Linear actuator, DPDT relay, diodes
    cyberjoes
    Re: Linear actuator
    I need to control a 24 v DC linear actuator, it has limit switches for both ends of travel and I will do full travel for both directions. I have a DPDT relay that I plan to control with the Duet. I do not have flyback diodes yet. - what diodes should I spec? And can someone give me an idea of how I should wire and control this thing with the Duet, or is there a better way?
      rjenkinsgb
      This is the basic circuit you need for a reversing motor with limit switches:
      https://www.halloweenforum.com/attachments/relay-controlled-dc-motor-jpg.252253/
      The relay flywheel diode should preferably be a schottky or fast recovery type, with a higher current rating than the relay coil and a rather higher voltage rating than the circuit operates on.
      It would also be a good idea to add a kind flywheel circuit around the motor, to minimise relay contact arcing; the most effective is four diodes arranged as a bridge rectifier with the AC connections across the motor and DC out connected back to the power source (eg. the 24V supply) with bridge positive out connected to supply positive.
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      undefined 1 Reply Last reply 14 Apr 2022, 20:21 Reply Quote 0
        cyberjoes @rjenkinsgb
        @rjenkinsgb , Thanks for the help. This system was designed by someone with more circuits knowledge than I have, afraid I am more the type to follow a recipe when it comes to electronics
        I have found this: the control current of the relay is 46mA, voltage is 24, motors are also DC 24V (well we are driving them at 24V - I just pulled one out and it is rated for 12V, wonder if they are going to fail?) You are suggesting 5 diodes, right. Am I giving the right specs?
        I could not find the rated current draw for the linear actuators -- here are the specs, they are small:
        Power: 12V DC
        Stroke Length: 1.2"/30mm
        Retracted Length: 3.3"/84mm
        Extended Length: 4.8"/123mm
        Maximum Load: 64N/14lbs
        Travel Speed Without Load: (15mm/s)
        Protection Class: IP54 Rated
        Noise: <55 dB
        Inner Tube: aluminium
        Wire Length: 13 in
        Thanks for your time and knowledge
        Van
        undefined 1 Reply Last reply 15 Apr 2022, 06:57 Reply Quote 0
          dc42 administrators @cyberjoes
          @cyberjoes have you considered using a L298N module instead of a relay?
          What is the specification of the linear actuator, in particular how much current does it draw?
          undefined 1 Reply Last reply 15 Apr 2022, 19:11 Reply Quote 0
            cyberjoes @dc42
            @dc42 Thanks -- I ordered an L298N control board. It does seem to solve my issues. I found a good tutorial
            I don't know the current draw of these motors, I will check it on my multimeter, must be very low though - the motors are no bigger than my pinkie
            I did learn that the linear actuators are rated for 12V but we are driving them now with 24 V -- I just ordered a DC 24V to DC 12V 10A 120W Step Down Transformer. I think those will solve my problems. I will use the transformer for the l298n board and the motors.
            Thanks for pointing me to this solution
            Van
            3 out of 5
