    RRF3.4 RC2 Filament/sensor error
    Beta Firmware
    2.0k
    • BoAundefined
      BoA @Phaedrux
      Blue path is filament sensor wiring - about 50cm long
      Red are motors and heaters
        Well that path seems pretty clear from other cabling.
        Is sensor error the only error that you get?
        BoAundefined 1 Reply Last reply Reply Quote 0
        • BoAundefined
          BoA @Phaedrux
          @phaedrux Yes. That is the only error. If there is a way to enable some debug logging I can do that to get more info.
          And... probably not related completly, but I noticed that my stop.g causes chamber heater to go into active state, which was not the case with 3.3
          stop.g:
          T-1
          M104 S0 T0
          M104 S0 T1
          M140 S0 R0
          M141 S0 R0 ; disable chamber heater
          M144 S0 ; put heatbed on standby
          M106 P0 S0
          M220 S100
          M221 S100 D0
          M221 S100 D1
          M84
          M300 P300
            Phaedrux Moderator @BoA
            @boa said in RRF3.4 RC2 Filament/sensor error:
        T-1        M104 S0 T0        M104 S0 T1        M140 S0 R0        M141 S0 R0 ; disable chamber heater        M144 S0 ; put heatbed on standby
            If you send those commands manually does it behave the same with with the chamber heater? And is it active state with 0 temperature?
            • BoAundefined
              BoA @Phaedrux
              @phaedrux Yes. Sending manually M141 S0 R0 manually causes chamber heater switch to active with temps 0*C
                What if you just use M141 R0?
                • BoAundefined
                  BoA @Phaedrux
                  @phaedrux said in RRF3.4 RC2 Filament/sensor error:
                  This way it stays off. Thanks. However... what it is active, sending M141 R0 does not switch to off state. I wonder how DWC makes chamber heater off.
                  • BoAundefined
                    BoA
                    I just opened Object Model and...
                    I was expecting values from M591 command
                    M591 D0 P3 C"io5.in" S1 L25.4 R50:150 E12.7 A0
                    which seems not to be the case.
                      What happens if you set the temp to -274?
                      • BoAundefined
                        BoA @Phaedrux
                        M141 R-274
                        Error: M141: Temperature too low for heater 3
                        state is unchanged
                          How about -273?
                          • BoAundefined
                            BoA @Phaedrux
                            -273 is set and state does not change
                            If executed on active, it stays active, of on off it stays off
                            • BoAundefined
                              BoA
                              I updated to official 3.4 release, and the issue is still reproducible.
                              20.03.2022, 19:17:00 	Resume state saved
                              20.03.2022, 19:16:57 	Error: Filament error on extruder 0: sensorError
                              20.03.2022, 12:27:04 	80 points probed, min error -0.085, max error 0.175, mean 0.098, deviation 0.050
                              Height map saved to file 0:/sys/heightmap.csv
                              20.03.2022, 12:24:44 	Leadscrew adjustments made: 0.322 -1.414, points used 2, (mean, deviation) before (-0.494, 0.579) after (0.000, 0.000)
                              20.03.2022, 12:23:29 	Connected to 192.168.0.204
                              Sensor reported after about 6h 50m of printing.
                              After resuming, works just fine.
                              M122 shows nothing disturbing
                              M122
                              RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                              Board ID: 08DJM-956L2-G43S8-6J1D6-3SJ6R-KA0YG
                              Used output buffers: 1 of 40 (40 max)
                              Static ram: 151000
                              Dynamic ram: 98868 of which 0 recycled
                              Never used RAM 80884, free system stack 118 words
                              Tasks: NETWORK(ready,13.6%,193) ETHERNET(notifyWait,0.6%,166) HEAT(notifyWait,0.6%,321) Move(notifyWait,18.1%,248) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.1%,333) TMC(notifyWait,102.1%,58) MAIN(running,210.0%,1016) IDLE(ready,0.0%,30), total 345.1%
                              Owned mutexes:
                              Last reset 07:00:42 ago, cause: power up
                              Last software reset at 2022-03-14 16:09, reason: User, GCodes spinning, available RAM 85252, slot 2
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                              Error status: 0x04
                              Aux0 errors 0,1,0
                              Step timer max interval 195
                              MCU temperature: min 23.6, current 45.3, max 45.7
                              Supply voltage: min 9.2, current 27.3, max 27.5, under voltage events: 0, over voltage events: 0, power good: yes
                              12V rail voltage: min 8.4, current 12.2, max 12.5, under voltage events: 1
                              Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/240/0, gc cycles 0
                              Events: 1 queued, 1 completed
                              Driver 0: ok, SG min 0, mspos 166, reads 30928, writes 47 timeouts 0
                              Driver 1: ok, SG min 0, mspos 120, reads 30928, writes 47 timeouts 0
                              Driver 2: stalled, SG min 0, mspos 498, reads 30943, writes 33 timeouts 0
                              Driver 3: standstill, SG min 0, mspos 8, reads 30950, writes 26 timeouts 0
                              Driver 4: ok, SG min 0, mspos 248, reads 30938, writes 38 timeouts 0
                              Driver 5: ok, SG min 0, mspos 103, reads 30938, writes 38 timeouts 0
                              Date/time: 2022-03-20 19:20:04
                              Slowest loop: 78.87ms; fastest: 0.05ms
                              === Storage ===
                              Free file entries: 9
                              SD card longest read time 4.5ms, write time 1.4ms, max retries 0
                              DMs created 125, segments created 31, maxWait 203567ms, bed compensation in use: mesh, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 358986, completed 358977, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state 3
                              === AuxDDARing ===
                              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 3 -1 -1 -1, ordering errs 0
                              Heater 0 is on, I-accum = 0.3
                              Heater 1 is on, I-accum = 0.7
                              Segments left: 1
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is doing "G1 X171.425003 Y45.29912 E.186246311" in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              SBC is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Aux2 is idle in state(s) 0
                              Code queue is empty
                              === Filament sensors ===
                              Extruder 0: pos 142.03, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                              Extruder 1: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                              === CAN ===
                              Messages queued 227184, received 0, lost 0, boc 0
                              Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 126215/0/0
                              Tx timeouts 0,0,126214,0,0,100968 last cancelled message type 30 dest 127
                              === Network ===
                              Slowest loop: 18.39ms; fastest: 0.02ms
                              HTTP sessions: 1 of 8
                              - Ethernet -
                              State: active
                              Error counts: 0 0 0 0 0
                              Socket states: 5 2 2 2 2 2 0 0
                              Same thing with M591 D0
                              M591 D0
                              Duet3D rotating magnet filament monitor v3 on pin io5.in, enabled, sensitivity 25.40mm/rev, allow 50% to 150%, check printing moves every 12.7mm, version 3, mag 131 agc 64, measured sensitivity 26.03mm/rev, min 95% max 104% over 625.4mm
                                Alright, let's replace the sensor. When and where did you purchase it?
                                • BoAundefined
                                  BoA @Phaedrux
                                  @phaedrux I bought it from Hobbystore, around IX.2020
                                  I have 2 of them, and can swap to check if this issue is still there.
                                  In fact I have no idea why I did not do that already.
                                  I will test 2 cases:
                                  • use second one and second wiring, just adjust the config to completly eliminate path from the board to sensor and sensor itself
                                  • swap the seonsors only, so the wiring will be the same.
                                  • BoAundefined
                                    BoA
                                    I did a lot of testing, printing and now from denial I moved to acceptance. The actual cause of the problem was the wiring harness. Not sure why and how, once per few hours it has to loose connection somewhere.
                                    I swapped sensor, ioport, and... wiring.
                                    So I guess, as @Phaedrux stated somwhere here, 3.3 was not very good at reporting this type of error. Apparently 3.4.... is much better in this area 😉
                                    Heh...
                                      Well at least you got it figured out.
                                      What was the wiring like before, and what did you change it to?
                                      • Phaedruxundefined Phaedrux has marked this topic as solved
                                      • BoAundefined
                                        BoA @Phaedrux
                                        @phaedrux I just used second harness. Identical as the previous one. Movement propagated from extruder through reversed bowden tube to the sensor causes it to move very slightly and during the long time the wire start breaking. I see no other explanation.
                                        WapuraRalfundefined 1 Reply Last reply Reply Quote 0
                                        • WapuraRalfundefined
                                          WapuraRalf @BoA
                                          @boa I have the same issues. I also have two sensors on a dual extruder. I understand that too little or too much movement is an issue to to stop the print. However the Sensor errors I saw until now are happening after a few hours but after resume the print runs fine for hours again. So why isn't there a way of ignoring those single errors and only trigger a stop if it is keeping reporting errors?
                                            Phaedrux Moderator @WapuraRalf
                                            @wapuraralf Take a look at this thread for a way to use conditional gcode to gain further control over what happens on errors you think may be spurious.
                                            https://forum.duet3d.com/topic/27847/filament-error-g-usage-help-avoid-pausing-on-sensorerror/5?_=1654287075525
                                            Otherwise, please start a new thread with your issue in the filament monitor forum.
