 2042bf34 00000000 00000001 00000000 004844d7 2042bf34 00000000 00000000 0048481f 003ffff0 004849f7 20429860 ffffffff 0934d918 2042bf34 20419a7c 2042c2dc ffffffff
                  Error status: 0x04
                  Aux0 errors 0,0,0
                  MCU temperature: min 47.3, current 47.5, max 47.7
                  Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                  Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/160/126, gc cycles 0
                  Events: 2 queued, 2 completed
                  Driver 0: pos 60689, ok, SG min 0, mspos 928, reads 41145, writes 0 timeouts 0
                  Driver 1: pos 14056, ok, SG min 0, mspos 616, reads 41145, writes 0 timeouts 0
                  Driver 2: pos 50096, standstill, SG min 0, mspos 72, reads 41145, writes 0 timeouts 0
                  Driver 3: pos 0, standstill, SG min 0, mspos 664, reads 41146, writes 0 timeouts 0
                  Driver 4: pos 0, standstill, SG min 0, mspos 152, reads 41146, writes 0 timeouts 0
                  Driver 5: pos 0, standstill, SG min 0, mspos 104, reads 41145, writes 0 timeouts 0
                  Date/time: 2022-03-09 16:28:53
                  Slowest loop: 31.03ms; fastest: 0.05ms
                  === Storage ===
                  Free file entries: 10
                  DMs created 125, segments created 20, maxWait 796ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  Scheduled moves 678710, completed 678677, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                  === AuxDDARing ===
                  Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                  Heater 0 is on, I-accum = 0.3
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 1
                  HTTP* is doing "M122" in state(s) 0 0, running macro
                  File* is doing "G1 X453.419006 Y257.640015 E-0.570000" in state(s) 0
                  Queue* is idle in state(s) 0
                  Autopause* is idle in state(s) 0
                  Code queue is empty
                  Extruder 0: no data received
                  === CAN ===
                  Messages queued 15065, received 12407, lost 0, boc 0
                  Longest wait 0ms for reply type 0, peak Tx sync delay 268, free buffers 50 (min 47), ts 3026/3026/0
                  Tx timeouts 0,0,0,0,0,0
                  === SBC interface ===
                  Transfer state: 4, failed transfers: 0, checksum errors: 0
                  RX/TX seq numbers: 15043/15043
                  SPI underruns 0, overruns 0
                  State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2b8b0
                  Buffer RX/TX: 1520/2544-0, open files: 0
                  === Duet Control Server ===
                  Duet Control Server v3.4-rc2
                  File /opt/dsf/sd/gcodes/Pandero11in_Escalas_0.6n_0.3mm_PLA_13h57m.gcode is selected, processing
                  HTTP:
                  Executing macro 0:/macros/Diagnostics, started by M98 P"0:/macros/Diagnostics"
                  > Next stack level
                  File:
                  Buffered code: G1 X453.419 Y257.64 E-.57
                  Buffered code: G1 E-.03 F2400
                  Buffered code: G1 Z63.02 F720
                  Buffered code: G1 X457.643 Y264.663 F10800
                  Buffered code: G1 Z62.62 F720
                  Buffered code: G1 E.6 F2400
                  Buffered code: G1 F4200
                  Buffered code: G1 X458.599 Y265.619 E.09391
                  Buffered code: G1 F8640
                  Buffered code: G1 X457.643 Y264.663 E-.35695
                  Buffered code: G1 E-.24305 F2400
                  Buffered code: G1 X459.911 Y269.805 F10800
                  Buffered code: G1 X460.905 Y270.799 E.09959
                  Buffered code: G1 X459.911 Y269.805 E-.37085
                  Buffered code: G1 E-.22915 F2400
                  Buffered code: G1 X463.158 Y276.331 F10800
                  ==> 992 bytes
                  Code buffer space: 1552
                  Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                  Full transfers per second: 39.36, max time between full transfers: 44.0ms, max pin wait times: 29.1ms/8.3ms
                  Codes per second: 18.47
                  Maximum length of RX/TX data transfers: 3928/1628
                    charliedrums
                    That print finished without any more faults. Started another print, this one 17 hours long and by hour 5 I got the
                    3/10/2022, 3:12:23 AM Error: Filament error on extruder 0: sensorError
                    I don't get any other filament errors as I was very careful in installing the sensor correctly. This is the M591
                    3/10/2022, 10:14:45 AM M591 D0
                    Duet3D rotating magnet filament monitor v3 on pin 121.io1.in, enabled, sensitivity 28.80mm/rev, allow 35% to 130%, check printing moves every 20.0mm, version 3, mag 129 agc 85, measured sensitivity 24.72mm/rev, min 99% max 101% over 1626.0mm
                    Diagnostics:
                    3/10/2022, 10:08:44 AM === Diagnostics ===
                    Used output buffers: 6 of 40 (40 max)
                    Static ram: 150984
                    Never used RAM 129876, free system stack 128 words
                    Tasks: SBC(resourceWait:,14.6%,504) HEAT(notifyWait,0.3%,321) Move(notifyWait,17.9%,248) CanReceiv(notifyWait,0.5%,772) CanSender(notifyWait,0.2%,346) CanClock(delaying,0.1%,339) TMC(notifyWait,185.9%,58) MAIN(running,156.5%,923) IDLE(ready,0.1%,30), total 376.1%
                    Last reset 13:18:07 ago, cause: power up
                    Last software reset at 2022-03-10 01:24, reason: AssertionFailed, GCodes spinning, available RAM 129804, slot 2
                    Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x2041b53c Task MAIN Freestk 1689 ok
                    Stack: 00000599 004a3b00 00484adb 20429860 ffffffff 9b6a2e4b 2042c2dc 20419a7c 2042e1c4 ffffffff 00000000 9b6a2e7a 00484b0d 2041b58c 20429f28 20421e98 0048229f 2042e1c0 0045c7f3 00000000 2042e1c4 00000000 2041b59c 00000101 00000000 00000000 00000000
                    Error status: 0x04
                    Aux0 errors 0,0,0
                    Step timer max interval 180
                    MCU temperature: min 35.1, current 45.6, max 48.3
                    12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                    Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/100/60, gc cycles 0
                    Driver 0: pos 40039, ok, SG min 0, mspos 725, reads 50511, writes 17 timeouts 0
                    Driver 1: pos 16068, ok, SG min 0, mspos 530, reads 50512, writes 17 timeouts 0
                    Driver 2: pos 16792, ok, SG min 0, mspos 437, reads 50512, writes 17 timeouts 0
                    Driver 3: pos 0, ok, SG min 0, mspos 715, reads 50512, writes 17 timeouts 0
                    Driver 4: pos 0, ok, SG min 0, mspos 267, reads 50512, writes 17 timeouts 0
                    Driver 5: pos 0, ok, SG min 0, mspos 149, reads 50512, writes 17 timeouts 0
                    Date/time: 2022-03-10 14:38:24
                    Slowest loop: 977.23ms; fastest: 0.04ms
                    === Storage ===
                    DMs created 125, segments created 17, maxWait 24379276ms, bed compensation in use: mesh, comp offset -0.455
                    === MainDDARing ===
                    Scheduled moves 290327, completed 290301, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
                    === AuxDDARing ===
                    Segments left: 1
                    File* is doing "G1 Z20.799999 F720" in state(s) 0
                    Code queue is empty
                    === CAN ===
                    Messages queued 704031, received 981440, lost 0, boc 0
                    Longest wait 2ms for reply type 6026, peak Tx sync delay 279, free buffers 50 (min 45), ts 239437/239436/0
                    RX/TX seq numbers: 35269/35269
                    Buffer RX/TX: 2064/3296-0, open files: 0
                    File /opt/dsf/sd/gcodes/Pandero 14in escalas_0.6n_0.3mm_PLA_18h27m.gcode is selected, processing
                    HTTP:
                    > Next stack level
                    File:
                    Buffered code: G1 Z20.4 F720
                    Buffered code: G1 X311.863 Y149.869 E.138
                    Buffered code: G1 X313.184 Y148.549 E-.4928
                    Buffered code: G1 E-.1072 F2400
                    Buffered code: G1 Z20.8 F720
                    Buffered code: G1 X311.471 Y154.535 F10800
                    Buffered code: G1 X310.523 Y154.629 E.06607
                    Buffered code: G1 X308.988 Y154.828 E.1074
                    Buffered code: G1 X309.043 Y154.72 E.00841
                    Buffered code: G1 X309.595 Y154.092 E.05804
                    Buffered code: G1 X310.231 Y153.463 E.06202
                    Buffered code: G1 X310.72 Y152.835 E.05527
                    Buffered code: G1 X311.017 Y152.207 E.04823
                    Buffered code: G1 X311.163 Y151.578 E.04476
                    Buffered code: G1 X311.183 Y150.95 E.04362
                    Buffered code: G1 X311.061 Y150.322 E.04441
                    Buffered code: G1 X310.743 Y149.693 E.04886
                    Buffered code: G1 X310.565 Y149.491 E.01873
                    Buffered code: G1 X307.182 Y150.524 E.24546
                    ==> 1104 bytes
                    Pending code: G1 X307.075 Y150.73 E.01612
                    Pending code: G1 X306.5 Y150.911 E.04182
                    Code buffer space: 2056
                    Full transfers per second: 37.64, max time between full transfers: 83.8ms, max pin wait times: 62.5ms/6.9ms
                    Codes per second: 6.04
                    Maximum length of RX/TX data transfers: 3712/1716
                    Still printing at time of writing with 22.4 % complete and about 13ish hours to go.
                    Edited to add tool board 1lc diagnostics
                    3/10/2022, 10:21:58 AM M122 B121
                    Diagnostics for board 121:
                    Duet TOOL1LC rev 1.1 or later firmware version 3.4.0rc2 (2022-02-22 10:15:02)
                    Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                    All averaging filters OK
                    Never used RAM 2204, free system stack 17 words
                    Tasks: Move(notifyWait,4.4%,99) HEAT(notifyWait,4.8%,95) CanAsync(notifyWait,0.0%,55) CanRecv(notifyWait,0.8%,74) CanClock(notifyWait,0.3%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,51.5%,57) MAIN(running,153.6%,351) IDLE(ready,0.0%,26) AIN(delaying,84.1%,142), total 299.6%
                    Last reset 13:31:22 ago, cause: VDD brownout
                    Last software reset data not available
                    Driver 0: pos 22986108, 405.0 steps/mm,standstill, SG min 0, read errors 20, write errors 0, ifcnt 13, reads 28334, writes 13, timeouts 7, DMA errors 0, CC errors 0, failedOp 0x41, steps req 25729946 done 25729946
                    Moves scheduled 288224, completed 288224, in progress 0, hiccups 125, step errors 0, maxPrep 665, maxOverdue 8517, maxInc 8517, mcErrs 0, gcmErrs 0
                    Peak sync jitter 1/6, peak Rx sync delay 232, resyncs 0/0, no step interrupt scheduled
                    VIN voltage: min 24.1, current 24.3, max 24.5
                    MCU temperature: min 37.8C, current 51.0C, max 53.2C
                    Last sensors broadcast 0x00000002 found 1 81 ticks ago, 0 ordering errs, loop time 0
                    CAN messages queued 997750, send timeouts 0, received 726318, lost 0, free buffers 37, min 36, error reg 0
                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 617, adv 35626/74661
                    Accelerometer: LIS3DH, status: 00
                    I2C bus errors 0, naks 3, other errors 0
                    Interrupt 4 to 97us, poll 8 to 2542us
                    Driver 0: pos 285.47, errs: frame 88 parity 0 ovrun 0 pol 0 ovdue 0
                      charliedrums
                      Happened again at 44.5% of the print the same error code:
                      3/10/2022, 2:47:01 PM Error: Filament error on extruder 0: sensorError
                      This time I did the diagnostic codes before I resumed the print.
                      M122
                      3/10/2022, 4:32:40 PM M122
                      Used output buffers: 8 of 40 (40 max)
                      Static ram: 150984
                      Never used RAM 129828, free system stack 128 words
                      Tasks: SBC(ready,120.2%,504) HEAT(notifyWait,2.6%,321) Move(notifyWait,231.3%,248) CanReceiv(notifyWait,4.1%,772) CanSender(notifyWait,3.2%,346) CanClock(delaying,0.9%,339) TMC(notifyWait,1474.5%,58) MAIN(running,2710.9%,923) IDLE(ready,0.1%,30), total 4547.8%
                      Last reset 19:42:02 ago, cause: power up
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      Step timer max interval 149
                      MCU temperature: min 45.4, current 47.2, max 48.7
                      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/160/120, gc cycles 0
                      Driver 0: pos 36230, standstill, SG min 0, mspos 104, reads 17097, writes 0 timeouts 0
                      Driver 1: pos -35430, standstill, SG min 0, mspos 904, reads 17097, writes 0 timeouts 0
                      Driver 2: pos 40272, standstill, SG min 0, mspos 312, reads 17097, writes 0 timeouts 0
                      Driver 3: pos 0, standstill, SG min 0, mspos 840, reads 17097, writes 0 timeouts 0
                      Driver 4: pos 0, standstill, SG min 0, mspos 392, reads 17098, writes 0 timeouts 0
                      Driver 5: pos 0, standstill, SG min 0, mspos 24, reads 17098, writes 0 timeouts 0
                      Date/time: 2022-03-10 21:02:19
                      Slowest loop: 50.08ms; fastest: 0.04ms
                      === Storage ===
                      DMs created 125, segments created 19, maxWait 1260ms, bed compensation in use: mesh, comp offset -0.455
                      === MainDDARing ===
                      Scheduled moves 602559, completed 602559, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                      === AuxDDARing ===
                      Segments left: 0
                      File* is idle in state(s) 0
                      Code queue is empty
                      === CAN ===
                      Messages queued 494841, received 472277, lost 0, boc 0
                      Longest wait 5ms for reply type 6024, peak Tx sync delay 301, free buffers 50 (min 45), ts 115176/115176/0
                      RX/TX seq numbers: 22180/22180
                      Buffer RX/TX: 0/0-0, open files: 0
                      File /opt/dsf/sd/gcodes/Pandero 14in escalas_0.6n_0.3mm_PLA_18h27m.gcode is selected, paused
                      Code buffer space: 4096
                      Full transfers per second: 39.26, max time between full transfers: 77.9ms, max pin wait times: 60.7ms/10.7ms
                      Codes per second: 14.20
                      Maximum length of RX/TX data transfers: 3768/1716
                      M122 B121
                      3/10/2022, 4:33:34 PM M122 B121
                      Tasks: Move(notifyWait,2.4%,99) HEAT(notifyWait,1.2%,95) CanAsync(notifyWait,0.0%,55) CanRecv(notifyWait,0.4%,74) CanClock(notifyWait,0.1%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,13.3%,57) MAIN(running,60.9%,351) IDLE(ready,0.0%,26) AIN(delaying,21.7%,142), total 100.0%
                      Last reset 19:42:58 ago, cause: VDD brownout
                      Driver 0: pos 35910153, 405.0 steps/mm,standstill, SG min 0, read errors 10, write errors 0, ifcnt 13, reads 15749, writes 0, timeouts 3, DMA errors 0, CC errors 0, failedOp 0x06, steps req 16566495 done 16566495
                      Moves scheduled 560607, completed 560607, in progress 0, hiccups 0, step errors 0, maxPrep 681, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                      Peak sync jitter 1/8, peak Rx sync delay 235, resyncs 0/0, no step interrupt scheduled
                      VIN voltage: min 24.1, current 24.3, max 24.3
                      MCU temperature: min 37.8C, current 48.2C, max 53.2C
                      Last sensors broadcast 0x00000002 found 1 70 ticks ago, 0 ordering errs, loop time 0
                      CAN messages queued 457092, send timeouts 0, received 473045, lost 0, free buffers 37, min 36, error reg 0
                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 601, adv 35676/74660
                      I2C bus errors 0, naks 0, other errors 0
                      Interrupt 4 to 34us, poll 8 to 2477us
                      Driver 0: pos 139.92, errs: frame 206 parity 0 ovrun 0 pol 0 ovdue 0
                      M591 D0
                      3/10/2022, 4:37:28 PM M591 D0
                      Duet3D rotating magnet filament monitor v3 on pin 121.io1.in, enabled, sensitivity 28.80mm/rev, allow 35% to 130%, check printing moves every 20.0mm, version 3, mag 129 agc 85, measured sensitivity 24.74mm/rev, min 98% max 103% over 33743.9mm
                      undefined 1 Reply Last reply 10 Mar 2022, 21:42 Reply Quote 0
                        Phaedrux Moderator @charliedrums
                        @charliedrums You've kind of taken over someone else's thread. To keep things clear can you please create a new thread with your issue?
                        undefined 1 Reply Last reply 10 Mar 2022, 21:49 Reply Quote 0
                          charliedrums @Phaedrux
                          @phaedrux Sure thing will do Sorry about that.
                          undefined 1 Reply Last reply 10 Mar 2022, 21:51 Reply Quote 0
                            @charliedrums said in RRF3.4 RC2 Filament/sensor error:
                            No problem. I'd be curious to know if your issue also goes away when going back to fw 3.3
                            undefined 1 Reply Last reply 10 Mar 2022, 22:01 Reply Quote 0
                              @phaedrux
                              I made a thread on the issue.
                              Once this 17 hour print finishes I have a 20 hour print I have to do after this one. I can downgrade to 3.3 and see if it finishes without any problem but If you could point me in the right direction on how to downgrade I'd appreciate it. Also would I have to downgrade the tool board (1lc) as well?
                                BoA
                                Catched again. This time I executed M122 and M591 D0 before resuming the print.
                                11.03.2022, 19:21:28 M24
                                Printing resumed
                                11.03.2022, 19:21:21 M122
                                Used output buffers: 1 of 40 (40 max)
                                Static ram: 150984
                                Never used RAM 81364, free system stack 116 words
                                Tasks: NETWORK(ready,26.6%,199) ETHERNET(notifyWait,1.6%,166) HEAT(notifyWait,2.0%,321) Move(notifyWait,50.4%,243) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,355) CanClock(delaying,0.4%,333) TMC(notifyWait,89.7%,58) MAIN(running,47.4%,967) IDLE(ready,0.1%,30), total 218.2%
                                Owned mutexes:
                                Last reset 49:04:02 ago, cause: software
                                Last software reset time unknown, reason: User, GCodes spinning, available RAM 85132, slot 1
                                Error status: 0x04
                                Aux0 errors 0,1,0
                                Step timer max interval 184
                                MCU temperature: min 36.9, current 47.2, max 48.9
                                Supply voltage: min 12.2, current 27.2, max 27.5, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 11.4, current 12.2, max 12.5, under voltage events: 0
                                Heap OK, handles allocated/used 99/6, heap memory allocated/used/recyclable 2048/1440/1260, gc cycles 0
                                Driver 0: pos 0, standstill, SG min 0, mspos 296, reads 27362, writes 179 timeouts 0
                                Driver 1: pos 40000, standstill, SG min 0, mspos 408, reads 27360, writes 181 timeouts 0
                                Driver 2: pos 5685, standstill, SG min 0, mspos 600, reads 27471, writes 70 timeouts 0
                                Driver 3: pos 0, standstill, SG min 0, mspos 8, reads 27525, writes 16 timeouts 0
                                Driver 4: pos 0, standstill, SG min 0, mspos 72, reads 27407, writes 134 timeouts 0
                                Driver 5: pos 0, standstill, SG min 0, mspos 904, reads 27408, writes 134 timeouts 0
                                Date/time: 2022-03-11 19:21:12
                                Slowest loop: 79.06ms; fastest: 0.05ms
                                === Storage ===
                                SD card longest read time 5.0ms, write time 131.1ms, max retries 0
                                DMs created 125, segments created 31, maxWait 8354511ms, bed compensation in use: mesh, comp offset 0.000
                                === MainDDARing ===
                                Scheduled moves 254484, completed 254484, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
                                === AuxDDARing ===
                                Heater 1 is on, I-accum = 0.6
                                Heater 3 is on, I-accum = 0.0
                                Segments left: 0
                                File is idle in state(s) 0
                                Code queue is empty
                                Extruder 0: pos 161.72, errs: frame 12 parity 0 ovrun 0 pol 0 ovdue 0
                                === CAN ===
                                Messages queued 1589784, received 0, lost 0, boc 0
                                Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 883214/0/0
                                Tx timeouts 0,0,883213,0,0,706569 last cancelled message type 4514 dest 127
                                === Network ===
                                Slowest loop: 131.55ms; fastest: 0.02ms
                                - Ethernet -
                                State: active
                                11.03.2022, 19:21:14 M591 D0
                                Duet3D rotating magnet filament monitor v3 on pin io5.in, enabled, sensitivity 25.40mm/rev, allow 50% to 150%, check printing moves every 12.7mm, version 3, mag 131 agc 64, measured sensitivity 25.91mm/rev, min 94% max 107% over 26367.4mm
                                11.03.2022, 19:11:29 Resume state saved
                                11.03.2022, 19:11:27 Error: Filament error on extruder 0: sensorError
                                undefined 1 Reply Last reply 11 Mar 2022, 19:15 Reply Quote 0
                                  Phaedrux Moderator @BoA
                                  @boa How do you have your cabling run?
                                  Our best guess is that interference is corrupting the signal from the MFM and that RRF 3.3 wasn't very good at reporting that type of error.
                                  undefined 1 Reply Last reply 11 Mar 2022, 19:38 Reply Quote 0
                                    BoA @Phaedrux
                                    Blue path is filament sensor wiring - about 50cm long
                                    Red are motors and heaters
                                      Well that path seems pretty clear from other cabling.
                                      Is sensor error the only error that you get?
                                      undefined 1 Reply Last reply 11 Mar 2022, 20:02 Reply Quote 0
                                        BoA @Phaedrux
                                        @phaedrux Yes. That is the only error. If there is a way to enable some debug logging I can do that to get more info.
                                        And... probably not related completly, but I noticed that my stop.g causes chamber heater to go into active state, which was not the case with 3.3
                                        stop.g:
                                        T-1
                                        M104 S0 T0
                                        M104 S0 T1
                                        M140 S0 R0
                                        M141 S0 R0 ; disable chamber heater
                                        M144 S0 ; put heatbed on standby
                                        M106 P0 S0
                                        M220 S100
                                        M221 S100 D0
                                        M221 S100 D1
                                        M84
                                        M300 P300
                                        undefined 1 Reply Last reply 11 Mar 2022, 20:18 Reply Quote 0
                                          @boa said in RRF3.4 RC2 Filament/sensor error:
                                          T-1 M104 S0 T0 M104 S0 T1 M140 S0 R0 M141 S0 R0 ; disable chamber heater M144 S0 ; put heatbed on standby
                                          If you send those commands manually does it behave the same with with the chamber heater? And is it active state with 0 temperature?
                                          undefined 1 Reply Last reply 11 Mar 2022, 20:31 Reply Quote 0
                                          8 out of 36
