    MotionWebcamServer plugin - Missing library
    Beta Firmware
    1.8k
    • luckyflyerundefined
      luckyflyer
      I have the plugin running and have a grey screen that has a message in the top left corner "unable to open video device". I tried a different (known to work camera) with the same results. I ran lsusb and the ports see the camera. I'm using http://192.168.0.181:8081/0/stream Any ideas? Thanks
        luckyflyer
        Any ideas why the grey screen?
        • chrishammundefined
          chrishamm administrators @luckyflyer
          @luckyflyer Your error message says "Unable to open video device" so your webcam is probably not recognized by the Pi or you don't have access to it. Can you check if /dev/video0 exists? That's the default in the motion settings (see motion.conf in the System Files directory).
          Please run sudo gpasswd -a dsf video and reboot your Pi. That should fix it.
          Duet software engineer
          MintyTreborundefined 1 Reply Last reply Reply Quote 0
          • MintyTreborundefined
            MintyTrebor @chrishamm
            @chrishamm I have just enabled this plugin on a brand new clean duet image install on a pi4 with v3.4. The permissions issues described above were present on the included version of the plugin, and the fix previously posted did indeed work to enable the plugin to start.
            However the permissions issues seem to be deeper within the operations of the plugin.
            By default the plugin cannot access /dev/video*, neither can it create a log entry in the default logging folder set in the config file (when enabled). I changed the log folder to the tmp directory and I was able to see in the logs that motion was complaining it cannot access the video* device, which results in the grey screen shown in @luckyflyer post.
            To prove this is a permissions problem I changed the permissions of /dev/video0 in the terminal (chmod), and the plugin was able to start with video working correctly. I looked at
            /etc/apparmor.d/dsf.MotionWebcamServer
            and I can see there is an entry to set the access permissions to /dev/video* in the file, but this does not seem to be working as expected.
            --edit - I see you have updated your post since I started this one. I will try the proposed additional command....
            -- Update 2 - Additional command worked. Also I found adding the following line to the Live Stream Configuration Parameters section in motion.conf, improved the output framerate significantly :
            stream_maxrate 50
            NodeDSF - Native Node-Red integration with Duet boards.
            BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
            ReleaseMgr - Duet update info inside DWC.
            Repo
            MintyTreborundefined 1 Reply Last reply Reply Quote 1
              MintyTrebor @MintyTrebor
              If anyone is interested you can show the motion "control" web page inside DWC to allow you access / change some advanced video values (brightness, size etc) in a simple gui provided by motion:
              (you will need BtnCmd Plugin to do this)
              Set your motion config like below:
              & restart the plugin
              In BtnCmd add a remote source panel:
              And set the URL to http://[pi ip]:8080/ eg:
              Then resize to fit your screen and save the layout.
              Repo
              chrishammundefined adammhaileundefined 2 Replies Last reply Reply Quote 2
                chrishamm administrators @MintyTrebor
                @mintytrebor DWC lets you show the same content on the Jobs -> Webcam page if you check Embed webcam image in an iframe on the Settings -> General page and change the config + URL accordingly.
                PS: I'm rebuilding DuetPi to make the required changes from above obsolete. The next DSF version will fix it, too.
                  @chrishamm said in MotionWebcamServer plugin - Missing library:
                  Great. Thanks @chrishamm
                  Repo
                    luckyflyer
                    @chrishamm, @MintyTrebor Thanks
                      luckyflyer
                      @chrishamm @MintyTrebor I would like to increase the frame rate. Could you help a Linux dummy out and give me the exact command to enter to change the frame rate. Thanks
                      adammhaileundefined 1 Reply Last reply Reply Quote 0
                      • adammhaileundefined
                        adammhaile @luckyflyer
                        @luckyflyer said in MotionWebcamServer plugin - Missing library:
                        In with your system files is now motion.conf. Open that file to edit in DWC and go to around line 59 and change the default 15 to whatever you want (within limits of your camera, of course). It'll look like this:
                        # Maximum number of frames to be captured per second.
                        framerate 15
                        luckyflyerundefined 1 Reply Last reply Reply Quote 0
                          luckyflyer @adammhaile
                          @adammhaile Wow that was too easy, thanks @adammhaile
                            luckyflyer
                            This post is deleted!
                            • Phaedruxundefined Phaedrux referenced this topic
                              adammhaile @MintyTrebor
                              @mintytrebor Are you aware of any way to get motion to output a stream larger than 640x480?
                              I've tried updating motion.conf but no matter what size I set the stream stays tiny.
                                MintyTrebor @adammhaile
                                @adammhaile
                                My Config:
                                motion.conf.txt
                                I also made sure to use a resolution supported by my camera by checking:
                                v4l2-ctl --list-formats-ext
                                more info https://www.mankier.com/1/v4l2-ctl
                                Repo
