Solved Motors not reacting
Hello experts,
I am having a problem with my setup.
The setup is a Duet3 6HC with 3 1XD modules that are connected to stepper motors from Nanotec. Link to the Motors:
I'm still getting no response from the motors even after upgrading the firmware to 3.4 to solve the issue with 1XD modules. To check the motors I used an Arduino Uno with grbl and the motors moved. I still can't figure out why the motors won't respond to the Duet3 setup. I checked the wiring and every bit of the documentation. Any idea what could be the problem?
I also tried forcing the axis to report as homed and the motors still won't move. The coordinates on the touchscreen (Panel 7) change when I try to move the axis but the motors aren't moving at all.
Extra info:
The limit switches are in NC setup.
There will be no heated bed or fans in this printer
The Mainboard will not use Ethernet.thanks for the support!
OK, those are a new set of motor/drivers for me.
Can you please post:
- Your complete config.g
- A diagram of how you have the motors wired to the Duet.
- A diagram showing any other wiring to the motors such as power, enables etc.
- A link to the manual for the exact motor/driver you are using.
Can you also post the results of M122 and M122 B# where # is the can bus address of each of the expansion boards?
This post is deleted! -
I found the error... 2 1XD Boards had the same address and it was causing the whole problem. Thanks for the support!
