DUEX 0.11 FAN 5
The M581 commands need to go into config.g
trigger0.g needs to have
M106 P5 S255
as its content
trigger1.g needs to have
M106 P5 S0
as its content
@oliof said in DUEX 0.11 FAN 5:
M106 P5 S255
as its content
M106 P5 S0
as its content
trigger0.g trigger1.g config (31).g
You can see if that's as good as I did -
Your trigger files do not have the M106 commands as their content.
Please can you correct me the files I posted I don't want you to spend a lot of time
@paolozampini1973 Add the following two lines at the end of config.g:
M581 T1 P17 S0 M581 T0 P17 S1 put the following into the file
/sys/trigger0.g
and nothing elseM106 P5 S255
/sys/trigger1.g
and nothing elseM106 P5 S0
Also, I am assuming you are using a toggle switch like this:
No I'm not using this SWITCH But what does it have to do with it
@paolozampini1973 what kind of switch do you use? show me a photo. A toggle switch with two positions will work with my example. If you use a momentary / push button switch it will not work like that, another solution is required.
@paolozampini1973 that kind of switch should work with the solution I provided.
But I surely do hope that you are NOT connecting high voltage to the pins!! That would blow up the board.
@oliof So the talk is this I have to activate a fan When activating the x axis and the if Y with the external drivers that I connected EN + EN- when enabled Enables also the fan for as long as notified EN + and when EN- is Disable we will also need the fan but honestly the switch has absolutely nothing to do with it Maybe I didn't explain myself
However I did copy and paste and the fan does not turn on
@oliof EN + EN- now they are fully functional. When it starts printing the motors go to on mode at the end of the print they go to unit off and work very well the cooling fan for the engine must also work in the same way
@paolozampini1973 So you want to start the fan when a print starts, and stop it when the print is finished? Then you can put the
M106 P5 ...
commands into your start gcode and end gcode in your slicer.No need to use pins and triggers.
M106 P5 ...
but in this way if I go to make six prints in 30 minutes each time I have to insert it in the GCODE and so it becomes very cumbersome
@oliof Anyway I did what you wrote to me and the fan doesn't work it always stays off When the print started or I move the axis manually
@paolozampini1973 every slicer allows you to define custom start and end gcode that is added to the file automatically during slicing.
That is where you can add the commands to start and stop the fan. You set it up one time, it automatically gets added to the file.
Yes I know and by the way I am now using Ultimaker Cura Enterprise 4.10.0 and it works very well.It solved many problems
but I needed that it is activated in that way because I need it so also for other reasons -
@oliof Anyway I did as you told me and it doesn't work I did copy-paste it doesn't work
Have you come around to the idea of using a thermostatically controlled fan tied to a heater active during the print yet?
If that is truly unacceptable, it's possible to use daemon.g and a conditional gcode block to enable fan 5 when the machine state is processing.
@paolozampini1973 I am not sure that you can use enable to get the trigger. I assumed you wanted to turn on the fan manually with a switch since that is how you use pins usually. You have now clarified that, and my proposed solution is not applicable to your issue.
Anyway, I am running out of time for tonight and may revisit this topic later.
