    Duet3 Homing failed
    Using Duet Controllers
    1.9k
      Phaedrux Moderator @Hammad
      @hammad said in Duet3 Homing failed:
      The board is only connected to the PC using a high quality USB cable from ANKER.
      The Duet3 can be quite particular about USB cable and port. Please try some different combinations. Also make sure you remove the jumper after the erase.
      Hammadundefined 1 Reply Last reply Reply Quote 0
      • Hammadundefined
        Hammad @Phaedrux
        @phaedrux 3 different laptops and over 15 cables and still nothing. I removed the bridge from erase before resetting the board. I'm not sure what to do now. nothing seems to be working.
          jay_s_uk @Hammad
          @hammad do you have a powered hub you can try with?
          • Hammadundefined
            Hammad @jay_s_uk
            @jay_s_uk Do you think this will solve the problem?
              jay_s_uk @Hammad
              @hammad it has for people in the past. i've seen instances where standard USB doesn't provide enough power, especially laptops
              Hammadundefined 2 Replies Last reply Reply Quote 0
              • Hammadundefined
                Hammad @jay_s_uk
                @jay_s_uk Thank you for the idea. Ill let you know in few minutes if this actually works.
                • Hammadundefined
                  Hammad @jay_s_uk
                  @jay_s_uk Thank you so much! this actually worked. It is writing the Firmware right now. It's been at 34% for a while now. I'm just glad that it connected!
                    jay_s_uk @Hammad
                    @hammad one step forwards and all that
                    • Hammadundefined
                      Hammad @jay_s_uk
                      @jay_s_uk Do you think it is normal, that it's taking that long?
                        jay_s_uk @Hammad
                        @hammad no, its not normal for it to take very long. last time I flashed one the increase in % was fairly uniform and only took a minute or so.
                        maybe try again?
                        • Hammadundefined
                          Hammad @jay_s_uk
                          @jay_s_uk Same thing. it gets stuck at 35%. I've tried it from a different Laptop.
                            jay_s_uk @Hammad
                            @hammad not a good sign. hopefully @Phaedrux or @dc42 can comment
                              dc42 administrators @jay_s_uk
                              It might be worth trying the modified version of Bossa that I released recently. See the fork of Bossa at https://github.com/Duet3D/BOSSA/releases/tag/1.9.1a-duet3d.
                              Hammadundefined 1 Reply Last reply Reply Quote 1
                              • Hammadundefined
                                Hammad @dc42
                                @dc42 It does the same and gets stuck at 34% of the writing process. Any other ideas? I hope this isn't the only way.
                                  Can you confirm that you have the same write options checked?
                                  • Hammadundefined
                                    Hammad @Phaedrux
                                    @phaedrux Yes, I followed the instructions in the documentation. I've tried from many different PCs and cables. The board gets detected but the writing process doesn't finish. I even left it over night and it stayed at 34%. I tried older versions of the Firmware and it doesnt get beyond 34% for some weird reason.
                                      dc42 administrators @Hammad
                                      @hammad when and where did you purchase the Duet? Which country are you in?
                                      • Hammadundefined
                                        Hammad @dc42
                                        @dc42 From Dold Mechatronik in Germany.
                                        • Hammadundefined
                                          Hammad @Hammad
                                          I received the board like a month ago.
                                          • Hammadundefined
                                            Hammad @Hammad
                                            @hammad @Phaedrux @dc42 The firmware writing worked. The issue was the powered USB hub. After uploading the firmware to the board the 5V and 3.3V LEDS stopped working.
