    LIS3DSH accelerometer on an Ender 3?
    • westechundefined
      westech
      Happy! My accelerometer LIS3DSH comes in tomorrow. I have an ender 3. Is there a preferred way to mount it to the bed? I have all kinds of JST, Dupont etc connectors and wire I can use.
      Thanks!
      Max
        Have you seen this?
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer
        westechundefined 1 Reply Last reply Reply Quote 0
        • westechundefined
          westech @Phaedrux
          @phaedrux Yes, I'm actually trying to find out how the module is attached to the bed or hotend? Use tape? Print a mount?
            The mounting option is up to you. The sensor only needs to be mounted when doing a measurement, so it does not need to be permanent. The important thing for mounting during a measurement is that it is rigid. That could be achieved with tape since the sensor is so light. If you have a spot to mount it with a printed mount and screws, that's all the better, but not critical for a good measurement.
