    MotionWebcamServer plugin - Missing library
    Beta Firmware
    1.8k
    • MintyTreborundefined
      MintyTrebor @MintyTrebor
      If anyone is interested you can show the motion "control" web page inside DWC to allow you access / change some advanced video values (brightness, size etc) in a simple gui provided by motion:
      (you will need BtnCmd Plugin to do this)
      Set your motion config like below:
      & restart the plugin
      In BtnCmd add a remote source panel:
      And set the URL to http://[pi ip]:8080/ eg:
      Then resize to fit your screen and save the layout.
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      chrishammundefined adammhaileundefined 2 Replies Last reply Reply Quote 2
      • chrishammundefined
        chrishamm administrators @MintyTrebor
        @mintytrebor DWC lets you show the same content on the Jobs -> Webcam page if you check Embed webcam image in an iframe on the Settings -> General page and change the config + URL accordingly.
        PS: I'm rebuilding DuetPi to make the required changes from above obsolete. The next DSF version will fix it, too.
        Duet software engineer
        MintyTreborundefined 1 Reply Last reply Reply Quote 1
          MintyTrebor @chrishamm
          @chrishamm said in MotionWebcamServer plugin - Missing library:
          Great. Thanks @chrishamm
          Repo
          • luckyflyerundefined
            luckyflyer
            @chrishamm, @MintyTrebor Thanks
              luckyflyer
              @chrishamm @MintyTrebor I would like to increase the frame rate. Could you help a Linux dummy out and give me the exact command to enter to change the frame rate. Thanks
              adammhaileundefined 1 Reply Last reply Reply Quote 0
              • adammhaileundefined
                adammhaile @luckyflyer
                @luckyflyer said in MotionWebcamServer plugin - Missing library:
                In with your system files is now motion.conf. Open that file to edit in DWC and go to around line 59 and change the default 15 to whatever you want (within limits of your camera, of course). It'll look like this:
                # Maximum number of frames to be captured per second.
                framerate 15
                luckyflyerundefined 1 Reply Last reply Reply Quote 0
                  luckyflyer @adammhaile
                  @adammhaile Wow that was too easy, thanks @adammhaile
                    luckyflyer
                    This post is deleted!
                    • Phaedruxundefined Phaedrux referenced this topic
                      adammhaile @MintyTrebor
                      @mintytrebor Are you aware of any way to get motion to output a stream larger than 640x480?
                      I've tried updating motion.conf but no matter what size I set the stream stays tiny.
                      MintyTreborundefined 1 Reply Last reply Reply Quote 0
                        MintyTrebor @adammhaile
                        @adammhaile
                        My Config:
                        motion.conf.txt
                        I also made sure to use a resolution supported by my camera by checking:
                        v4l2-ctl --list-formats-ext
                        more info https://www.mankier.com/1/v4l2-ctl
                        Repo
