    DUEX 0.11 FAN 5
    Gcode meta commands
    2.7k
    • oliofundefined
      oliof @paolozampini1973
      @paolozampini1973 every slicer allows you to define custom start and end gcode that is added to the file automatically during slicing.
      That is where you can add the commands to start and stop the fan. You set it up one time, it automatically gets added to the file.
      paolozampini1973undefined 2 Replies Last reply Reply Quote 0
      • paolozampini1973undefined
        paolozampini1973 @oliof
        @oliof said in DUEX 0.11 FAN 5:
        Yes I know and by the way I am now using Ultimaker Cura Enterprise 4.10.0 and it works very well.It solved many problems
        but I needed that it is activated in that way because I need it so also for other reasons
          @oliof Anyway I did as you told me and it doesn't work I did copy-paste it doesn't work
            Have you come around to the idea of using a thermostatically controlled fan tied to a heater active during the print yet?
            If that is truly unacceptable, it's possible to use daemon.g and a conditional gcode block to enable fan 5 when the machine state is processing.
            paolozampini1973undefined 1 Reply Last reply Reply Quote 0
            • oliofundefined
              @paolozampini1973 I am not sure that you can use enable to get the trigger. I assumed you wanted to turn on the fan manually with a switch since that is how you use pins usually. You have now clarified that, and my proposed solution is not applicable to your issue.
              Anyway, I am running out of time for tonight and may revisit this topic later.
                @oliof Ok thanks Okay we'll go back when you can
                  paolozampini1973 @Phaedrux
                  @phaedrux said in DUEX 0.11 FAN 5:
                  Obviously making you start a thermostated fan is much simpler but for me it is not enough practically not good
                    If you're concerned about the motor temp, why not add a thermistor to the motor itself and use that as the source of thermostatic control.
                    But I have to question the premise entirely at this point, is the motor temperature really a concern?
                      Yes, of course the engine temperature is a problem
                      I just don't want to leave them on all the time because now they always stay on you are right I could also put a thermocouple in them which would be simpler
                        Phaedrux Moderator @paolozampini1973
                        @paolozampini1973 said in DUEX 0.11 FAN 5:
                        Then adding a 10 cent thermistor to allow for thermostatic control is a good option.
                          would like to enable fan F5 when PIN 17 is enabled and disable fan when PIN 17 is disabled ?
                            @oliof Good morning There is a possibility that we will resume the speech of the fins 17 To enable the fan and disable the fan I remember you told me that the time was up and we would talk about it later
                              dc42 administrators @paolozampini1973
                              @paolozampini1973 what do you mean by "pin 17" ?
                                paolozampini1973 @dc42
                                @dc42 said in DUEX 0.11 FAN 5:
                                Thank you for answering me I wasn't hoping for it anymore I have been trying to talk to her for a long time.
                                axis Y external DRIVER 7 ( WHEN switch to mode ON PIN17 = EN + 3.3V switch to mode ON FAN 5
                                WHEN switch to mode OFF PIN 17 = EN + 0.0V switch to mode OFF FAN 5 )
                                axis X external DRIVER 8 ( WHEN switch to mode ON PIN 22 = EN + 3.3V switch to mode ON FAN 6
                                WHEN switch to mode OFF PIN 22 = EN + 0.0V switch to mode OFF FAN 6 )
                                I want to specify that the dwelling of the X and Y motor and the disabling of the x & y motor works perfectly at the beginning Print skills and x & y motors at the end of the print disables the X and Y motors this function works perfectly
                                  @paolozampini1973 so you are looking to turn a fan on when an external driver enable pin is activated, and off when it is deactivated.
                                  I think you can do that in RRF 3.4.0 by pretending that the fan is a motor brake solenoid. Use the M569.7 command https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m5697-configure-motor-brake-port to associate that fan port with the motor.
                                    the command 569.7 is not very clear how to use it there is a bit of confusion can you help me please I'll publish my config.g
                                    config (33).g
                                      paolozampini1973 @paolozampini1973
                                      config (33).g
                                      @dc42 Good evening can you help me please
                                        Why not use a thermistor attached to the motor? Then you can also see what the motor temperature actually is to know if it's an issue or not. You're trying to make this the more complicated than necessary.
                                        paolozampini1973undefined 3 Replies Last reply Reply Quote 0
                                          for the simple reason that I would have to make a structural change AND in any case it would not be 100% reliable it would be 96% reliable and also because I have to use the same rule for other things other functions
                                            your solution is much cheaper but much more complicated and then I haven't solved all the problems. Anyway, thanks for your interest
