    DUEX 0.11 FAN 5
    Gcode meta commands
    2.7k
      Perhaps you can share the solution that Oliof was so kind to provide and perhaps we can explain it.
      paolozampini1973undefined 1 Reply Last reply Reply Quote 0
      • Phaedruxundefined Phaedrux moved this topic from Documentation
      • paolozampini1973undefined
        paolozampini1973 @Phaedrux
        @phaedrux said in DUEX 0.11 FAN 5:
        oliof
        M581 T1 P17 S0 defines trigger 1
        then you need a macro called trigger1.g
        In that Macro you do M106 P5 S0
        M581 T0 P17 S1 defines trigger 0
        then you need a macro called trigger0.g
        In that Macro you do M106 P5 S255
          That seems pretty straightforward.
          M581 T1 P17 S0
          M581 T0 P17 S1
          would need to go in config.g
          Then create two macro files in the sys folder: trigger1.g and trigger0.g
          Those are just text files and you can create them in the web interface or on your computer and upload them. Put the M106 commands into those trigger macros respectively.
            M581 T1 P17 S0
            M581 T0 P17 S1
            trigger0.g trigger1.g
            I did but it doesn't work I don't understand why
              paolozampini1973 @oliof
              @oliof said in DUEX 0.11 FAN 5:
              @paolozampini1973 as I wrote in chat, define triggers using M581 and put the fan control commands in the corresponding trigger macros.
              Could you please tell me the explanation I don't know where to get the macros are created How to do it I don't understand I hope not to bother you too much
              • oliofundefined
                oliof @paolozampini1973
                @paolozampini1973
                The M581 commands need to go into config.g
                trigger0.g needs to have
                M106 P5 S255
                as its content
                trigger1.g needs to have
                M106 P5 S0
                as its content
                  @paolozampini1973
                  M106 P5 S255
                  as its content
                  M106 P5 S0
                  as its content
                  trigger0.g trigger1.g config (31).g
                  You can see if that's as good as I did
                  • oliofundefined
                    Your trigger files do not have the M106 commands as their content.
                      Please can you correct me the files I posted I don't want you to spend a lot of time
                      • oliofundefined
                        @paolozampini1973 Add the following two lines at the end of config.g:
                        M581 T1 P17 S0
                        M581 T0 P17 S1
                        put the following into the file /sys/trigger0.g and nothing else
                        M106 P5 S255
                        put the following into the file /sys/trigger1.g and nothing else
                        M106 P5 S0
                        • oliofundefined
                          oliof @oliof
                          Also, I am assuming you are using a toggle switch like this:
                          https://www.flickr.com/photos/adafruit/29889840241
                            No I'm not using this SWITCH But what does it have to do with it
                            • oliofundefined
                              @paolozampini1973 what kind of switch do you use? show me a photo. A toggle switch with two positions will work with my example. If you use a momentary / push button switch it will not work like that, another solution is required.
                                AC 17
                                • oliofundefined
                                  @paolozampini1973 that kind of switch should work with the solution I provided.
                                  But I surely do hope that you are NOT connecting high voltage to the pins!! That would blow up the board.
                                  paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                                    @oliof So the talk is this I have to activate a fan When activating the x axis and the if Y with the external drivers that I connected EN + EN- when enabled Enables also the fan for as long as notified EN + and when EN- is Disable we will also need the fan but honestly the switch has absolutely nothing to do with it Maybe I didn't explain myself
                                    However I did copy and paste and the fan does not turn on
                                      @oliof EN + EN- now they are fully functional. When it starts printing the motors go to on mode at the end of the print they go to unit off and work very well the cooling fan for the engine must also work in the same way
                                      • oliofundefined
                                        @paolozampini1973 So you want to start the fan when a print starts, and stop it when the print is finished? Then you can put the M106 P5 ... commands into your start gcode and end gcode in your slicer.
                                        No need to use pins and triggers.
                                          but in this way if I go to make six prints in 30 minutes each time I have to insert it in the GCODE and so it becomes very cumbersome
                                            @oliof Anyway I did what you wrote to me and the fan doesn't work it always stays off When the print started or I move the axis manually
