    Save custom "Machine movement steps"
    Duet Web Control
    • jp.douarvil 0undefined
      jp.douarvil 0
      I am using a Duet3 with firmware 3.4.
      Every time I refresh the Web Interface page in my browser the customized values of the movement steps got reset to their default values. I haven't found any way to save those custom values.
      Is it even an available option? Or is it necessary to alter the source code of the Duet Web Interface?
      Thank you for your help.
      Re: Change proposal to DWC Head Movement Steps...
        droftarts administrators @jp.douarvil 0
        @jp-douarvil-0 DWC user-customised settings are stored on the SD card in /sys/dwc-settings.json unless "Use local storage" is enabled on the settings page. In that case the settings are stored in the browser's local storage. What browser are you using?
        jp.douarvil 0undefined 1 Reply Last reply Reply Quote 1
          jp.douarvil 0 @droftarts
          @droftarts Thank you.
          I use Firefox for browsing. The same behavior is experienced using Edge however.
          I have to add: I am using a 6 axis 3D printer (X, Y, Z, U, V, W).
          Correct values are saved in the "dwc-settings.json" file but only X, Y and Z axis steps values are not reset to default upon refreshing the page. Could it be a bug?
          • chrishammundefined
            chrishamm administrators @jp.douarvil 0
            @jp-douarvil-0 said in Save custom "Machine movement steps":
            Thanks, I can confirm this is a bug - move steps for additional axes are not correctly loaded.
            I'll fix it in the next DWC version.
            Duet software engineer
