Change proposal to DWC Head Movement Steps...
  • Hi,
    the proposal its in DWC change the steps in "Manual Head Movements", especially on the Z axis ... with two proposals:
    A- For example: 0.05 - 0.5 - 5 - 20 - 100
    or
    B- That can be configured in DWC, and establish the steps that each one more interests you.
    The reason for changing the increments in manual movement, is that at least in my case, my delta printer has an important height, about 500 mm, and when I want to move the print head from Z = 500 to Z = 0 .. There are many clicks .... It's certainly not important, but I preferred the 100 mm before, the 50 now.
    It is curious that in X and Y the 100 mm remain, where the distances of the beds are usually smaller, and if it could be interesting to have X = Y = 50 mm, and change to Z.
  • Moderator
    Try right clicking on the speeds in the dialogue. You should be able to pick your own custom values.
  • @phaedrux Thanks, thas perfect.... the answer has arrived before posting the question .... bufff, how fast.
    Thank you
