No setting motor current with macro
Using Duet Controllers
663
    nriviera
    I'm currently working on a BLV with a jubilee tool changer (with the tool changer a work in progress). Currently I have two tool heads that I use a Triangle Matrix Extruder and a Mellow Sunrise both through a 1LC toolboard. To make it easier to change tools I've created a 'ToolBoardN.g' file for each setup. When the printer is turned on it loads an 'Power On' macro which then starts a "Start Tools" macro which then references which just has M98"ToolBoard1.g" and "Toolboard2.g" that I just comment in and out as needed.
    Weirdly since changing to the this system the motor current doesn't seem to set and the stepper just stalls. However If I run the "Start Tools" macro again it works normally. Ditto if I run an M906 with the E current. The macro is clearly running because my fans/z-probe etc run correctly. I've also tried various delays between powering on and running the macro without any improvement.
    Does anyone have any ideas why?
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 06:07:32 GMT+0000 (Coordinated Universal Time)
    G90                                                       ; send absolute coordinates...
    M83                                                       ; ...but relative extruder moves
    M550 P"Cube"                                              ; set printer name
    M669 K1                                                   ; select CoreXY mode
    ; ATX power
    ;M80
    M569 P0.4 S1                                              ; physical drive 0.4 goes forwards
    M569 P0.3 S0                                              ; physical drive 0.3 goes forwards
    M569 P0.0 S0                                              ; physical drive 0.0 goes forwards
    M569 P0.1 S0                                              ; physical drive 0.1 goes forwards
    M569 P0.2 S0                                              ; physical drive 0.2 goes forwards
    M569 P0.5 S1                                              ; physical drive 0.5 goes forwards
    ;Extruder Drives are setup in toolboard*.g files
    M584 X0.4 Y0.3 Z0.0:0.1:0.2 E20.0 U0.5               			  ; set drive mapping
    M350 X16 Y16 Z16 U16 I1                               ; configure microstepping with interpolation
    M92 X160.00 Y160.00 Z1600.00 U30.5	          	  ; set steps per mm
    M566 X3000.00 Y3000.00 Z20.00 U500.00         	  ; set maximum instantaneous speed changes (mm/min)
    M203 X20000.00 Y20000.00 Z900.00 U3000.00 	  	  ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z20.00 U250.00         		  ; set accelerations (mm/s^2)
    M906 X1700 Y1700 Z1100 U600 I30                	  ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                                   ; Set idle timeout
    ;Setup 3 motor z
    M671 X-50:-50:350 Y246:54:150 S10
    M208 X0 Y0 Z0 U0 S1                                       ; set axis minima
    M208 X310 Y300 Z300 U360 S0                               ; set axis maxima
    M574 X2 S1 P"io3.in"                                      ; configure active-high endstop for low end on X via pin !io1.in
    M574 Y2 S1 P"io2.in"                                      ; configure active-high endstop for low end on Y via pin !io2.in
    M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
    M574 U1 S1 P"io4.in"									  ; configure U end stop
    ;Setup no moeved to toolboard*.g files
    M557 X50:250 Y50:250 S50                                  ; define mesh grid
    ;Chamber Temp
    M308 S2 P"temp1" Y"thermistor" T100000 B4100 A"Chamber Temp"	;Setup chamber temperature sensor
    ; Heaters - Bed
    M308 S0 P"temp0" Y"thermistor" T100000 B4267 A"Bed Temp"             ; configure sensor 0 as thermistor on pin temp0
    M950 H0 C"out8" T0                                        ; create bed heater output on out0 and map it to sensor 0
    M307 H0 R0.940 C532.800:532.800 D6.30 S1.00 V23.7 B0      ; disable bang-bang mode for the bed heater and set model parameters
    M140 H0                                                   ; map heated bed to heater 0
    M143 H0 S150                                              ; set temperature limit for heater 0 to 150C
    M570 H0 P5 T15 S10 ;Triggers shutdown if heater fault for more than 10s
    ; Fans - frame and MCU temp
    M308 S10 P"mcu-temp" Y"mcu-temp" A"MCU" ;creates a sensor on pin 10
    M950 F0 C"out7" Q500                                      ; create fan 0 on pin out7 and set its frequency
    M106 P0 S200 H10 X255 T25:40 C"MCU fan"                                          ; set fan 0 value. Thermostatic control is turned off
    M575 P1 S1 B57600                                         ; Enable support for PanelDue
    M575 P2 S1 B57600                                         ; Enable support for Neopixels
    ; Pressure Advance values
    M572 D0 S0.02
    ; Endstop based buttons
    M950 J0 C"io5.in" 					;creates trigger input for io5
    M950 J1 C"io6.in" 					;creates trigger input for io6
    M950 J2 C"io7.in" 					;creates trigger input for io7
    M581 P0 T2 S1				;Triggers trigger2.g (turns off power)
    M581 P1 T0 S1				;Triggers emergency stop
    M581 P2 T1 S1				;Triggers pause
    The "1-Power-On" macro
    M80
    G4 S6												  ;Wait 4 seconds for CAN to connect
    M98 P"0/macros/3-Start Tools"
    G4 S2												  ;Wait a second for toolboards to setup
    M501													  ; Load config-override.g values
    "3-Start Tools" Macro
    ;M98 P"ToolBoard1.g"
    M98 P"ToolBoard2.g"
    "ToolBoard2.g" system config file (the one currently in use)
    ;Setup for Mellow Sunrise
    ;Setup Extruder Drive
    M569 P20.0 S1                                              ; physical drive 20.0 goes forwards
    M350 E64 I1                             				  ; configure microstepping with interpolation
    M92  E2850									          	  ; set steps per mm
    M566 E300									         	  ; set maximum instantaneous speed changes (mm/min)
    M203 E3600										 	  	  ; set maximum speeds (mm/min)
    M201 E600								         		  ; set accelerations (mm/s^2)
    M906 E700 I30                	  						  ; set motor currents (mA) and motor idle factor in per cent
    ;Setup Toolboard Z-probe
    M558 P9 C"^20.io0.in" H5 F240 T6000 R.5                   ; set Z probe type to switch and the dive height + speeds
    M950 S0 C"20.io0.out"									  ; sets up servo output
    G31 P500 X40 Y15 Z3.4                                      	  ; set Z probe trigger value, offset and trigger height
    ; Toolboard 1
    M308 S1 P"20.temp0" Y"thermistor" T100000 B4100           ; configure sensor 0 as thermistor on pin temp0 on board 20
    M950 H1 C"20.out0" T1									  ; Sets heater 1 and maps it to temp probe 1
    M307 H1 A340.0 C140.0 D5.5 S2.00 V0.0 B0  			      ; Default Tool Heater Parameters.
    M143 H1 S300                               			      ; Maximum H0 (Extruder) heater temperature
    M570 H1 P5 T15 S10 ;Triggers shutdown if heater fault for more than 10s
    M950 F1 C"20.out2" Q500                                   ; create fan 0 on pin out7 and set its frequency
    M106 P1 S0 H-1 C"Parts Cooler 1"                      	  ; set fan 0 value. Thermostatic control is turned off
    M950 F2 C"20.out1" Q500                                   ; create fan 0 on pin out7 and set its frequency
    M106 P2 H1 T40:50 L25 H255 C"Hotend 1 Fan"                ; set fan 0 value. Thermostatic control is turned off
    M563 P0 D0 H1 S"1LC No 1" F1									  ; Define tool 0
    G10 P0 X0 Y0 Z0											  ; Set tool 0 axis offsets
    G10 P0 R0 S0
    ;Config Toolboard Buttons
    M950 J3 C"20.button0"				;creates tooboard button 0
    M950 J4 C"20.button1"				;creates tooboard button 1
    M581 P3 T3 S1				;Triggers lock
    M581 P4 T4 S1				;Triggers unlock
    undefined undefined 2 Replies Last reply 11 Jul 2021, 08:02 Reply Quote 0
      o_lampe @nriviera
      @nriviera
      The only thing I can think of is the 'config-override' file containing false motorcurrent info or the slicer start gcode.
      Can you call the toolboard macros in dedicated slicer profiles? That way you wouldn't have to comment out the unused toolboard.
      undefined 1 Reply Last reply 11 Jul 2021, 13:02 Reply Quote 0
        dc42 administrators @nriviera
        @nriviera please confirm that you are running firmware 3.3 on both the main board and the tool board.
        Do you see any error messages when running the power on macro? If you see CAN timeout messages, then it could be that your tool board is especially slow to start up. If that's the case, then upgrading its bootloader to the latest version (2.3) may help.
        undefined 2 Replies Last reply 11 Jul 2021, 13:10 Reply Quote 0
          nriviera @o_lampe
          @o_lampe Thanks, I didn't think of different slicer or tool profiles. I thought the config-overide but alas nothing in there to cause it.
            nriviera @dc42
            @dc42 I do get random CAN-bus unhandled inputs (2000, 3000, 2100 and sometimes others) so maybe that's it. I'll give it a go.
            undefined 1 Reply Last reply 29 Mar 2022, 10:16 Reply Quote 0
              nriviera @dc42
              @dc42 its been a while and the error messages never went away but I stopped having extrusion issues so I didn't pursue it. They seem to have come back intermittently this last week however. I've updated the bootloader to 2.4, running 3.4rc2 firmware. The config files are unchanged from above. Any idea?
                Update to 3.4 final.
                https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.0
                undefined 1 Reply Last reply 4 Apr 2022, 07:33 Reply Quote 0
                  @nriviera said in No setting motor current with macro:
                  That's typically triggered by removing power to the tool board but keeping 5V power to the main board. Is that what you are doing?
                  undefined 1 Reply Last reply 30 Mar 2022, 00:21 Reply Quote 0
                    nriviera @dc42
                    @dc42 yes. The 6HC 5v is always on as it triggers the 24v power which power the toolboards. I have a fairly large delay (I changed it to 10s but even 20s doesn't make any difference) to ensure the boards have enough time to boot but still get current issues intermittently.
                      nriviera @Phaedrux
                      @phaedrux said in No setting motor current with macro:
                      I have done the update and still have the issue unfortunately.
                      @dc42 said in No setting motor current with macro:
                      I'm not too fussed about the warnings and errors it's having to run a separate macro every-time I print is the annoying part. Should I use a very long delay?
                      undefined 1 Reply Last reply 4 Apr 2022, 07:50 Reply Quote 0
                        @nriviera what bootloader versions are the tool boards running? To find out, use M122 B# where # is the CAN address of the tool board.
                        Some tool boards running older versions of the bootloader sometimes take a while to start up after power is applied.
                        undefined 1 Reply Last reply 5 Apr 2022, 10:41 Reply Quote 0
                          nriviera @dc42
                          @dc42 weirdly the m115 output didn't have the bootloader but i updated it to the most recent last week so it should be 2.4
                          undefined 1 Reply Last reply 5 Apr 2022, 14:25 Reply Quote 0
                            @nriviera it's M122 that displays the bootloader version, not M115.
                            undefined 1 Reply Last reply 6 Apr 2022, 10:46 Reply Quote 0
                              nriviera @dc42
                              @dc42 sorry had a moment. Definitely 2.4
