    Z-probe commissioning problem
    Smart effector for delta printers
    5.3k
    • MoS-tekknixundefined
      MoS-tekknix
      Did you check the Connections and proofed if you have bad crimped connections as David suggests?
      • number40fanundefined
        number40fan
        Delete those folders.
        • RGN01undefined
          RGN01
          @MoS-tekknix:
          I checked them with a multimeter when I installed the cable - it was OK. I'll check again. Thanks.
          • RGN01undefined
            RGN01
            @number40fan:
            Do you mean files, please?
              number40fan
              Yes, the deploy and retract files. Delete them completely.
              • RGN01undefined
                RGN01
                @number40fan:
                OK, I've done that, they are deleted.
                I've also homed the printer and slowly dropped the nozzle until it just touches the bed. The Z-height readings were:
                Homed: 645.0
                Touching bed: 212.5
                And as it touched the bed the Z-probe field went pink and read 1,000 from the normal 0 for a split second.
                Going to power it down and check the cable as suggested.
                Thanks for the help, I appreciate it!
                  number40fan
                  Change the H numbers in M665 to 433. That'll fix the issue.
                  • RGN01undefined
                    RGN01
                    Cable is good, no bad crimps and no crossed wires - they are in the same order on both ends.
                      number40fan
                      What type of motors, pulleys and belts are you running? Reason I ask is your M92 numbers are goofy.
                      • RGN01undefined
                        RGN01
                        @number40fan:
                        Motors are 17HM19-2004S, pulleys 16-tooth GT2, belt GT2
                          number40fan
                          Thanks. You're ok then. Just looked off to me having only ran 20 toothed pulleys.
                          • RGN01undefined
                            RGN01
                            Since deleting those two files, issuing a G30 seems to put the printer into a 'frozen' Busy state and only a power reset or emergency stop seems to allow it to move again.
                            The status near to the Emergency Stop in the top right corner changes to Busy and nothing moves after that.
                            • RGN01undefined
                              RGN01
                              @number40fan:
                              Phew, thank goodness for that! Thanks for checking and pointing it out anyway!
                                number40fan
                                Have you changed the H number yet? Just wonder if it is freaking out because your homed height is greater than what your config is.
                                  number40fan
                                  M665 R246.6 L440.0 B180 H443
                                  Try this and see what happens.
                                  • RGN01undefined
                                    RGN01
                                    @number40fan:
                                    Yes, if I manually lower the nozzle from homed position it stops at bed height so that seems OK.
                                    • RGN01undefined
                                      RGN01
                                      @number40fan:
                                      I have that already - after changing it earlier.
                                      In an effort to fix the 'freezing' problem, I replaced deployprobe.g - it now reacts to the G30 command without freezing - but the original problem returns and it ignores a touch on the nozzle during the G30 operation.
                                        number40fan
                                        Notes from the Wiki.
                                        Version 1.19
                                        Upgrade notes from version 1.18.2:
                                        •Recommended DuetWebControl version is 1.19
                                        •Recommended DuetWiFiServer version is 1.19
                                        •Important! If you use an IR Z probe or some other type that does not need to be deployed, delete the files sys/deployprobe and sys/retractprobe.g if they exist, because they are now called automatically. You can do this in the System Files Editor of the web interface.
                                        You do need those two files removed, so your issue is somewhere else.
                                          number40fan
                                          So, now when the nozzle is at the bed, the web interface reads 0 for Z height?
                                          • RGN01undefined
                                            RGN01
                                            @number40fan:
                                            Version 1.19
                                            If I remove deployprobe.g then I get the freezing issue. It contains the following:
                                            [[language]]
                                            ; Probe deployment routine for Mini Kossel
                                            M564 S0					; don't apply limits
                                            G1 X25 Y93 Z40 F10000	; put probe arm next to belt
                                            G1 X-5 F500				; move probe arm across belt
                                            G1 X12 F1000			; move probe back
                                            G1 X0 Y0 F10000			; move to somewhere sensible
                                            M564 S1					; apply limits again
                                            With that file in place, it seems to execute the commands, then probes the bed (green LED flash) and then stops with z=-0.1. Without that file it does none of those operations and enters a permanently busy state.
                                            I will try and comment those lines out 1 by 1 to find which one is required to make G30 work.
