    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.7k
      droftarts administrators @paolozampini1973
      @paolozampini1973 Post a picture of the Duet. I think the endstop is plugged in in the wrong place.
        droftarts administrators @droftarts
        @droftarts Sorry, I realise that ystop was not free; the Y axis was using it already. There should not be a problem using a duex endstop, though.
        paolozampini1973undefined 2 Replies Last reply Reply Quote 0
        • paolozampini1973undefined
          paolozampini1973 @droftarts
          @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
          dovrebbero esserci problemi nell'utilizzo di un duex endstop.
          Yes exactly but it doesn't work anymore it has always worked perfectly so what do you do
            @droftarts That is, the Switches no longer work, the LEDs are signaled but it no longer works, it no longer stopsthe problem occurs on both Z axes when it reaches the end of the stroke In which the LEDs light up but it does not stop anymore
              @paolozampini1973 DueX2 should allow use of all 5 endstops. To test, plug the Z2 endstop back into duex.e6stop, change config.g back to
              M574 Z2 S1 P"!zstop+!duex.e6stop"
              Turn off Duet. Put DueX5 jumper back on. Turn on, and test Z homing.
              Then turn off Duet, remove DueX5 jumper, turn on and test Z homing.
              paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                @droftarts 22/3/2022, 16:35:46 Error: short-to-ground reported by driver(s) 7 8 9
                Error: over temperature shutdown reported by driver(s) 7 8 9
                so nothing works anymore and gives The error that I always complained always said
                  @paolozampini1973 Also, the X endstop line is wrong. X0 means no endstop, it should be X1 or X2, eg:
                  M574 X1 S1 P"!xstop"
                    @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                    That's because the on-board drivers are disabled. Ignore it for testing Z.
                      @droftarts so the Z axis doesn't work eitherconfig (20).g
                        @droftarts you are right because you rightly want to try how it goes like this the aces if they have a loss of pace I understand what you want to do you are fine with me too you are right but unfortunately it cannot be done
                          @paolozampini1973 Does it work after you send G92 X0 Y0 Z0?
                            G92 X0 Y0 Z0
                            I sent your message but nothing happens
                              @paolozampini1973
                              Look at the Console page, there is a longer message about G28 Z.
                              To test endstops: send M119 in the Console. Then hold down each endstop, send M119 again. Repeat for all endstops, checking that they change state.
                                @droftarts 22/3/2022, 16:49:55 Error: short-to-ground reported by driver(s) 7 8 9
                                22/3/2022, 16:49:52 M119
                                Endstops - X: at min stop, Y: not stopped, Z: at max stop, Z probe: at min stop
                                  Is that with both Y endstops pressed?
                                    Is that with both Y endstops pressed? NO
                                      @paolozampini1973 You need to press both.
                                      droftartsundefined paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                                        @droftarts Send a picture of Duet and Duex wiring.
                                          22/3/2022, 16:55:26 M119
                                          Endstops - X: at min stop, Y: at min stop, Z: at max stop, Z probe: at min stop
                                          droftartsundefined 2 Replies Last reply Reply Quote 0
                                            Okay, that shows they are working. Post your homez.g file.
