    Spindle Controll with M950
    CNC
    330
    • gabitundefined
      gabit
      i try to make a spindle Controll via Duet 2 Wlan
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
      my prefered config.g is like
      M950 R0 C"!e1heat" L22000     ; Create spindle index 0, with PWM pin on heater 1 and 22000 RPM achieved at full PWM
      M563 P1 S"Spindle 1" R0       ; Create tool 1 with spindle 0 and call it "Spindle 1"
      M453                          ; CNC Mode
      when i start with this config or send manual this "M950 R0 C"!e1heat" L22000 " i got
      What is the correct Code for define a spindle in RepRap 3.3
        jay_s_uk @gabit
        @gabit https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m453-select-cnc-device-mode
        gabitundefined 1 Reply Last reply Reply Quote 0
        • gabitundefined
          gabit @jay_s_uk
          @jay_s_uk ok, i knew this page and my code is from this side
          the only different is the connector
          ; New code
          M950 R0 C"!exp.heater3" L12000 ; Create spindle index 0, with PWM pin on heater 3 and 12000 RPM achieved at full PWM
          M453
          Doesnt work, same error
          ; Old code
          M453 S0 T1 C"!exp.heater3" R12000 ; Assign tool 1 to spindle index 0, with PWM pin on heater 3 and 12000 RPM achieved at full PWM
          The same, what is the problem?
            jay_s_uk @gabit
            @gabit what DWC version are you running?
            • gabitundefined
              gabit @jay_s_uk
              @jay_s_uk Is this DWC?
                jay_s_uk @gabit
                @gabit yes, thats the issue then, not the code.
                That won't work with RRF3 correctly. Update to the duet release of DWC
                • gabitundefined
                  gabit @jay_s_uk
                  @jay_s_uk ok thanks, i try this
                  • gabitundefined
                    gabit @gabit
                    @gabit Thanks, now it works!
