    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    25.1k
    • paolozampini1973undefined
      paolozampini1973 @droftarts
      @droftarts Ok Now what do you want me to do ?
        droftarts administrators @paolozampini1973
        @paolozampini1973 Next, remove these 4 jumpers on DueX:
        1 for DueX2 mode:
        3 to disable on board stepper drivers:
        paolozampini1973undefined 1 Reply Last reply Reply Quote 1
          @droftarts Yes I have already done this
            @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
            Including the jumper on EN9?
            paolozampini1973undefined droftartsundefined 2 Replies Last reply Reply Quote 1
              @droftarts YES
                droftarts administrators @droftarts
                Reset Duet and DueX. Check that DueX is recognised as DueX2. Send M122 to check.
                  @droftarts 22/3/2022, 15:31:27 M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX2
                  Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
                  Used output buffers: 6 of 24 (20 max)
                  Static ram: 23876
                  Dynamic ram: 77448 of which 0 recycled
                  Never used RAM 13092, free system stack 184 words
                  Tasks: NETWORK(ready,10.5%,246) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,313) DUEX(notifyWait,0.0%,24) MAIN(running,86.4%,433) IDLE(ready,2.9%,29), total 100.0%
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:00:25 ago, cause: power up
                  Last software reset at 2022-03-22 15:15, reason: User, GCodes spinning, available RAM 13092, slot 1
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  Step timer max interval 0
                  MCU temperature: min 25.3, current 29.0, max 29.1
                  Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 0, standstill, SG min/max not available
                  Driver 1: position 0, standstill, SG min/max not available
                  Driver 2: position 0, standstill, SG min/max not available
                  Driver 3: position 0, standstill, SG min/max not available
                  Driver 4: position 0, standstill, SG min/max not available
                  Driver 5: position 0, standstill, SG min/max not available
                  Driver 6: position 0, standstill, SG min/max not available
                  Driver 7: position 0
                  Driver 8: position 0
                  Driver 9: position 0
                  Driver 10: position 0
                  Driver 11: position 0
                  Date/time: 2022-03-22 15:31:26
                  Cache data hit count 987899119
                  Slowest loop: 6.44ms; fastest: 0.18ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  === AuxDDARing ===
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Filament sensors ===
                  Extruder 0 sensor: no filament
                  Extruder 1 sensor: ok
                  Extruder 2 sensor: no filament
                  Extruder 3 sensor: ok
                  === DueX ===
                  Read count 1, 2.32 reads/min
                  === Network ===
                  Slowest loop: 39.64ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    WiFi firmware version 1.26
                    WiFi MAC address 40:f5:20:0d:6b:49
                    WiFi Vcc 3.37, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 23400
                    WiFi IP address 192.168.1.4
                    WiFi signal strength -63dBm, mode 802.11n, reconnections 0, sleep mode modem
                    Clock register 00002002
                    22/3/2022, 15:31:20 Connected to 192.168.1.4
                    @paolozampini1973 Great. Test if the extruder drives on driver 5 and 6 work. These are tool 2 and tool 3. Send M302 P1 to allow cold extrusion.
                      @droftarts Yes ok but the temperature has already been set to zero degrees
                        @paolozampini1973 I just want to know if the motors work. Heat up the tool and remove filament if you need to.
                        paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                          @droftarts Yes quiet The machine is in the test phase filament is removed I understand that we want to see if everything works and if it still loses pace?
                            @paolozampini1973 No, I just want to check that the two extruder drives work in DueX2 mode.
                            paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                              @droftarts a moment I have problem with the Z switch the switch LEDs light up but it never stops and you have to configureconfig (19).g
                                @droftarts can you help me because the Z switches no longer intervene
                                  @paolozampini1973 Move Z2 endstop to ystop on Duet 2. Change config.g to:
                                  M574 Z2 S1 P"!zstop+!ystop"
                                    @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                                    Now I have this problem
                                      @paolozampini1973 Either Home X and Y first, or send M564 S0 H0 to allow axes to move without homing, then home Z.
                                        @droftarts it is already included in the configuration
                                          @paolozampini1973 Send G92 X0 Y0 Z0
                                            @droftarts DONE
